AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Marantz AV8801 Preamp/Processor Official Owner's thread
Marantz AV8801 Preamp/Processor Official Owner's thread - Page 61
post #1801 of 11289
Originally Posted by buckley44 View Post
Do you have to turn it off every time a TrueHD track is played or once you turn it off in the menu it should stay off?
Didn't have time to check last night, will take a look today
post #1802 of 11289
The only Think I'm not too crazy about at the moment is the Remote, my fat fingers have a hard time with it, and i wish the backlight would stay on longer even though you can press it twice to get another 2 sec, per the manual it just is not long enough,
I know most people will use another device, but till i get a hang of this I've been using the Marnatz.
Listened to some HD Tracks last night briefly with Marantz and sounded great, Has a warm tone to it,seems to fit nice into my system, with the audessey my bass is more controlled. Listened to Dark side of the Moon sacd and it never sounded better...
One thing happened to me last night though, i got stuck on the menu page and could not get off of it, the volume controlled worked and other features but could not close it out, eventually i had to restart the Marantz, then no problem.....
post #1803 of 11289
Don't want to derail the thread or break a rule, but is there an authorized dealer who can beat MSRP on the 8801? Or perhaps there's "deals" thread I could be pointed to?
post #1804 of 11289
I played StarTrek again, and the 8801 remembered the off position for compression...so that's good...
post #1805 of 11289
Some Paramount titles will engage DRC by default (it's an old bug) Iron Man has the same issue. Happened in a few of my previous processors. If the Marantz remembers to stay off, then good.
post #1806 of 11289
Also noticed a network ip oddity. I tried logging into the marantz this morning (statically assigned .110 address) but it was not responding on any browser.
Ran a network scan utility, the the 8801 was showing an ip of .207 (on my network, all dhcp addresses are .200 and above) The 8801 responded at that address from my browser
When I checked the GUI on the 8801, the network still showed a static .110 address, though not responding to that, only the .207 address. I re-saved the static ip, and then .110 worked... Bizarre....
I'm finding similar bugs & quirks with network, power, settings backup, video loss (with OSD still viewable/accessible). Lets all report these to marantz, so they could tweak the firmware. One thing about my Denon 4311CI was that it was solid. I'm sure a firmware update or two will remedy this, but they might not know of these bugs.
post #1807 of 11289
The OSD issue for me seems to be related to changing input resolutions, even on the same hdmi input. For example, changing channels on my directv, switching between 1080 and 720, at one point causes the 8801 to stop overlaying the osd onto the video. A power cycle of the Directv always brings the function back. But I've seen it with other devices on other physical inputs...
It's not 100% consistent, but that's the best correlation I can see so far.
I emailed Marantz support a few days ago but no response so far...
Edited by thrang - 1/13/13 at 10:52am
post #1808 of 11289
joerod
Between your Blu-ray player, 8801, Sony PJ, and DVD Duo which one do you prefer to handle the video processing with?
post #1809 of 11289
I got mine @ HiFI Heaven in Green Bay, WI. While they didn't move on the MSRP, they gave me a ridiculous trade on my AV7005. If you have something to trade in, it might be worth contacting them. I've worked with them on both my h/t system and a dedicated two channel. Great guys to work with.
www.hifiheaven.net
post #1810 of 11289
Originally Posted by Rosano View Post
Let me tell you Lex guys that are on the fence....I would not hesitate for one second in recommending this unit. I am not saying things like..blows it away...night and day diff etc.....the sound quality is excellent and I did here a clarity in the sound like a veil being lifted. It will not leave you wanting at all...directional effects allso seemed more pronounced. Now like i said no Audyssey engaged...and it was using straight DTS Master....no surround processing just like I would have with the Lex. This baby is nice...
Excellent!
I am interested in your comment "Lifted the veil".
For example, my 5507 is very bright and can change the balance of the sound. Many described it the same way.
I much prefer using the 7.1 analog inputs and letting my BDP-105 do the analog decoding.
The Onkyo is brighter, but fullness and detail is much greater coming from the 105 analog outputs.
One thing, I like to do is pick some albums that are already bright and see how they sound.
On this type of material, any additional treble will hurt your ears.
In the past, folks have said the Marantz produces a "warmer" sound.
Can you characterize its sound?
- Rich
post #1811 of 11289
Contact avs, great to work with
post #1812 of 11289
Originally Posted by baranowski View Post
the audio should be roughly the same between the d2 and the d2v... i will be looking forward to your thoughts after listening to your sacd...
thank you for the response.
Bill
Diehard D2v fans claim that it is quite a bit better than the D2. However, in this hobby, what's a big difference for some may be subtle or insignificant to others. It's not like driving cars where a car costing multiple times the cost of another will be an incontrovertible difference.
My previous processor was a D2. I would have been happy keeping it but I needed a processor that handled high def audio via bitstream. The D2 can take LPCM but my Dune Smart D1 couldn't convert to LPCM properly (and getting a reliable media server that can handle mkv's is harded to find than a good processor). The D2 only handled 5.1 LPCM too. Finally, I got tired of the HDMI handshaking problems with the D2.
I had considered getting a D2v but its price had gone significantly higher than what the D2 was when I bought it 6+ years. Anthem had a great upgrade program from the D2 but sadly cancelled it by the time I wanted to upgrade.
Anyway, the AV8801 has some nice features over the D2v such as TCP support. Only complaint is that Marantz support doesn't respond to online questions (but when I called them I got my answer, which was to get the RS232 and discrete Ir codes. Haven't heard back from them re Xantech Ir to AV8801 remote control issues though. Anthem has great suppor and is very responsivet. But hopefully I won't be needing much support for the AV8801 in the long run.
I haven't done any critical music listening to compare the D2 and AV8801. In recent years I've only used my system for movies. Just haven't had time to sit down and try to compare their musicality. But so far I like what I've heard from the AV8801.
Edited by randman - 1/13/13 at 1:13pm
post #1813 of 11289
Talk to Robert at Value Electronics.
Edited by discodol - 1/13/13 at 1:17pm
post #1814 of 11289
My unit has only passed the network diagnostics twice and will not stay connected solidly enough to check for firmware updates. It will however let my Oppo perform all of its network functions when plugged into one of the 8801's ports??
post #1815 of 11289
post #1816 of 11289
Originally Posted by GetGray View Post
+1 for Scott!
post #1817 of 11289
This is my 1st marantz unit. To those of you with previous experience, how are they with firmware updates?
post #1818 of 11289
Here's a new problem with the Marantz I'm having, it's stuck on the screen no network configuration, on the Marantz display it say's Media server, i cant even turn it off by the power button on the unit itself nor the remote. Any suggestions before i try to unplug it? mad.gif
post #1819 of 11289
Unplugging the unit (ie. a soft reset) after first placing it in Standby does not result in any loss of settings and sometimes will cure some minor issues in the process so give it a try.
post #1820 of 11289
Can't even get it in stand by mode, I'm going to have to unplug it, will see if i loose my settings, anyone else having these issue's?
post #1821 of 11289
Originally Posted by mjljfloyd1 View Post
Talk to Steve at SoundVideo of Minnesota
Multiple excellent buying experiences with Steve... most highly recommended.
post #1822 of 11289
Looks like I maintaind all my settings by unplugging unint,that's a good thing....
post #1823 of 11289
Originally Posted by randman View Post
...when I called them I got my answer, which was to get the RS232 and discrete Ir codes....
Have you gotten RS232 codes to work?? Other posts in this thread suggested that most Marantz codes would work. I'm using the same codes I used for an AV8003 (there's code list on the Marantz site and most devices share the same codes however the 8801 is not included on the list). I only get one code to work - Power Off....
post #1824 of 11289
Is anyone else losing OSD periodically? Either a reboot of the Marantz or the source component brings it back...
post #1825 of 11289
No issues at all with mine so far
post #1826 of 11289
Thrang...just a wild guess do you have "video conversion" enabled...if not you may want to try and enable it. Are you losing it when you are say changing volume and a movie is playing.....or just OSD when say doing a set up.. ..also set the resolution for the same as your dvd palyer and see what happens.
post #1827 of 11289
Video conversions is enabled. Both the setup screen on osd overlays (volume, surround modes, info, etc.) disappear when it happens. I disabled native mode on my directv so it just outputs 1080 to see if it minimizes the issue.
I do have a lumagen video processor and darbeevision darblet on the output side of the 8801, though I don't imagine that's an issue.
post #1828 of 11289
I have waited for 3 years and have finally purchased and installed a system into my home. I have wired the entire top floor of my house with speakers and will be running speakers outside in the spring when its warmer. My multi zone system is controlled of course by the AV 8801. I am still figuring out even the most basic of operations (install was finished yesterday). I am wondering , Am I able to listen to my I pod in the main zone and also play on my PS3 in the main zone? And if so how? I'm fairly sure I can do this. Just not sure how
post #1829 of 11289
I think I discovered the issue with the multi zone power on, at least for my setup -
I use RoomieRemote, and they have both IP and IR devices for the 8801. However, the commands sets aren't mature, so not all commands work the identically, and I have both versions of the device in my setup. This is not an issue as you can pick and choose what you want to use from each "remote", and also select one to Power On for all activities.
It seems the IR version of the Power On command is actually sending a Power All Zones command. The IP version of the device seems to be properly sending the main zone power on only.
Let's see....
post #1830 of 11289
Is the top of the unit hot?
