Hello all I just ordered my first internal (extra storage HDD).
my Acer case has a removeable tray which all ready has a SATA cable and a 12V power cable attached to the backplan
should I just use this tray or should I just bolt the new HDD into the extra HDD slot in the HDD cage then steal the SATA cable from the tray mechcanism?
edit I believe this new HDD dos'nt come w/ bolts.
pros and cons of both installations is appreciated.
also any tips on installing this new HDD like will Windows 7 automaticalley install in and format it for me? if not I'm tinking it should be formatted NFTA?
Thanks STB
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136783&Tpk=22-136-783&nm_mc=EMC-GD100112&cm_mmc=EMC-GD100112-_-index-_-Item-_-22-136-783
Thanks STB
