I recently got my 2006-era HTPC out of storage and realized it's just not cutting it any more. I installed Precise Pangolin and it won't smoothly play DVDs at 1920x1080 using XBMC. Everything else about the software stack is making me pretty happy, except my CPU runs at 70%, and memory similarly used up. I had to create a swap file (something I haven't done in years) to prevent running out of memory!
This is what I have:
8400GS passive video card
AMD single-core 2.2GHz 90W
1.5GB DDR 400 ram
OCZ SSD
I'm running the system with a single 120mm fan and it seems to be doing ok heat-wise. I don't do gaming, but I do have high standards for video.
My question is, what should I upgrade? Does it make sense to buy a new video card, or should I bite the bullet and upgrade the mobo-processor-memory?
If I upgrade to Sandy Bridge or Ivy Bridge I get Intel graphics. Are these going to be better than my 8400GS? If not, it doesn't bother me to use my 8400GS...I won't feel like I'm 'wasting' the Intel graphics.
If I go with AMD Llano or Trinity or whatever, I get ATI graphics. I swore off ATI for Linux a long time ago, so I would be using my 8400GS no matter what if I buy AMD. Will my current video card cut it?
Any suggestions welcome. I also don't now what kind of ram or how much, I should be getting.
1.5GB DDR 400 ram
OCZ SSD
