AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players ›  Official OPPO BDP-103 Owner's Thread
Official OPPO BDP-103 Owner's Thread - Page 383
post #11461 of 16358
Originally Posted by pbarach View Post
It's a nice feature, but it's not really unique to Oppo. Both of the players I replaced with the 103 (Samsung and Pioneer) had a Subtitle button.
Could they also adjust the positioning of the subtitles like the Oppo can?
post #11462 of 16358
^^Nope!
post #11463 of 16358
Originally Posted by amoergosum View Post
I was wondering >>> how customer-friendly is Oppo in regards to supporting older Blu-ray players? Especially with some new Blu-rays, firmware updates are essential. I'm asking since I recently had a bad experience with a Philips Blu-ray player. Philips stopped releasing firmware updates so quite a number of Blu-rays don't play. I'm never gonna purchase a Blu-ray player from Philips again. So for example; when I look at the Oppo support website for the BDP-83 I see that the latest official firmware was released on March 7, 2012. So I guess they stopped supporting it? Have there not been ANY issues with newly released Blu-rays?
Only issue with my 83SE is the length of time some of the newer releases take to load. For example, "Hitman" hung up when I first loaded it, the display said "stop", and remained that way for some time. I thought I had a defective disc or a dirty one, but after a long time it eventually loaded and played normally. All newer discs that did the same eventually played. I have not had a Blu-ray disc that has not played in my 83SE.
post #11464 of 16358
Did you turn off BD-Live?
post #11465 of 16358
Probably a silly question: if I rip a BluRay from my collection into a MKV file (using MakeMKV) and then play it from an external drive plugged into a USB on my Oppo, is that the same A/V quality as playing it from the BR disc?
post #11466 of 16358
Yes.
-Bill
post #11467 of 16358
Again, sorry for the 101-type questions:
ripping my collection and dumping onto a Buffalo Link station drive - that is connected to the Oppo via USB but connected to my network via ethernet - would be the best way to accomplish getting everything into one place and not losing any audio or video quality? Should I expect that the file would then just simply work (in terms of the pop-up menus) if I selected that file just as if I'd put the BR in the Oppo?
thanks again for the help
post #11468 of 16358
MKV copies of Blu-ray discs are single title. There is no menu. You can chapter skip and use the GOTO button, and the Subtitle and Audio buttons to select from available tracks.
Are you sure your device can be on ethernet and a USB mass storage device at the same time? A lot of these devices have USB for additional storage, but are not themselves accessible that way.
If the OPPO and the device are both on the network you can access the files from the player via its DLNA or SMB capability. You don't need a direct USB attachment.
-Bill
post #11469 of 16358
ok, that's the info I was looking for… I assumed there would be a loss of something in the mix, but wasn't clear what it was…
Also, thanks for the clarification about USBvNetwork… Yes, the Oppo would be on the same network so that probably is the better option.
Was just looking for a HT project and wondered if this was a viable option, but in no way am interested in losing a/v quality.
post #11470 of 16358
Any thoughts if we might be seeing a new version of the Oppo's at Cedia this year? smile.gif
post #11471 of 16358
Originally Posted by Ricoflashback View Post
.....I did experiment with a 9.1 (even 11.1) channel speaker setup but it was really overkill. I settled into 7.1 and haven't looked back.
Really I thought 9.1 and 11.1 really added sense of space?
post #11472 of 16358
Based on their past patterns of introducing new models, I would say no. New models are usually at least 2 years apart in my experience.
post #11473 of 16358
I was wondering if I could get some clarification from someone on this forum!
I have an Oppo 103 for music and movies using hdmi. How would I be able to use a different dac for 2 channel music only? I have a Cambridge DAC100 that is gathering dust and would like to try it out. Is coaxial or optical the better route to get the highest res possible? and would connecting it that way be the right way?
Thanks for the help.
post #11474 of 16358
I would just use the dacs in the oppo
i also have a very nice transport/ dac with a seperate power supply..(costing 4 times the oppos cost)..and for music,the oppo is right up there
very very close.....very nice sounding dacs in the oppo"s.
post #11475 of 16358
Barring a faulty cable, Optical Digital or Coax will be identical as far as output from the 103. Typically I would go for Optical, as it doesn't carry an electric signal and is thus one less path for shield-path interference to travel between devices. I wouldn't know if your DAC has a preference.
--Bob
post #11476 of 16358
--Bob
What does 'shield-path interference ' sound like or what are its effects. Is it ever audible?
post #11477 of 16358
In the settings menu what should I set the optical to so the player doesnt use its internal DAC? is there a raw option that I am missing?
thanks again
post #11478 of 16358
--Bob
Ground Loops (the most common form of such stuff) typically are heard as 60Hz power line interference hum. The interference current travels between devices on the cable shields of the cables connecting them. Since Optical cable has no electrical path -- not even a cable shield -- such current can't flow.
--Bob
post #11479 of 16358
Originally Posted by globalnomad View Post
For those on Windows using SMB and NTFS formatting, this may be a nice (temporary) work around for dealing with playlists.
The newest version of Foobar2000 has the built-in ability to copy files as Hard Links to a directory of your choosing. This doesn't duplicate the file, but rather links the target back to the original file, thus saving storage space. During this process, you can rename the link based on a pattern.
(Made some edits thanks to Flave)
  1. Load your playlist into Foobar.
  2. Select all items in the playlist, right-click, select File Operations-->Copy to... (If you have saved previous Copy operations the tree will be -->Copy-->...)
  3. In the copy dialog, select the "Link" radio button in the first row labeled "Operation type:"
  4. Select the directory you wish to copy the links to under "Destination Folder". I have created a structure like \Playlists\[PlaylistName]
  5. To insure your files stay in the playlist order prefix any naming pattern you choose with %list_index%. For example, to name my links by [Playlist Position]. [Artist] - [Title] (e.g. "01. Billy Joel - Piano Man"). I would use the following naming pattern: %list_index%. %artist% - %title%
  6. Make sure the "Copy entire source folder content" checkbox is unchecked.
  7. Click Run.
You will now have a folder containing links to the original files, renamed to include the playlist position at the front to insure your files appear in the folder in the same order as that of the playlist. You can set OPPO to default play-order to play the directory in the order of the playlist/folder, otherwise you can set it to Shuffle/Random to let it do its own thing.
Full details on how you can use naming patterns to rename your files when copying can be found here.
The latest version of Foobar2000 (1.2.4 as of this post) can be found here.
NOTE: Editing the files from the links will edit the original files! Deleting the links, however, will not touch the original data.
I hope this helps! Sorry for no screen caps.
So this appears to work very well. WIth that said, the links created imply that they are the same size as the source file.....I assume this is because it is reading the "spot" the file is in but has not made a copy of the file itself correct?
post #11480 of 16358
thanks again
The internal DAC in the OPPO is always "live" since the Analog outputs are always live, but if you are listening to DIGITAL audio output from the 103 then the internal DAC is not in the signal path. So HDMI Audio, or Optical/Coax S/PDIF Audio remains digital from content to output, and thus no Digital to Analog Converter in the signal path.
Perhaps you are confusing the DAC (Digital to Analog Converter), with the decoding that turns something like a TrueHD or DTS-HD MA Bitstream track from a Blu-ray disc into LPCM digital audio? If you want to avoid having the player do that decoding then set HDMI Audio Bitstream and Secondary Audio OFF. Your HDMI-capable AVR will need to be able to accept such high bit-rate Bitstream HDMI Audio input formats and do its own decoding of those.
--Bob
post #11481 of 16358
--Bob
Thanks, I never thought of coax as a possible source for ground loops, good to know.
Avoided optical as it was thought to be a poorer performer many years ago, I guess not an issue any more.
post #11482 of 16358
I've got a question I'm running my 103 threw my main HT gear via HDMI to my Integra 80.3 and then RCA out to my 2 ch setup NAD 356 bee preamp section to my halo A21 amp. Anyway when I play CDs or SACDs I don't have to fire up my display and Integra it just starts playing . But when I play my hi res downloads on my USB thumb drive I have to fire up my HT To navigate threw my kuros display to play it and of course that consists of my amps in my HT also . It seems not only its a waste when I just want my 2 ch setup playing but that splits the signal from the HDMI to my RCAs out of my Oppo . So does that take away from the sound quality ? I can't hear any difference it still sounds amazing but was just curious . I normally just turn off the display and HT amp and Integra after I navigate threw my kuros display to get it to play .But it just seems like a lot of extra wear on my HT firing it up Everytime and then turning off just to listen to my seperate 2 ch setup threw the RCA's on my Oppo . It seems it won't let me navigate threw the Oppos remote unless I have my display on . Is there a trick to it I'm missing ? I checked the owners manual and it just shows navigating on the Tv's display not on the Oppos display face .
post #11483 of 16358
Right, I simply connected the single cable to the Oppo's HDMI 1 output and all was well. kUH9
post #11484 of 16358
Correct, the links you made are just that - links. They refer back to the original file so when you view their properties it looks like the original file even though no additional space is consumed.
post #11485 of 16358
People get a small TV or monitor that accepts HDMI and run it instead of the main display.
post #11486 of 16358
I can see why , Thank you that's a great idea .
post #11487 of 16358
Originally Posted by aulola0001 View Post
Want it !
post #11488 of 16358
Chalk it up to my smaller man cave. Plus, there really isn't much material natively recorded in discrete 9.1 or 11.1 format that I know of.
You can use DTS-Neo and output 5.1 & 7.1 into 9.1 or 11.1 - - but it is "matrixed" as I understand it.
I ended up going with 7.1 and using a dedicated 7.1 amplifier (Wyred4Sound MMC-7) and it seems to work the best for my area, "sense of space" wise.
post #11489 of 16358
So I've been thinking about ordering an OPPO BDP-103 for quite a while now.
I'm looking for a solution to watch Region A & Region B Blu-rays so I either need >>>
a) one multi zone Blu-ray player
or
b) one region A Blu-ray player and one region B Blu-ray player
I'm from Germany by the way.
So of course it would be more convenient to purchase one multi zone Blu-ray player. On the other hand I heard that the Panasonic BDT-500 has better pq than the Oppo BDP-103. PQ is very important to me. I actually don't want an image processor like the Qdeo chip which alters the image. I read quite a bit about the softness of HDMI1 due to default noise reduction (Oppo BDP-103). What I want is an image which represents what the master looks like. I'm not looking for additional contrast boost, noise reduction etc. .
Oppo recommends using HDMI2 in that case...hmmmm.
I wonder how HDMI2 (Oppo) compares with the Panasonic BDT-500.
What would you recommend?
post #11490 of 16358
For Blu-Ray, no one has been able to demonstrate significant differences among Blu-Ray players, except for some of the dirt cheap no-name-brand players which are poor. For standard DVD, I think it is hard to beat the Oppos. I get great results with both NTSC and PAL material on my BDP-105 (which has the same video circuitry as the 103) via HDMI2. The Oppo also gives you a whole lot of file playing and disc playing options that just aren't there on the Panasonic. It all depends on where your needs and priorities are.
