AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players ›  Official OPPO BDP-103 Owner's Thread
Official OPPO BDP-103 Owner's Thread - Page 366
post #10951 of 16452
My 103 has the last FW update before this new one but when I check it stills says its the most current . How long before it will let me update FW via wireless Internet ?
post #10952 of 16452
The "new" one posted by neuromancer is a beta firmware. You have to install either by USB or by CD - no internet installations are available for beta firmwares.
post #10953 of 16452
Oh ok thanks I think I'll just wait until its available threw the Internet . I'm in no real rush other then liking to keep it up to date . Everything I use it for seems to be working good now anyway .
post #10954 of 16452
Just a quick note of appreciation to everyone who replied to my posts about Oblivion yesterday . . .
Disabled BD-Live functionality and that did the trick.
post #10955 of 16452
I generally find BD-Live pretty useless and always leave it off. Obviously helps with compatibility rolleyes.gif
post #10956 of 16452
I concur on the BD-Live . . .
I normally leave it off as well, but I'm assuming that it turned itself back on after a firmware update and "reset to factory defaults" deal. I'll definitely remember to turn it back off after this experience!
post #10957 of 16452
Originally Posted by Neuromancer View Post
3. Improved CUE file support. Now a CUE file can point to multiple music files located in the same folder.
Well, they're getting there. Slowly. Requiring all files to be in the same folder is still a huge restriction on this feature.
post #10958 of 16452
Would it work with hard links? I haven't tested that with cue files. See: Are hard links supported on NTFS volumes?
That was written for local storage NTFS volumes; we should also check SMB support for other file systems. It might depend on the server.
-Bill
post #10959 of 16452
How about posting your 'CUE file' observations within the dedicated Oppo BDP-103 & 105 and Cue Files topic
Edited by SeeMoreDigital - 8/13/13 at 8:50am
post #10960 of 16452
Nice additions to the new firmware beta. I just set up a NAS, so the timing is perfect. Sorting is working correctly now with SMB.
post #10961 of 16452
I'll assume this beta doesn't have a fix for the MKV 24p issue introduced in the last official firmware. OPPO told another poster that it would probably be 2-3 weeks, but then this beta firmware dropped shortly thereafter so I wondered if OPPO had an early surprise for us.
post #10962 of 16452
It does not. If it is not in the Release Notes, then it is likely that it is not resolved in the firmware. This is particularly true when things were broken in firmware. OPPO likes to point out when these kind of errors are resolved.
post #10963 of 16452
I don't think this is necessarily the case. There are issues they have resolved with firmware updates in the past that were never listed in the release notes.
post #10964 of 16452
For some reason, Plex is not super stable on the Oppo 103, in my experience. Lots of random "back to the top level" during navigation.
Also, it doesn't seem to like it when you browse too quickly.
Try another DNLA server. I'm using Asset UPnP for my audio (WHS2011) and it works infinitely better than Plex for a large music collection.
Thanks Bill for the information. I flipped the switch on the DLNA support on my Plex server last night and while that solves the sorting problem it isn't very stable (I assume that is most likely the fault of Plex). It would just be nice if I could do all of this directly sans DLNA, but I guess I will just wait it out.
post #10965 of 16452
Which version firmware do you have installed?
post #10966 of 16452
I have the latest Asset, and it has the same problem of popping back to the top level during navigation. This is an Oppo quirk, because Asset doesn't do this when I access it through my Denon AVR.
post #10967 of 16452
Anybody else having problems playing 24p mkv content after the latest update ? my display now only shows 1080p @ 60hz, i have forced 1080p 24p playback on my oppo and have de interlacing mode on film
post #10968 of 16452
Yup, go back a few pages and read all about it---the current "official" firmware (July 24, 2013) broke 24Hz network playback.
The public beta firmware just released (August 12, 2012) does not fix the issue although the screen info on the Oppo now displays the correct Hz for the media (again) but it is still output at 60Hz.
post #10969 of 16452
This is a HUGE problem for many customers, so it would not be something that they would want to just fix and sweep it under the rug. It is not in their interest to have people using a firmware which affects the performance of their player, so they will be forthright in informing the customer of the fix and encourage them to upgrade.
Smaller issues may be fixed and no listed, but something like a lack of 24Hz output from MKV containers is no a small issue.
post #10970 of 16452
Mkv 24hz playback is a biggie, at least for me, but Knowing oppo they should get it fixed soon
post #10971 of 16452
They indicated to a customer that they expected a fix within 2-3 weeks.
post #10972 of 16452
BDP10XEU-60-0808B for the OPPO BDP-103EU/105EU
post #10973 of 16452
Nice that it arrived so quickly after the US release. - I can confirm that the JVB Digital multi-region mod works as intended also after the upgrade.
post #10974 of 16452
After what I read about multi-region mod's I'm happy I, too, have that one.
post #10975 of 16452
I didnt upgrade my Oppo 103 since when they disabled ripped blu-ray movies play back. Any one have any work around to still use this feature with new firmware.
If yes, can you please provide me a step by step instructions.
Yhank you and greatly appreciate your help.
post #10976 of 16452
If you are running Windows, the fix was posted awhile back.
http://www.avsforum.com/t/1432162/official-oppo-bdp-103-owners-thread/9840#post_23448613
post #10977 of 16452
Awesome. Thank you so much.
post #10978 of 16452
Will a multiple-file CUE play back gapless, either from local USB or from networked SMB?
post #10979 of 16452
I knew they'd come through on this one!
All- I have no idea what this allows us to do now? Does this affect Playlist capabilities? Are we still just limited to one Playlist?
Thanks!!
post #10980 of 16452
I have been extremely happy with my JVB Digital all regions mod too. After I was serially defecated on by World-Import (as explained in earlier posts, it's an ugly story), I was scared to death when I added the JVB Digital to my 103. As it turned out, I had nothing to worry about. I have had my JVB Digital chip in my 103 for nearly four months and it has performed flawlessly so far.
