AVS › AVS Forum › Audio › Speakers › Want to add inwall L&R to corner location - help. (pic)
post #1 of 4
Best TV placement for my living room is in the corner. Both wife and I prefer inwall for aesthetics. This is our only option for the tv location. Seating is a sectional opposite the 90degree corner. Red squares are where I'd like to place the inwalls if possible.
Looking for suggestions on L/R/C
I have been searching for aimable speakers so that the convergance point wont be right in the middle of the room.
So far I've looked at Speakercraft brand online - yet to hear. Are those aimable enought? Are there inwalls out there that will work for me? I've been recommended Bose 191 since they're "articulated array". I know the reputation of the Bose AM series on here, not sure if the reputation continues to these units or if they'd be a good fit.
Not sure what I'll do with rears at this point since one of the walls for those will be an outside wall. I'll tackle that after the fronts.
Notes -
Sub - Existing CSW
Receiver - HK AVR 125 (to be upgraded in spring 13')
Budget for L/R/C $600 +/- total
Use - 90% TV&movies, 10% music
post #2 of 4
I would recommend a small pair of floorstanding speakers placed beside the tv and forget the center channel. Inwall speakers won't pivot enough to get the correct dispersion you are looking for.
post #3 of 4
The center would go below the TV.
Hoping someone knows of a speaker that will pivot enough.
post #4 of 4
I would not use in-wall speakers or try to cram floorstanding speakers in that space. I would use some bookshelf speakers with something like these wall mounts:
http://www.amazon.com/Pinpoint-AM-40B-Clamping-Bookshelf-Speaker/dp/B002UV03MW
Look for speakers that are front or sealed. Deftech, Kef, Boston, all are good brands to start with.
  Back to Forum: Speakers
