AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Best lights to use in Halo 6" cans for Home Theater
post #1 of 3
I just had my basement finished and have about 12 - 6" Halo recessed lights in the "Home Theater" area.
What type of bulbs are everyone using for recessed lights in the HT?
post #2 of 3
I have a large number of cans over the seating area in my HT. I used pinhole baffles to restrict the light down not on the screen and was using 50 watt reflector bulbs. They were forever burning out from what I suspect is vibration from the floor above. So I tried a bunch of these and Love them.
http://www.homedepot.com/Electrical-Light-Bulbs-LED-Light-Bulbs/h_d1/N-5yc1vZbm79/R-202188260/h_d2/ProductDisplay?catalogId=10053&langId=-1&storeId=10051
I put these over my back bar
http://www.homedepot.com/Electrical-Light-Bulbs-LED-Light-Bulbs/h_d1/N-5yc1vZbm79/R-202324430/h_d2/ProductDisplay?catalogId=10053&langId=-1&storeId=10051
Edited by BIGmouthinDC - 9/26/12 at 1:25pm
post #3 of 3
I've found that some of the traditional *indoor* flood and spot bulbs typically used for 6" cans vibrate with certain low freq tones. Run a test disc and you'll see...
The outdoor bulbs don't vibrate near as much, or at least it's not noticeable, and they last longer.
i also like the outdoor bulbs because they look better by filling the 6" baffle a lot more.
