AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Marantz AV8801 Preamp/Processor Official Owner's thread
Marantz AV8801 Preamp/Processor Official Owner's thread - Page 87
post #2581 of 5769
Sorry, byt in the Harmony software, I am not seeing the above options;
When I go into the "Devices" tab, I select the "Settings" option for the AV Receiver, and I select "Adjust power settings", but my options are
*I want to leave this device on all the time
*I want to turn off this device when its not in use
*There are no power buttons on my current remote for my Marantz AV8801 AV Reveiver
Which do I need to select? The middle one; "I want to turn off this device..."?
post #2582 of 5769
I think I put there were no power buttons on my current remote. That way the input will power it on without the zones coming on....
I did it several weeks ago, but it hasn't been an issue since I did a little trial and error.
The only issue I'm currently having is no audio when starting a blu-ray on the oppo 103. This happened again last night with Flight. I need to swap HDMI cables and see if that has something to do with it. I always have audio with the other sources at startup. When I had no audio last night, I used the oppo Audio command to use one of the other formats (I think it was dolby digital) and the audio came through. Switched back to DTS HD-MA and still no audio. Turning the 8801 off (standby) and back on immediately resumes the lossless audio. Everytime. This doesn't happen every time...but its been a more than a handful.
Anyone else experiencing this? Its my last bug and then I can chill!
post #2583 of 5769
Yep I have a similar issue. Also with an Oppo (93 for me). But this never happened with the Integra 80.2. So the Marantz must have some handshaking issues.
post #2584 of 5769
I will try that.
I have an Oppo BDP93, I will see if I experience this as well.
Have you tried contacting Oppo?
post #2585 of 5769
Given that the issue never happened with an Integra 80.2 even once in a couple of years of ownership, I think the fault lies with the Marantz.
post #2586 of 5769
I will try that.
I did the Marantz FW update (although I probably did not need to), and fired up the system with the Harmony One.
It turned everything on, and theres no handshake issue with my Oppo 93. Zones 2, 3 and 4 appear to not power on.
When I power down the system, zones 2, 3 and 4 remain off, BUT, the 8801 stays on!
This will not work......
post #2587 of 5769
CP
If the Marantz turns it off then it has to be the Harmony one programming.
When I was reprogramming my Harmony One, it seems that I has to teach one of the commands from the Marantz remote.
Did it work right before the firmware update?
Did you have to rerun audyssey after the update?
post #2588 of 5769
Today I couldn't log in to the web interface of the AV8801. It displayed "installer locked". As I did a "save" of all my settings yesterday, I did a complete reset. Now I could get into the web interface again, and I tried a 'Load'. To my disappointment this didn't work. I get the following error: Load Not Completed. The version of config.dat is different. Please check your config.dat.
I don't understand how the version of the Config.dat can be different, as I did the save after the firmware upgrade.
Anyone any ideas?
post #2589 of 5769
I tried to 'load' a config.dat that I had just saved 10 min. ago. No luck! Now I get : Load Not Completed. Please retry again .
post #2590 of 5769
Originally Posted by markrubin View Post
the 8807 amp I got is S/N ...00072 made in China
it appears to be identical in overall size so I am hoping the Marantz rack kit for the 8801 will also work for the amp: will see tomorrow
Would be really interested in your thoughts on how the 8807 compares to the Emotiva.
post #2591 of 5769
I'm having handshake issues. Every so often, I'm losing all video (don't know about audio), but still can pull up the setup OSD, when I switch hdmi inputs, just not the status command OSD. I'm getting another 8801 to test. I will update my situation. The only thing that brings back output is unplugging then plugging it back in. Here are my HDMI sources;
CX7000ES MEGA CHANGER #1
CX7000ES MEGA CHANGER #2
PANASONIC 3D PLAYER
HTPC NVIDIA 4GB 680GTX
360
PS3
WII-U
Update #1:
Mv 2nd experimental 8801 will be here tomorrow. Gives me from Thursday till Monday to decide if this issue is firmware or what by having two on deck.
Edited by Geronimo.USMC - 2/6/13 at 6:48pm
post #2592 of 5769
Anyone any ideas?
I was getting this installer locked message. I noticed that I was trying to log in from my computer while my iPad was still logged in. Once I made sure both were logged out before trying again, it worked. Some time went by though after I logged out of both before trying to log in again, though, so that MAY not have been the cause or solution.
post #2593 of 5769
Originally Posted by JimP View Post
Did we ever find out what all the firmware update addresses????
post #2594 of 5769
Originally Posted by retate View Post
av8801 rack mount hardware .JPG 94k .JPG file av8801 rack mounted.JPG 152k .JPG file
I have attached images of the Marantz rack mount for the AV8801 and a picture of the AV8801 installed with the Marantz rack mount. The rack mount kit itself is the Marantz RMK8003AV. The side panels attach with 3 screws to each side of the AV8801, and the front piece attaches with to the two side panels with two screws on each end. I purchased the rack mount along with my AV8801 from Sound Video.
post #2595 of 5769
MM8077 amp interesting thermal design
this amp has two large heat sinks 4 inch diameter mounted in series horizontally behind the front panel: there are 3 fans: one in the center and one on each end: the air is pushed out the right side when the fans run...you can hear a faint click when the fans kick in: hours after turn on in a 70f equipment closet
at low loads, the fans do not run and the heat sink is convection cooled: the top gets warm
very active thermal management: as a track ends, you can hear the fans running...then they quickly shut off...it also modulates fan speed quite effectively: nice thermal management...
post #2596 of 5769
Well, I may have an issue with my new AV8801. mad.gif Then again, being a "separates noob," it could be me. wink.gif
After hooking up the AV8801/MM8803 and just my speakers and FM antenna, I turned everything on. I had a loud hum coming from my subwoofer.
After trying some suggestions that I found online--trying a new sub cable, different AC outlets, etc., and the problem not going away---I finally have everything unplugged but the AV8801 and the sub, with one HDMI cable from the AV8801 to the TV for the setup menu and one sub cable (RCA) from the sub to the AV8801. The MM8803 is unplugged and totally out of the loop.
When I then turn the AV8801 on and then the sub, the hum from the sub comes up right away. Funny thing--if I unplug the HDMI cable from the AV8801 to the TV, the hum in the sub goes away. Wonder what's with that? rolleyes.gif
I then tried the same setup with my old AVR4311--cable to sub from the AVR4311 and HDMI cable from the TV to the monitor out on the AV4311. No hum. Whisper quiet from the sub.
Am I looking at getting a replacement AV8801? Any other things I could look at?
Also, the Setup menu sometimes does not want to come up on the TV. I did a reset of the AV8801 and it came back but sometimes after that it's darn near impossible to bring it back up.
post #2597 of 5769
Marantz' web site says: "Rack Mount Kit for AV8003, AV7005 and SR7005". It doesn't mention the AV8801. But it fits perfectly?
post #2598 of 5769
None of your inputs have "deep color" switched on? (as mentioned here)
post #2599 of 5769
It your TV is connected to a cable box.
Try disconnecting the cable and see if that helps.
You could also try connecting the ground on the 8801 to the wall socket screw to ground it.
- Rich
post #2600 of 5769
Seems like the 8801 still have a lot of problems. Is it still worth $3k?
post #2601 of 5769
Every new unit will have issues, but D&M seems to be on top of the major issues. None of the issues so far can't be resolved by a firmware update so my answer would be 'yes'
post #2602 of 5769
My March 2013 issue of Stereophile Magazine with the review of the Marantz AV 8801 by Kal Rubinson arrived today. Part of his closing paragraph: "Overall, the Marantz AV 8801 is the best-sounding preamplifier-processor I have heard at or below its price."
post #2603 of 5769
Anyone any ideas?
Saving & loading work for me actually. Mine is 726KB large. Check the size. I would hate to lose a perfectly good xt32 8pt measurement as well...
Edited by Geronimo.USMC - 2/6/13 at 6:55pm
post #2604 of 5769
I agree it's the best I've heard in it's price range. No question about it. Although some have compared it to the Onkyo/Integra and Denon and claim it's close but I haven't compared myself.
post #2605 of 5769
I would agree with my colleague on this statement. Hopefully my review will be fast tracked to the web.
post #2606 of 5769
CP
I did not rerun Audessy. I am guessing the power issue it is because I selected something like "no power button", or whatever it was described above on this page.
post #2607 of 5769
I think I remember now what I did. Teach the harmony the on and off buttons....for power on do something meaningless like "enter", then when it selects the input it will power on without the zones. Then for power off just use the regular power toggle button on the remote. Sorry about the misinformation before.
post #2608 of 5769
Yes it fits perfectly. The correct rack mount kit for the AV8801 was verified with Marantz prior to my order.
post #2609 of 5769
I'm a Harmony newb and I just picked up a Harmony 900. I've got an activity called "Watch a Movie" which selects the Blu-ray input and uses HDMI audio. Can anyone help me program it so when I run an activity I call "Listen to BDP", it selects the Blu-ray input, but switches the audio to the Analog inputs so I can use the DACs in my Oppo BDP-105? I've seen codes for this kind of thing, but I have no idea what to do with them!
post #2610 of 5769
Originally Posted by leefarber View Post
I'm a Harmony newb and I just picked up a harmony 900. I've got an activity called "Watch a Movie" which selects the Blu-ray input and uses HDMI audio. Can anyone help me program it so when I run an activity I call "Listen to BDP", it selects the Blu-ray input, but switches the audio to the Analog inputs so I can use the DACs in my Oppo BDP-105? I've seen codes for this kind of thing, but I have no idea what to do with them!
Well, you could make an activity called listen to BDP , switching to an input such as CD, assigning the correct analog input to it, cycle "input mode" till It says analog. It should remember the input mode. Try that. Or you could just teach the harmony the "input mode" command from another marantz AV/AVR and cycle through while in "watch a movie", to achieve what you want. I hope I'm clear. It's late & I'm on my cell phone typing this.
Edited by Geronimo.USMC - 2/6/13 at 10:34pm
