LOL...I doubt she'll read it. She doesn't understand all the techno mumo jumbo.
I have always gone the DIY route for subwoofers as the value/$$ is not even in the same ballpark as commercial offerings. It would take probably 8-12 seaton submersive HP's to get what I have right now with my sealed DIY setup. Let's see what the cost difference is, hm, around $2000 all in for my build, and that doesn't even cover a single Seaton SubM, so there is that
I haven't read the whole article yet, but just from the science of sound standpoint, what I previously posted holds true to the differences between ported and sealed offerings. A ported speaker has a pretty steep rolloff at the port tuning frequency (24dB/octave) where the same driver sealed would have a 12dB/octave rolloff so depending on how you set the XO points for both, the response will either work seamlessly, or cause a big suckout in the response around the XO point. Other ways to combat this is to adjust the XO points of the speakers and the subs independently to see if you can find the best transition between the two.
It is basically a devil in disguise, but I for one love to look at my frequency response as I move speakers, adjust settings, and look at the overall final product of my tweaking efforts.
Interesting
How did you compare did someone else made the switch?
You are correct: line level attenuation is necessary and I have pointed this out in the past. Somehow, I often forget about hitting the attenuation limits, perhaps because I have never come up against this problem myself.
I will delete/correct my earlier post.
haha, it can also be done, but in ported and horned sub alignments, I don't suggest hoping that the AVR or Pre is going to be able to do it all by itself, it may take another piece of to assist
