Hi, hope you can help to suggest improvements / changes to my plan. Looking to start my first DIY build on a fairly tight budget, and have (after reading and reading everything I can find) come up with this plan. Primary focus is music, but it’s going to be used for HT too. Big room with high (9ft) ceilings, open plan family room / kitchen / great room, probably around 1000 sq ft total.
Amp: Crown XLS 1000
Drivers: Dual opposed Infinity Reference 1262W 12”
Cab: Sealed, 3 ft^3
Any thoughts / problems or improvements with this set-up? I plan on mounting the Crown behind my TV and running the cables semi-hidden. It'll be used primarily for music, and the sub input will be from a Denon 1712 AVR.
Andrew
Amp: Crown XLS 1000
Cab: Sealed, 3 ft^3
Andrew
You can do these for ~$150/box
