AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Looking to buy: Pioneer Elite SC-55 vs Pioneer Elite SC-65...advice?
post #1 of 3
I currently have an Elite VSX-23. I'm looking at bumping up to one of the last two years SC models due to a house change and completely different setup then when I bought the VSX-23. I have 2 zones I'd like to run to, and I really like the idea of the new airplay built into the models.
My question is: What is the big oustanding difference between the SC55 and SC65? Where would you guys suggest I spend mroe money to get the 65 over the 55?
I can get a used SC55 from a friend for a pretty solid price. But I think I can get an SC65 If I want for only 200-300 more. What should I do? Does the SC-65 have more to it that would justify spending more cash. I'm looking for something as well that will be more "long term friendly" that I won't have to upgrade again for a while.
My speakers aren't anything fancy, so either of those will drive what i have with no problem.
post #2 of 3
Also, I did find a few threads with similar questions, but no one really answered (I think some of them were prior to July when the 65 came out).
post #3 of 3
Hey bungi43,
Which one did you end up buying ? Did you find any more comparisons between the 2 models - SC55 & SC-65 ?
Edited by btikoo - 1/10/13 at 7:22am
