Hello,
I am slightly confused on throw distance and what I can and cannot do as far as measurements. The projector placement calculators recommend a throw distance of 12'7"
Problem is I can't mount the projector right at that distance, I can mount at roughly 13'6" or around 11 feet. OR, I can go off center by about 1 foot.
My room measurements are 16x11' , with a ceiling height of 7'6"
Screen size is 106" fixed at the wall.
Also, the calculator says the center of the lens must be 8.3" above the top of the screen. I am using http://www.projectorcentral.com/Optoma-HD33-projection-calculator-pro.htm for the measurements.
So, is it possible for me to move the projector back slightly ? I don't have the projector mounted yet as I am waiting for some parts to arrive first.
