AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players ›  Official OPPO BDP-103 Owner's Thread
Official OPPO BDP-103 Owner's Thread - Page 386
post #11551 of 16399
^ Yes, the design goal of the 105 is to produce better sound quality on the Analog audio outputs than the already excellent quality on the 103's Analog audio outputs.
The 105 also adds a Headphones jack, and additional types of Digital Audio Input connections compared to the 103.
Here's how OPPO themselves describe the differences:
http://www.oppodigital.com/KnowledgeBase.aspx?KBID=37
--Bob
post #11552 of 16399
KC-Technerd I tried all three inputs to the Samsung,Still get the same response.
The best thing for me to do is get a compatible AV Receiver to replace The Sony DB-830. I do have a place for it.
The Idea of a splitter requires to much of another trial and error that I don't fell like dealing with. The switch I have
coming out of the SC-07 HDMI-2 out is hooked to a cheap 24in HDTV that I use when I do not want to turn on the large TV, and a 26in HDTV that goes to the Kitchen.Only one of the two will work at one time and will work with or without the large TV that is hooked to the HDMI-1 OUT.
post #11553 of 16399
Originally Posted by kaffeen View Post
Can someone provide a brief synopsis of the advantages/disadvantages of using HDMI 1 versus HDMI 2? My understanding is the HDMI 1 uses the Marvel processor whereas HDMI 2 does not. Are there any situations where one is ideal and another is not. Any info appreciated! Thanks in advance.
De-interlacing and scaling are both performed by the MediaTek processor for both HDMI outputs. HDMI 1 adds additional post processing via a Marvell QDEO Kyoto G2H. See this document for more details on the QDEO processing: https://www.oppodigital.com/blu-ray-bdp-103/qdeo_extended_technology_brief.pdf
My understanding is that (in the order they appear in the brief):
HDMI 1 has an undefeatable base level of QDEO Noise Reduction applied. Additional QDEO noise reduction can be applied using the Noise Reduction setting under "Picture Adjustment" for HDMI 1. The base level is applied even when the "Noise Reduction" setting is at "0" or when "Source Direct" is used. (This is despite the statement in the owner's manual that noise reduction is turned off with the default level of 0.)
QDEO Format Conversion is not used in the Oppo BDP-103/105 (except for 4k upscaling). Format conversion is handled by the MediaTek processor for both HDMI 1 and HMDI 2. The MediaTek incorporates non-ringing scaling which is not true of the Marvell QDEO.
Adaptive Contrast Enhancement (ACE) is available by setting the "Contrast Enhancement" under "Picture Adjustment" for HDMI 1. None is applied when the setting is "0".
Intelligent Color Remapping (ICR) is available by setting the "Color Enhancement" under "Picture Adjustment" for HDMI 1. None is applied when the setting is "0".
Natural Depth Expansion: I'm uncertain how or if this is applied in the Oppo BDP-103/105. I believe this is likely incorporated into the "Sharpness" setting under "Picture Adjustment" for HDMI 1, with none being applied when the setting is "0".
Bit Resolution Expansion/Qdeo True Color Processing (QTC) is applied to HMDI 1 when the Deep Color setting for HMDI 1 is above 24 bit, even when using Source Direct.
Looking at the differences in the available Picture Adjustment setting (between HDMI 1 and 2) on pages 56-59 of the User Manual also gives some information on the differences between the HDMI outputs. Additionally, DSD can only be output on HDMI 2. The Marvell also provides 4k upscaling on HDMI 1.
Edited by KC-Technerd - 9/5/13 at 4:37pm
post #11554 of 16399
Originally Posted by RobDec View Post
thanks Rdgrimes
I guess my question is given that the 105 has better DACs and a better anolog board, will it give a considerable better sound than the 103s, on the analog end? I currently have the 83, but no 3D. Im not looking for better bells and whistles, just Audio quality.
Thanks again Rob
Analog audio quality is just as good as the weakest link in your analog chain, no better. So the answer to your question is: it depends. Depends on the speakers, the amp and any pre/pro hardware in the system. I'd qualify it this way: if your speakers cost less than the BDP-105, consider the 103 as a strong contender. Obviously a generalization but you get the point. FWIW, the 103 is a decent step up in analog quality from the 83.
post #11555 of 16399
thanks Bob
This is a tough decision. I do want to get the best sound, given the difference isn't subtle. . My setup consists of Krell Kav amps. Lexicon MC-8B, B&W Nautilus speakers and audioquest cable. Based on my setup do you think I should go for the 105?
Rob
post #11556 of 16399
I used to have a Sony STR-DB930 that is still in the family. It always had a peculiar dip right at the frequency of Glenn Frey's voice.
Hopefully having another HMDI receiver between the Oppo and the Samsung will isolate the Samsung from the Oppo so the Oppo doesn't set itself for the audio capabilities of the Samsung.
post #11557 of 16399
thanks Rdgrimes
I have been out of the loop since I purchased to 83. My other equipment has some years behind it. Looks like ill go for the 105. From what I hear the 105 wont be replaced til fourth quarter 2014.
Rob
post #11558 of 16399
Thanks again Rob
I think the biggest advantage of the 105 in audio quality is if you are connecting analog outputs of the 105 directly to power amps. Second option would be through a receiver (AVR) or preamp that is not re-digitizing the audio for processing. Even then, the reviews I've seen suggest the improvement in audio quality is real, but subtle (over the analog outputs on the 103). I don't think you're going to find anything near a night and day difference between the two. If you use HDMI (or S/PDIF) for audio to your receiver or preamp, then the DAC in the Oppo isn't being used anyway, so there would be no difference.
My AVR uses ES9016 Sabre32 Ultra DACs which are better than the DAC in the 103, but a step below the ES9018 Sabre32 DAC in the 105. There's lots of discussion to be found on which DACs are better, and how much of a difference they actually make vs. other factors such as DAC implementation.
Here's a few reviews that focus on the audio quality/capability of the 105:
http://hometheaterreview.com/oppo-bdp-105-universal-blu-ray-disc-player/?page=2
http://www.soundandvisionmag.com/article/review-oppo-bdp-105-universal-disc-player?page=0,1
http://news.cnet.com/8301-13645_3-57565878-47/oppo-bdp-105-not-your-average-blu-ray-player/
Edited by KC-Technerd - 9/5/13 at 5:23pm
post #11559 of 16399
Thanks KC-Technerd
I am using the analogs for SACD, DVD-A, Dolby True, and DTS HD MA. Im using optical and coax for the Lex processing.
If the difference is only subtle and using the second option, Im favoring the 103. Ill have to research the reviews you recommended.
Rob
post #11560 of 16399
Does anyone else see that Neuromancer's Post #1 has been mostly deleted? Or is it just some strange rendering on my browser?
Ken
post #11561 of 16399
Ken
It's the whole forum. Intermittent melt down today.
-Bill
post #11562 of 16399
Thanks KC-Technerd
Rob
Rob
I struggled with the decision between the 103 and 105 myself. Ultimately, I just couldn't justify the extra cost of the 105 unless I was going to use it as my preamp/processor directly output to power amps. I decided instead to put the money toward an AVR with good DACs, and a room correction system.
I believe your Lexicon has an analog bypass mode. Understand that only when you're using that mode would you really be hearing the ESS Sabre DAC in the 105. Otherwise the analog input from the Oppo is being re-digitized by an ADC in the Lexicon, and eventually converted back to analog by the Lexicon's DAC(s).
Brett
post #11563 of 16399
Thanks Brett
I read your recommended reviews and Ive decided to get the 103. If the audio difference is subtle I opt for the 103.
In my decision making process I also decided to save the $700.00 for a good processor.
Thanks to all who replied!
Rob
post #11564 of 16399
Ken
It's not your browser. AVS is having a stroke. This is happening to random posts in random threads. If you Quote or Edit the post the full text is still there, it just isn't being displayed correctly when you view the thread normally.
Bill has already alerted the AVS Forum Operations folks.
ETA: And just that fast, the problem with THAT particular post is fixed. But the problem may still be showing up elsewhere. If you see a post showing just a couple lines, then ending in an ellipsis (...), that's probably a post showing this problem.
--Bob
post #11565 of 16399
Guys, the moderators have been deleting posts that announce hacked firmware. Similar to discussing illegal movie downloads, my understanding is that it's against AVS policy to discuss hacked firmware on AVS, especially if said firmware enables (or re-enables) features that were removed at the request of entities such as the movie studios. It's probably best to discuss such things on another forum where there aren't such policies.
post #11566 of 16399
Please continue to report these posts. Asking for payment for "hacked" firmware is not allowed on this site.
S~
post #11567 of 16399
A reasonable policy.
post #11568 of 16399
Re the OPPO 105 as a "Pre Amp" or "Pre Processor" -
I tried connecting my Directv satellite receiver via HDMI to my OPPO 103 and ran into "HDCP" content protection problems with premium channels. Has anyone else experienced this?
Also - - the OPPO 105 only has one HDMI "in" - - so I assume that you'd need to have an HDMI switcher if you had more that one component that you wanted to connect in that mode.
post #11569 of 16399
I see two HDMI ins, just like the 103. One on the back and one on the front.
post #11570 of 16399
Ah, I missed the one in the front. But still - - that would look kind of messy running an HDMI cable from there. I would have designed it with two HDMI "in" connections on the back. That would really cover 90% of the HT setups - - satellite box & media player.
post #11571 of 16399
^ Not my favorite place to connect a permanent HDMI cable either.
post #11572 of 16399
This is a good policy that I personally fully support...
I also think it would be helpful if the moderating team announced such forum rule infractions within this topic (together with the members name) to deter others who might do the same wink.gif
post #11573 of 16399
Same here. I have a show or two I can't get via cable, I run HDMI from my Blackberry Playbook to the front of the 103 and stream the sows that way, it works great as a temporary connection.
post #11574 of 16399
Originally Posted by wmcclain View Post
Currently: no Cinavia detection on M2TS or MKV.
-Bill
Are you talking no Cinavia detection at all for MKV, or just over SMB? I have had MKV files played via USB where Cinavia did kick in and I got the popup and lost sound. The work around was to ReMux and remove the chapter references. Then it played fine with no interruption.
post #11575 of 16399
That's news to me. I'll run some tests.
-Bill
post #11576 of 16399
Which movies?
post #11577 of 16399
Who's running the new FW and there thoughts ? I usually upgrade mine wireless threw the Internet but this one looks only to be Avaiable via USB or a disc . I'm not having any issues with my 103 and works great for everything I use it for so not sure I want to upgrade .
post #11578 of 16399
The most recent firmware is 0808B, B for beta. You can use network firmware upgrade only for going from beta to beta, or from production to production. Else you need to use USB or disc.
-Bill
post #11579 of 16399
After he saw her on my 65" Sammy with the Darblet and all her facial imperfections - - he said and I quote - "I'm not in love anymore."
If it's anything like my experience with the Darblet it created not revealed them. At least it did the moment I applied it on top of the already contrast boosting processes via my display or HTPC.
post #11580 of 16399
You're correct. I'm getting cinavia detection and prevention on Total Recall (2012) in MKV.
I don't know when this first appeared. I'll check M2TS.
The studio noose tightens.
-Bill
