AVS › AVS Forum › HDTV › HDTV Recorders › PC recording decisions
post #1 of 7
I currently am a 2 TiVo household. I have 2 premiers. I have one downstairs and one in my den.
I'm thinking of replacing the upstairs TiVo with Windows Media Center. I have a beast of a computer and Win 7 installed.
I'm looking at the following:
Hauppauge WinTV DCR-2650 Dual Tuner Cable Card TV Tuner
http://www.amazon.com/Hauppauge-WinTV-DCR-2650-Tuner-Cable/dp/B005FPT38A/ref=wl_it_dp_o_pC_S_nC?ie=UTF8&colid=20D81NYGOXO8W&coliid=I1YGLO8DJCRBMY
and
Ceton InfiniTV 4 PCIe - 4-channel Internal Cable TV Tuner Card for CableCARD
http://www.amazon.com/Ceton-InfiniTV-PCIe-4-channel-CableCARD/dp/B003B4VLJQ/ref=pd_sim_e_4
Are there other tuners I should be looking at? I subscribe to premium channels, so I will need cable card access. I already have the digital tuner boxes since TiVo needed them.
I'm looking at the Hauppauge more for price and simplicity. I don't need 4 tuners. 2 is plenty. It's an external device so I don't have to bust open my sweet case and move the water cooling out of the way.
Any thoughts?
post #2 of 7
I would take a look at this guy (Fry's has it for $129 semi-regularly)...
http://www.amazon.com/SiliconDust-HDHR3-CC-HDHomeRun-CableCARD-tuners/dp/B004HKIB6E/ref=pd_cp_pc_0
It features 3-tuners (from experience you can't have too many) and it connects to your network (not a PC) so you view TV on any/all of your PCs/Macs. Not sure how reliable Amazon rating's are but it's higher rated than the others and I have been using two of their OTA dual tuners for several months with zero issues. They haven't even been rebooted... they simply work. If you are still in the thinking stage you might want to check my WMC versus TiVo thread... it pretty much lets you know how I made out.
post #3 of 7
post #4 of 7
I like the HDHomeRun, but I have a problem. How do I get this to TV's?
I have a PC upstairs that can do the recording, but I need to send the signal to two TV's. Not sure how to output the video to those TV's. My card only supports two monitors, which I'm already using.
post #5 of 7
You have two options...
  • Extender - a device that natively supports your recording app. Such as the Xbox 360 and WMC.
  • Streamer - finding a streamer (stand alone or integrated in TV) that supports the recording app's' file format or converting the file to one it supports.
Both options are very limited and wide open at the same time so I'd suggest searching/reading a bit to find out what's available before trying to find a solution.
post #6 of 7
I'm taking a different look at this now.
Still looking at :
and
Or possiblely the HD Homerun.
One of my issues was "How will I get sound to the TV?"
The plan would be to use a Cable card with one of the devices above. The feed will go to the PC.
I'll have a long HDMI cable that will run from the video card to the TV.
I just purchased a wireless gaming headset. I've tested it, it works in the bedroom (which is on the other side of the TV)
I would control the channels/recording with this. http://www.amazon.com/Windows-Control-Infrared-Receiver-Ultimate/dp/B00224ZDFY/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=20D81NYGOXO8W&coliid=I1CR0QM95B082V
I can see the PC from the bedroom, so I should have line of sight with the remote and the headset.
Am I missing anything? In theory, should this setup work?
post #7 of 7
Anyone have any experience with this:
http://geniatech.com/pa/hd-cap-u800.asp
  Back to Forum: HDTV Recorders
