AVS › AVS Forum › Audio › Speakers › KEF LS50 Owners
KEF LS50 Owners - Page 7
post #181 of 652
Originally Posted by K Shep View Postyou obviously haven't listened to a pair of LS50s yet.
LS 50 are very good especially up close but when it comes to dynamics in a large room the 800Diamonds really shine leaving the LS50 in the dust.
Of course with the difference in price tag is something to be said!
post #182 of 652
No doubt. Those B&W's are a special speaker, it has been a few years since I sat in front of a pair. Apples and oranges, my comment was tongue and cheek.
I have a pair of speakers arriving today, although that is for another thread.
post #183 of 652
Originally Posted by K Shep View PostI have a pair of speakers arriving today, although that is for another thread.
What kind!
post #184 of 652
post #185 of 652
Interesting never heard of them
post #186 of 652
I saw there big brother at Rocky Mountain Audiofest, then saw the MMMini Two at the Calif Audio show in 2010 (below):
The following year the rep brought the Mini One's. I have become a monitor + sub enthusiast, these fit right in.
post #187 of 652
Contemplating replacing my Dynaudio BM5A MKIIs with a pair of LS50s and a Parasound A23. Preamp is a Benchmark DAC2 HGC and sources are AIFF files on iMac and vinyl via a Pro-Ject Carbon w/ SpeedBox, Acryl-It platter and 2M Blue cartridge. Room is 10'W x 11.5'L x 9'H. I have DIY soffit traps all the way around the room along with Superchunks in the front corners. Music is rock from all decades and jazz on vinyl from the 50s-60s. They'll be placed on stands out into the room and listened to nearfield.
Thoughts?
The room:
Bill
post #188 of 652
Originally Posted by sdg4vfx View Post
There are several comments about some common AVR's not working well with the LS-50.
The only solutions presented so far are 2-channel amps.
Can anyone recommend a 5.1 (or 7.1) AVR solution that would work well with LS-50s in HT setup?
Absolutely nothing wrong with an outboard amp and an AVR. The dacs, eq, crossover, bass management etc. Are usually very good. I have a Demon AvR 100 driving a Van Alstine U70 tube amp, divine.
post #189 of 652
Can someone suggest how I can intergrate a 2 channel amp for my system. How would you suggest I hook up my system? Currently I have my LG 9600 hooked into my Marantz SR7005 via HDMI. I have my Squeezebox touch Hooked into my AVR(streaming from my Mac). via analog. I have my Fios box into my AVR and my Apple TV hooked into my AVR( both HDMI).I also have a Adcom GFA 555 hooked into my zone 2 on my AVR to power my outside, dining room,kitchen and living room( via Adcom speaker selector). Any suggestion would be greatly appreciated.
post #190 of 652
You have pre-outs for the front 2 channels (all channels in fact). Interconnects from front left and right pre outs to the amp of your choice. Let the set up calibration match the levels.
post #191 of 652
Sorry I'm exactly sure what you mean? I guess I'm wondering if I'm better off using my Adcom for two channel with my LS50 then somehow/also use the with my marantz for TV and other multichannel uses?
post #192 of 652
What I mean is that generally the amplifier sections of most home theater receivers are the weakest link. Your adcom may wind up being a better match for the LS-50s, will certainly drive a lot more current. it is a somewhat old amp though. In my case I have a Denon AVR100A receiver and use a Van Alstine U70 tube amp to drive my front speakers. You won't need necessarily tons of power, just quality amplification. Likely you will also cross over the LS-50s at 80 hz or higher, relieving the amp and speakers of some of the heavy lifting in the bass region.
post #193 of 652
Thanks. Under that hookup, How will i be able to use my rear surrounds, center and sub? Run the marantz and the adcom at the same time? Will i be able to hook the speaker selector into Front A, which is currently used with my LS50's or front B(vacant). I currently have the crossover set @80(via audyessy). Should I go higher?
post #194 of 652
Simply hook up the amp to the front left and right pre-outs. Make sure the speakers are connected to the amp, not the receiver. smile.gif Audessy will do the rest. You will use the amps in the receiver for surrounds, center and sub will be via the sub out, right? Audessy will select the crossover but you can always put it where it sounds best. If you had stereo subs, or a pair, as I do you would be able to set the crossover higher without losing separation.
post #195 of 652
I think im staring to understand. I currently have the Adcom hooked into the "preout L/R" and the speaker selector hooked into the Adcom. So i can just leave the Adcom pluged into the marantz as is? Just change the F L/R into the Adcom? Any thoughts on the speaker selector? Into one of the fronts A/B? Thanks again for your patience.
post #196 of 652
Imagine a 11.4 with all KEF-LS50 and 4 SB13-Ultra that would make a great theater!
http://www.svsound.com/subwoofers/sealed-box/sb13-ultra#.UVnEacu9KSM
Or these!
http://www.rythmikaudio.com/F25.html
Edited by wse - 4/1/13 at 1:58pm
post #197 of 652
No speaker selector. I suppose you could use speaker B outputs from the Adcom to drive the other room and speaker A for the main fronts but the other room would be subject to crossover and EQ. You could always defeat that. The idea here would be for you to be able to use an amp that would be a good match for the LS-50. I am not sure that the Adcom would be that amp.
post #198 of 652
Do you think the KEF LS-50 would be good surround to the B&W 800Diamonds !
post #199 of 652
I am sure they will sound good but can they provide the output to keep up?
post #200 of 652
Don't you have diamonds for surrounds already?
post #201 of 652
Yes but I am selling them as I think they are overkill for surrounds
post #202 of 652
Do you run them all full range?
post #203 of 652
I crossover the surrounds at 80 HZ as they are driven by a single CA-5200 amp. The 800D in the front I cross over at 40 HZ for movies
post #204 of 652
Tell you what, ill buy you the LS50s for the surrounds you'll replace them with and you can just give me your old speakers. That way, I'm the only one that spent any money, you get new surround speakers and you get rid of your old ones in one fail swoop!
post #205 of 652
Ok as long as you buy the Sonus Faber Elipsa SE in addition then we have a deal. That 's the reason why I would even think to sell the 802D surround
post #206 of 652
Well, now your just getting greedy. I don't think they would make good surrounds though wink.gif
post #207 of 652
Here are my new toys!
Don't mind the speaker stands. I am experimenting
with speaker height. Building custom stands to
bring the left and right speakers out 6-10 inches into the room.
The LS50 works better than expected as a center.
Because it is semi enclosed I am using both port plugs.
Had to buy 2 pair so I am left with an extra.
Anybody need one?
MG
post #208 of 652
How much are you asking for the 2nd speaker? PM me, I might be interested. I also have a decent sized room which is open to the kitchen. How does these sound midfield? My listen position would be about 12 feet away.
post #209 of 652
LS 50 are very good especially up close but when it comes to dynamics in a large room the 800Diamonds really shine leaving the LS50 in the dust. Of course with the difference in price tag is something to be said!
I sit 6 feet away from the surround speakers so the dynamics are fine, I will experiment this weekend and see how it sounds! Will let you know.
post #210 of 652
I went to Look and Listen in Mobile Al this afternoon and listened to the LS50s. Absolutely amazing, I know why they are nicknamed Mini Reference! wse, they should be very good as surrounds, I am trying to figure out how to use them as my SR and SL, wiring is my challenge.
Edited by jima4a - 4/12/13 at 8:07pm
  Back to Forum: Speakers
