Here are some suggestions:
2 X
EMP Tek E55Ti towers: $800
EMP Tek E56Ci Center speaker: $450
2 X
EMP Tek E5Bi bookshelf speakers: $250
Hsu VTF15h subwoofer: $1018
Total cost: $2518 delivered
That would be a killer system at just a hair over your budget.
Alternatively:
2 X
Infinity Primus P363 tower speakers: $400
Infinity Primus c351 center speaker: $200
2 X
Infinity Primus p163 Bookshelf speaker: $172
2 X
Power Sound Audio XV15 subs ($1600 shipped)
Total cost: $2372 delivered
great system with monster bass and under budget
another alternative:
2 X
Klipsch RB61 Bookshelf speakers: $550
Klipsch RC62 II Center speaker: $550
2 X
Klipsch Synergy B-20 Bookshelf speaker: $279
Rythmik FV15 subwoofer: $1124 not including shipping
Total cost: $2503 except for shipping on the subwoofer, which will likely be an additional $100 to $150
Just a bit over budget with shipping but very crisp and powerful bookshelf speakers and razor sharp sub
Yet another choice:
2 X
Ascend Acoustics CBM-170 Bookshelf speakers: $376
Ascend Acoustics CMT-340 Center speaker: $324
2 X
Ascend Acoustics HTM-200 Bookshelf speakers: $318
2 X
Hsu VTF3 mk4 subwoofers: ($1516 shipped)
Total cost: $2534 delivered
Again just a hair over your budget but extreme deep bass subs (solid 16 hz) plus + highly regarded speakers = terrific setup
And one more choice:
3 X Chase Pro 10 Monitors: $1035
2 X
CraigSUB VS-18.1 subwoofer + Dayton Amp: $1240 shipped
Total cost: $2554 delivered
Just slightly over budget. This would easily be the most powerful system, but the thing is accommodating the center might be a problem depending on your display setup, and the sub is pretty scary looking. This setup would get you closest to commercial theater dynamics.
Remember you also have to buy accessories like cabling and mounts, if you don't have them already. Get your speaker cable and HDMI cable at monoprice.com (save your money, do not buy them at a retail store!), and the bookshelf speakers mounts you will want are the
AM40 Pinpoint side-clamping mounts
. Seriously, if you need mounts, get those, they will save you a big headache.
