AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Denon 2313CI audio on monitor 2
post #1 of 8
Hello,
I am running into an issue with my setup. I have a Denon 2313CI. From here there is an HDMI going to an Mitsubishi projector. In addition, I have a TV in the bar area that is connected to monitor 2 out via hdmi. I can get a picture at the bar TV, but no sound. Can the Denon just do a pass through to monitor 2 or do I need to put in a hdmi splitter or analog cable?
post #2 of 8
with just the avr, you can either pass the audio through OR have it processed by the avr... not both...
to do what you want, you would need a matrix switch before the avr...
post #3 of 8
If the 2313CI is still new, exchange it for a 3313CI which has the Zone 2 (HDMI) monitor output.
post #4 of 8
Can I just throw a powered sound bar on the TV and use an optical input from the TV?
I really don't want to open a can of worms by using a matrix switch as the projector is 3D and the TV is not.
post #5 of 8
nope... not if you want to get sound out of the avr too...
post #6 of 8
In order for there to be audio from a sound bar connected to the TV, the TV speakers have to be able to pass the audio as well.
post #7 of 8
Hello Again,
So I exchanged the 2313 for a 3313 and still cannot pass sound to the TV. I have video, but no audio at the TV. I am obviously missing something here.
Any help would be much appreciated.
Joe
post #8 of 8
The TV must be connected to the Zone 2(HDMI) output and one of the HDMI sources 1-6 selected for Zone 2.
