AVS › AVS Forum › Audio › 2 Channel Audio › Will I Need A Phono Preamp?
post #1 of 9
Hello all,
I've decided to venture into vinyl and just bought a vintage Bang and Olufsen TX2 turntable. Do you guys think I'll need a preamp between my 2100 and TX2?
Enjoy the music!
Al
post #2 of 9
What's a 2100?
post #3 of 9
If it's the Parasound 2100 preamplifier you're referring to then no. You won't need a separate phono preamp.
post #4 of 9
The 2100 has a phono preamp, but not a very good one.
If you get the Musical Fidelity V-LPS preamp, the sound quality will be improved considerably.
post #5 of 9
I haven't heard that many negative comments about the 2100's phono preamp. Unless you have a particularly finicky MC cart it should suffice.
post #6 of 9
what basis do you have for your statement?
post #7 of 9
http://www.parasound.com/pdfs/review/2100-2250.pdf
"A phono stage based on the well-received Zphono preamp is included."
I found that the Zphono is indeed highly regarded:
http://www.stereophile.com/content/entry-level-15
"When the music emerged, I heard sinuous strings sweeping across a big, wide soundstage; percussive acoustic guitar churning from the left channel; eerily realistic tambourine coming from the right channel; bass and drums at the rear of the stage, presented in a way that was clear, powerful, and easy to follow; that surreal bowed saw wavering and warbling, sounding like a choir of weeping spirits; and, finally, the fragile, childlike voice singing "Time, all th' long red lines / that take control / of all th' smokelike streams / that flow into your dreams . . ."
Also:
http://www.soundandvisionmag.com/article/test-report-parasound-zphono-usb-phono-preamp
http://news.cnet.com/2300-13645_3-10011744-3.html
etc., etc.
A general comment. Building a fine MM RIAA phono preamp is pretty much a cookbook project. Excellent chips for the purpose such as the 5532 have been around for decades. Good discrete circuits for the purpose preceded that. A critical performance parameter is the accuracy of the equalization network, but that problem was solved with the publication of a well-known and widely applauded JAES article on the topic a few decades ago.
post #8 of 9
Not a Parasound dealer? ;-)
post #9 of 9
And probably payment for each time he mentions Mainly Foul products (amongst others) on forums.
