Hello all,
To give some background: I have a long distance from my AVR to my TV. First, I bought a 60' HDMI cable from BlueJeans cable. This worked fine for a year or so, then just stopped working one day. Everything was fine with an alternate HDMI cable, so I attribute that to something breaking in the Blue Jeans cable.
My next attempt was a HDBase-T monoprice extender. This worked fine for about 6 months, then it started randomly dropping the picture, but only for 1080p 24 content (oddly enough 1080p 60 was fine...) I verified that it only happened with my UTP cat6 solid cable (aout 50'). I attribute this to EMI issues and something wrong with the cable
So, I began to research STP cable. Then I learned that you really need a metal rj-45 shielded plug and a truly grounded socket on the extender. Unfortunately my monoprice extender is not grounded. Does anyone know of a truly grounded HDBase-T extender? I assume that means it will need to have a 3-pronged power cord too?
I would appreciate any help, I've wasted a lot of money and my wife is starting to lose patience, I'd like to get the right solution once and for all!
(ps, just had a crazy thought, maybe I could simply run a wire from the shielding on the cable to a pin in the ground on the wall outlet?)
Edited by trs79 - 9/29/12 at 10:37am
