Originally Posted by thrang
Audyssey can be tricky to get right - no one is "one and done"!
Head over to the Audyssey thread for more details, but make sure there is minimal ambient noise, probe facing the ceiling, ear level, recline seats if applicable (I like to put a blanket of the leather as well), clear line of site to all speakers, assure the mic is isolated from vibrations during the test, try the recommended testing pattern and spacing, etc...
Theres something I don't understand, you put planket on the leather, other I have head mention they removed the seats while using roomkorrektion. Should the messurements be taken as the room is when used?
If in your case you take away the soundreflections of the leather, shouldn't it been corrected with all the rooms faults?
I have now bought a stand for the mic, so I don't hold it myself anymore. But shouldt I be then sitting in the sitting posision, as I'm part of the room when I'm listening?
I have a leather reclainer. As some sound will reflect off the back and onto the floor, I should then be sitting in the normal listening posision to get the most accurat results?
need to have a quiet room, even turn HVAC off while its running.
, would'nt Audyssey compensate (or "over-compensate" in this case) for these kinds of random exterior noise transients (street noise, helicopters, etc.,...)? What I'm getting at here is I've noticed, while operating my living-room theater set-up (using a new Denon AVR w/Audyssey) in very close proximity of the front yard/sidewalk and busy street, there does exist an "average" ambient noise level externally. I've made maybe two different Audyssey measurements (8-position) since having this new set-up, both approx. between 09:00pm and 10:00pm (typical time frame we're usually watching movies). After watching many features now in the last few months, and tweaking settings (ie. Cinema EQ, Dynamic EQ, etc.,...) , I'm mostly impressed with overall surround performance, even while consiously aware of outside random noise transients.
