AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Marantz AV8801 Preamp/Processor Official Owner's thread
Marantz AV8801 Preamp/Processor Official Owner's thread - Page 209
post #6241 of 11290
Originally Posted by Franin View Post
I did the update today and no issues with lip sync. I did use a different player last night the bd 93 but tonight I used the bd103.
I'm glad your issues are solved. In using the 93 do you notice any better audio or video quality with the 103?
post #6242 of 11290
post #6243 of 11290
My 8801 suddenly stopped triggering my amp ( Parasound Halo A 51) to turn on/off. (Yes, the cable is firmly plugged in on both ends and the switch on the amp is still in the proper position.) Has this happened to anyone else? Is there a quick fix? Thanks.
post #6244 of 11290
Hi
Originally Posted by Geronimo.USMC View Post
Why didn't D&M give the 8801 this:
* The INFO button on the remote now calls up a rich display of information including input/output speaker channels:
http://www.avsforum.com/t/1465528/the-official-2013-denon-e-series-x-series-avr-model-owners-thread-faq#post_23134184
I would even pay a nominal upgrade fee for that........
Hugo
post #6245 of 11290
I think Rich had the same problem with his triggers and had to send it in for repairs if I remember correctly.
I hope its not a new trend.
post #6246 of 11290
Is there a way to display what the video input of the signal coming in is (1080i, 480P)?
Also if you want the 8801 not to process the video at all and just let it pass thru is turning of the scaler in video settings all that is needed?
Edited by OzzieP - 6/17/13 at 4:53pm
post #6247 of 11290
I had Trigger 1 deliver low voltage. 9 volts instead of 12.
I sent it in and they replaced some parts.
Since then, I have added a 120 MM fan.
- Rich
post #6248 of 11290
There you go rich, your like Johnny on the spot!
What did the low voltage issue cause?
I assume not enough power to turn on or off the amps.
post #6249 of 11290
Trigger 1 would not turn on my amp.
They replaced the plug, a transistor, and some other parts.
Not much information is provided about the repairs.
- Rich
post #6250 of 11290
- Rich
Did yours ever work? Mine has been fine for the past few months that I've owned it until last night when it suddenly quit working.
post #6251 of 11290
It worked for three months.
- Rich
post #6252 of 11290
- Rich
Oh no that's no good. Has anyone had it longer than three months without any issues?
post #6253 of 11290
Ive had mine close to that long and I have been fine. Hoping that I won't be the next one though!!!
post #6254 of 11290
Originally Posted by beastaudio View Post
No no. Small suggestion, go into the Audio menu and change the volume readoff from absolute (0-100) to reference (-85dB to 0.0 or however it is labeled). That is how 9/10 guys on here are stating volume levels and is a good way to know how you are listening compared to others. The absolute scale is just what comes stock on the 8801. Once changed, setting the receiver at 0.0 would be "around" reference level. I have gotten in many a tiff with folks on here defining what "reference" is but as a general understanding, reference for movie watching is an average of around 85dB with 105dB peaks from your speakers, and 115dB peaks from your subs. Running Audyssey on the 8801 and then putting the unit at 0.0 usually equals this exact scenario, thus "reference" as most people understand it.
Ok, so now I am totally confused. I have 2 options only.
From 0 - 98, and -78.5 to -18.5.
What the heck, should it not be -78.5 to 0.0?
And if so, what is happening here?
Edited by cofn42 - 6/17/13 at 6:04pm
post #6255 of 11290
The first is 0-98 otherwise known as the "absolute" scale for those that simply want to see the volume number get higher as the volume level gets louder and see the volume number go lower as the volume level goes lower, while the "relative" scale is in "db" and relative to "reference" level or "0db" which goes from -78.5db to 0db and then increases to +18.5db.
Edited by jdsmoothie - 6/17/13 at 6:37pm
post #6256 of 11290
1. Information - Video (p. 148 OM)
2. Yes, set the "i/p Scaler" to OFF.
post #6257 of 11290
Look again and I think you will see that it is +18 not -18, so -78.5 to 18. In this case 0 on the master volume control will be for all practical purposes be called reference level. This is assuming you have calibrated the system.
post #6258 of 11290
Yes, but what I didn't understand (at first) is that you need to have the source already selected that you want to affect.
As each source can be tailored independently, and that's how its done (the manual isn't clear on this point I thought, or maybe I'm just a bit thick?).
So select 'Blu-ray' (or whatever) and then make your adjustments for that source.
Then if you want to affect other sources, select those in turn, and make setting adjustments for each of those, and so on...
post #6259 of 11290
I've been triggering my amplifier w/o incident since mid-February now (4 months).
(Knock on wood! eek.gif).
post #6260 of 11290
6 1/2 months and still triggers fine wink.gif
post #6261 of 11290
Strange thing just happened. I was watching a movie & all my zones turned on by themselves..... Weird......
post #6262 of 11290
Noticed the 8801 has Spotify & Pandora streaming, anyone know if Rhapsody will be added? Also is the HD radio a DAB/DAB+?
post #6263 of 11290
Did you hit the remote on accident or is it a gremlin!
post #6264 of 11290
Although a feature of earlier D&M models, Rhapsody was removed beginning with the 2012 models last year to include the 8801. AFAIK, the HD radio is not DAB compatible due to each using different frequency bands.
post #6265 of 11290
Kids with iPhones or iPads in the house perhaps?
post #6266 of 11290
Was it a licensing issue? Suppose I can use Airplay or switch to Spotify. Dab+ is allusive, keep missing out with car now with the processor.
post #6267 of 11290
I know this isn't the best area to ask but considering it is still in the end an 8801 issue, does anyone know if Android platform has developed an app that effectively mirrors what the Apple "remote" app does to control my Itunes library. It would have to be virtually identical to the Remote app with all the same functionality. Just wondering if one of you gents might know biggrin.gif
post #6268 of 11290
Thats what my problem was! I turn "ip scaler" to off only to find it on again. The reason it was a different source. No it makes sense.
post #6269 of 11290
Can you use a 3.5mm stereo mini cable as a trigger cable for the AV8801? One of my components requires a stereo cable, but the Marantz manual states that a mono cable should be used.
I'm currently using a mono cable, but yesterday in the middle of a television program, the component connected to the Marantz trigger shutoff. I thought switching to a stereo mini might help.
post #6270 of 11290
Stick with a mono-cable.
Try using Trigger 2 from the AV8801.
If that works, one of your triggers went down and you should contact Marantz support.
- Rich
