Originally Posted by
Aussie Bob II
They show you
attempting to correct each zone. Picture #5 shows that at the end of the process there's still about a pixel's worth of CA left.
Are the pics pixel level sharp, with excellent exposure, focus and framing? Admittedly, no. I was simply trying to illustrate - if crudely, with mediocre pics - that CA could be dialed out to a large degree using the ECC on certain current projectors. The Sony HW50 does not have the correction level adjustment range of the Epson we tested previously, for example, so yes - there is some residual aberration in pic 5. This is why we are working with our partners to tweak the technology for maximum effectiveness. However, despite the crudeness of the pictures, you can see that I was able to dial out a large degree of the aberration.
Aussie Bob II
Sophistry... The source was quoted as an (apparently) official Panamorph email.
Hardly "sophistry." You had quoted two different people in one post, and I did not want to leave the impression that I made the original quote. Since I had taken the time to respond, I thought just ignoring that section of your post could be misinterpreted.
Aussie Bob II
I've lost count of the number of threads here endlessly discussing Chromatic Aberration, to the
nth degree. Ditto for screen size, distortion and pincushion. There are probably dozens of them, with hundreds, if not thousands of posts attached. Many end-users do care.
Totally agree! And for those that do, they can choose from one of your lenses, our own UH480 and DC1, the Schneider, the Isco, etc. They also can choose the CineVista and do the adjustments that I suggest. Is the latter the very best solution regardless of price? No. And it was never meant to be the "best solution." As I said before, the UH480 and DC1 are not going away. There is a reason for this.
Aussie Bob II
There are anamorphics about that have virtually
zero Chromatic Aberration
Yes - like the Panamorph UH480 and DC1. And yours and the Schneider / Isco, I am sure
Aussie Bob II
, don't claim less glass equals a sharper picture, that don't underestimate pincushion, and that don't assert one fixed focal setting is good for 6-16 feet. They don't need to form partnerships with projector manufacturers. In fact, they work with any projector out of the box. Some of them even publish specifications, in detail.
We are working in good faith, for our customers and our projector partners. We see having partnerships with projector manufacturers as a good thing. For example, it is largely through our partnership efforts that almost every projector manufacturer in the world has the proper scaling modes for anamorphic projection. I know because I was directly involved in those efforts. We are also working right now with Hollywood studios to develop anamorphic Blu-ray under the Folded Space banner. This is the value of seeing others as partners. The entire projection and anamorphic lens industry benefits from the time we put into these projects.
Your last quote above is mostly directed at Russell again, but this time I will take a moment to address the issues even though I did not make the claims. The CineVista will likely be sharper than most other lens types in the center of the picture. As one moves away from the center, you are correct that the sharpness will be reduced by the chromatic aberration in the horizontal direction. This can be pretty effectively compensated for with the chromatic correction we have been discussing. Yes, it is true that other than in the center of the image, lenses like our own UH480 / DC1 (and others, such as your own, I imagine) will have a sharper overall image and therefore are more desirable
if one has the money to spend on them.
I would imagine that Russell took a guess at the amount of pincushion he was seeing and did not measure it precisely (hence his use of the term "about."). You suggested he re-measure. That's fair.
Yes, it's true that the CineVista will work at its absolute best in a narrower sweet spot than 6 - 18 feet. What was said was "the focus range can go down to 6 feet and up to 18 feet without any noticeable blurring or diminishing of the image." While I would have included the modifier "with normal video content," the statement is essentially true. Unless one is bringing up test patterns, the image does not start to look noticeably blurry until one gets beyond those recommended throw distances.
