I have a question for LG dvd player owners, when playing music over the network, there is no screensaver and burn in occurs.
You can turn the tv off and the music continues as the player feeds the amp directly, but if you try to switch input on the tv it for some reason tells the dvd to pause the music.
There is a screen saver for when a movie is paused, it also appears when left alone in Netcast apps, Youtube streeming for example.
I was wondering if there was perhaps upgradable software, or a workaround anyone has come up with. I have searched the settings menu as well as the manual but no luck, any help?
cheers
Arron
edit, my apologies this should be in the blu-ray section.
cheers
Arron
