AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Marantz AV8801 Preamp/Processor Official Owner's thread
Marantz AV8801 Preamp/Processor Official Owner's thread - Page 29
post #841 of 11290
FYI, I just received a reply from Marantz about whether the 12V triggers could be configured for PULSE or CONSTANT/LEVEL. The answer is "NO", the 8801 will only output a CONSTANT signal. That's too bad for Proceed and a few other amp owners. Apparently CONSTANT is more common so this is probably not a problem for most people.
Also, there was a question earlier that I did not see an answer to--"is the OSD routed to the video when you bypass the internal video processing"? Does anyone know the answer?
And like everyone else, I am looking forward to reading all reactions from new owners with great antici.....
Thanks for your help.
post #842 of 11290
If it is like the AV7701 then no OSD is present when you turn off video prcoessing. If you press menu then the menu appears and the picture for the input you are watching disappears until you quit the main menu. On the plus sie it is quick to switch and lock with video processing disabled.
post #843 of 11290
Even though the receiver is constant 12V out (normal) you could add a one-shot circuit that would do a pulse. This would solve the issue and is easy to do. Just search ebay for a "pulse timer module". Problem solved. About $12 and nothing to build.
post #844 of 11290
Originally Posted by planetbrian777 View Post
Originally Posted by Rosano View Post
Well just ordered mine. Maybe one of the first ones in Montreal or in Canada for that matter. Expected at the end of the month or very early Jan. Coming from a Lex MC12HD. Its gonna be a long Christmas lol !
I too ordered one and my last pre/pro was a MC12B. I am trying the AV7701 with XLR connections, but I am getting noise out of all my speakers that is audible from 12 feet away. I sure do hope the 8801 will work better with my system. The MC12B was dead quiet because of the fully balanced XLR circuit I am sure.
If you've selected an input with no signal and you are hearing an audible hissing noise which isn't due to the equipment having different grounding, then you have a defective unit. You shouldn't be able to hear any noise unless the volume is up at max and your ear is almost against the speaker.
Edited to add: For example, I have an AV8003 pre/pro feeding an MM9000 5 channel amp with standard 6 ft RCA cables. It's silent.
Edited by Selden Ball - 12/12/12 at 1:36pm
post #845 of 11290
Disconnect all inputs and then test for noise. If it is present then you do not have a source-related issue.
post #846 of 11290
Cool, what shop in Montreal did you order it from and what was the price?... if I may ask. The Canadian Marantz website still doesn't list the Canadian MSRP.
post #847 of 11290
I was thinking I might have a defective unit. Thanks for your input.
post #848 of 11290
With all inputs disconnected, I still have the noise. It does not matter what the volume is either. When I turn off the preamp while leaving my amps on the noise goes away, so I know it is not my amps. I have even gone so far as to run everything off of a battery backup with nothing connected to wall power and I still get the noise.
post #849 of 11290
XLR's have higher gain than RCA's. (Has to do with how common mode rejection occurs.) Plus, early in the AV7005 thread, it was commonly noted that XLR's were noisier in general than RCAs. So you could try RCAs and go from there.
XLR's are sometimes only better if you have a large external source of noise. Otherwise, RCAs can be quieter.
post #850 of 11290
Originally Posted by scratch17 View Post
I spoke to my dealer yesterday. He expects delivery sometime shortly after 12/27 on the AV-8801. The MM-8807 will not arrive until late February He will 'lend' me an MM-7055 until my amp arrives. So I guess I will be able to judge SQ differences (if any) between the two amps.
Steven.
Late February for the MM8077? That's odd as Amazon is showing they have one left in stock
post #851 of 11290
Try one connection at a time with the amp before you rule out a wire or amp connection.
post #852 of 11290
If you have a cable set top box, disconnect it completely. In my case that was usually the cause of ground loop hum/noise.
You can buy ground loop isolators if that is the source.
post #853 of 11290
constant 12V out
or +12VDC
post #854 of 11290
post #855 of 11290
Originally Posted by joerod View Post
What a beautiful Christmas tree all a twinkle!!
Hope mine gets here in time for Santa to do his thing!!!!
Ho Ho Ho!
post #856 of 11290
I have a feeling the Marantz may stay in the rack for the next year or 2!!!!!
post #857 of 11290
Originally Posted by WestCoastD View Post
or +12VDC
Not to be confused with -12VDC, or pulsed 12V DC, etc, Constant 12V simply means it stays on, that assumes it is +12V:)
Edited by sfav - 12/12/12 at 11:12pm
post #858 of 11290
I had this problem once and it was a grounding issue. If I recall correctly I had some components grounded to other outlets. Connecting certain components to the same outlet helped. YMMV
post #859 of 11290
I hope sound stage comparisons are not going to be made with stacked receivers, particularly on an amp. In addition that Parasound is going to bake the Denon.
I hope "soundstage comparisons" won't be made, period. Gulp.
James
post #860 of 11290
I was just doing this for effect. But you are wrong about the Parasound. It has an Antec Component Cooler on top not to mention an eight mini fan block on its back end. Been like that for a year now with numerous Receivers on top and never once and a single issue. And that is after many long football marathons and movie nights. I also have Antec Component Coolers on top whichever Receiver/pre-pro is running. smile.gif
The entire backside of my rack is open to the back room of my basement. It is plenty cold back there so each component is well ventilated. Of course having those Antec Component Coolers help as well. I consider this belt and suspenders for ventilation protection.
What kind of component coolers do you use?
James
post #861 of 11290
James
Why?
post #862 of 11290
Crap, I forgot an anecdotal, subjective, and scientifically irreconcilable account contrasting such things between AVRs still holds veracity for a percentage.
Opps, carry on then. I for one think the Marantz will sound much more open, unveiled, and steer effects with a sliver of increased detail and velocity than the Denon. Totally worth the additional cost on those merits alone, but copper casing and a nuanced, but still markedly superior fit and finish will be icing on the proverbial cake.
oh, and it (the marantz) will have a less muddled midrange once it's hooked up to the Parasound with xlrs. Lowered noise floor, too.
It will all be indubitable. Or just an opinion that will still carry substantial weight, because that's what someone heard.
Go figure.
James
Edited by mastermaybe - 12/13/12 at 8:17am
post #863 of 11290
Originally Posted by thrang View Post
Why?[/quote
This says quite about about the quality of stereo music which is one of the main marketing points of the Marantz brand of processor, ability to sound better on music. My point is that if I were going to compare any sound quality differences of two high-end units I would not stack them inches apart This is not about cooling, noise isolation can play a big role at times which is important in high-end gear and testing units sandwiched on fans and amps is not a good baseline. Why not put a cable box on top as well with all it's noisy RF or a Sat box on top of a power conditioner? Trying to see the small but sometimes important differences in components is not always possible even the same room but I would at least have some basic base-line steps in the evaluation to isolate any potential installation compromises:)
post #864 of 11290
Go figure.
James
The copper (plated) components can be silly, there are more effective ways to do noise isolation in the design.
post #865 of 11290
@james...
post #866 of 11290
The Satellite box did cause a ground loop hum so I had the tech come out and he disconnected the green ground wire on their hardware outside of my house. That fixed that problem, but I still have the noise. Thanks for the heads up though.
Edited by planetbrian777 - 12/13/12 at 10:35am
post #867 of 11290
Why?[/quote
betcha a large amount that if you measured the output it wouldn't make a dimes worth of difference.... smile.gif
"noise isolation" is an even bigger boogeyman for audiophiles than (dare i say it out loud? ) jitter...
your "concerns" are unwarranted... but then again, your expectations are as well...
post #868 of 11290
Yes I did that and it did solve the biggest of ground loop hum issues that I had with the plasma tv. I initially had two ground loop hums and a noise issue. I have solved both ground loop issues, but I still have the noise issue. Thanks for the advice.
post #869 of 11290
Where's the beating a dead horse emoticon?
post #870 of 11290
Hello, does anyone know if this pre-amp has any flexibility with the Pre-out terminals? I looked in the owners manual and didn't see a way to assign the audio outputs for say bi-amping. Thank you.
