AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Nuvo AM/FM tuner broken display repair
post #1 of 3
I know the Nuvo NV-T2DF is no longer manufactured so if you want one you have to find a used one. However I'm seeing a pattern in most of the used units I find. Almost all of them have non-functioning displays.
Does anyone know what the problem is with them? I'm an engineer so I can fix most stuff unless its inside an IC that I can't purchase replacements of on the open market. I'm hoping its just a power supply issue or something simple.
Any info would be helpful. If anyone has a .pdf of the service manual that would be a big help.
post #2 of 3
You may want to consider getting a music server instead. Most radio stations stream online, in the US.
post #3 of 3
Yes they do. However the streams I've listened to of the local stations I like seem to use a low bit rate and it sounds all warbly. And I don't want to spend ~$2.5k for the Nuvo music server.
I took a chance and bought one for $140. Hopefully I can get it to boot without the display working.
  Back to Forum: Home A/V Distribution
