Originally Posted by TMcG
You could have the best system in the world, but if you don't set up the room properly and have the equipment calibrated for optimal performance, you are doomed with poor quality sound right from the start because of the room - and no amount of room correction software can fix the problem.
This is very harsh, and seems elite'ish, as well.
How can you say that all of us with good equipment are getting "poor sound" due to room limitations? Personally, I use Audyssey for correction, and it sounds fantastic! Could it be a bit better? Maybe, but it certainly is not poor sounding. I read a lot of reviews, and Ralph has some of the best equipment that I've seen. The fact he uses front projection is very useful to me as my dedicated room has FP as well.
Maybe you should focus your criticism on reviewers with 32" 720p LCDs, and sound bars?
Maybe it's because you haven't had time to check it out four yourself, but once you do, I'd like to hear it from you. Thanks again! And, yes, thanks Ralph!
). Best wishes!
