Hi to All,
I've collected a sizable number of quotes from Audyssey (aka Chris Kyriakakis) that I thought by this time would be interesting to be launched and shared via a separate thread for those interested in reading such Q&A's of this well known room correction system. Please regard this thread as a platform for quotes only, while kindly request everyone not to post comments. The sole purpose is to share as many quote as possible, meantime if you have your own collection, please do not only feel free to share them, but you are explicitely asked to do the same. As you will see, in-depth explanations will follow throughout the quotes that I hope will be both entertaining and educational at the same time. Should you have a desire to comment you are kindly requested to open a separate new thread for further discussions on any of the subjects quoted here.
By no way does this thread want to be competing with the Audyssey FAQ or the Audyssey setup guide, it's a light weighted thread, kinda casual one, yet hopefully it will be taken with your anticipation.
Remember, quotes only!!
Here's the kick off for today to be follow by many more:
Audyssey test signal
________________________________________
This question has come up in some emails I received recently and I thought I would post it here as well.
Q: How can Audyssey measure anything with these silly blips? Shouldn't they use sweeps like everyone else?
A: The silly blip you hear is actually a fast sweep. It starts at 10 Hz and runs out to 24 kHz, but it weighs the frequency sweep logarithmically. In other words, the lower octaves get more energy than the upper ones. Sound familiar? In fact, if you take the time domain test signal (it's called a log chirp) and transform it to the frequency domain you will get the exact same spectrum as full range pink noise.
During measurement, the initial chirp is approx. 75 dB SPL for a nominal listening distance and speaker sensitivity. The chirp repeats several times per speaker and this has the benefit of increasing the signal to noise ratio in the measurement.
Also, Audyssey listens to the background noise in between chirps. If it's above the required minimum then it repeats the sequence of chirps at a higher level to make sure it gets meaningful measurements.
__________________
Chris
(to be continued...)
Edited by mogorf - 10/1/12 at 2:51pm
__________________
Chris
