AVS › AVS Forum › Audio › Speakers › Mixing/Connecting 6ohm and 8ohm Speakers to same Receiver ?
post #1 of 3
Heylo All,
I was hoping someone could help me here !
I have a pair of Yamaha NS-A200XT Towers ( 6ohms )and JBLs( 8 ohms ) and a JBL Sub ( 8 ohms ).
Would it be okay to connect all of those to the same receiver ( Yamaha RX-V665 ).
I would like to use the Yamahas for my Front L and R; and my JBLs for SR, SL, Center, SB-L, SB-R and the sub making it a 7.1 Setup.
Are there going to be any problems in connecting a setup this way ?
If I can/if it is okay to do this, what are my advantages/disadvantages and what should be my precautions ?
Any kind of thoughts / advice / help on this would be very helpful.
Cheers all...
post #2 of 3
No problem at all. A speakers's impedance is only nominal, as it changes with the frequency. Plus you are only talking a 2Ω difference.
post #3 of 3
  Back to Forum: Speakers
