Hi, what kind of amp do you have it connected to, and did you use XLR's?
Edited by comfynumb - 1/10/13 at 4:48pm
The 8801's video processing is not supposed to degrade the video coming from the player, so leaving it enabled should be fine. Using a separate video cable connection from a player to the display device (if that's what you're doing) usually is needed only because the receiver or pre/pro can't handle high bitrate 3D or 4K signals. The 8801 can handle both.
