AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players ›  Official OPPO BDP-103 Owner's Thread
Official OPPO BDP-103 Owner's Thread - Page 457
post #13681 of 16400
OPPO Upscaling Question
I have a JVC DLA-X35 projector playing Blu-ray and DVDs from my OPPO 103 player.
When I play DVDs I'm highly dependent upon the excellent upscaling capabilities of the OPPO.
I also have a Bose V20 Lifestyle system that I use in conjunction with the projector and the OPPO.
My question is whether the Bose V20 up scaling capabilities are going to help or hinder the signal coming from the OPPO if I run the OPPO through the Bose instead of direct to the projector.
It would be nice to have the OPPO going to the Bose V20 first so I can use its switching capabilities for my various sources.
Any thoughts?
BH
post #13682 of 16400
That's more of a Bose question: what are the settings for video passthru without other processing?
I see a v20 thread, although it has not been active in a while: http://www.avsforum.com/t/939249/bose-v20
-Bill
post #13683 of 16400
I have a question concerning subtitles: I recently downloaded the entire Season 1 of "Borgen" (http://en.wikipedia.org/wiki/Borgen_(TV_series) for those unfamiliar). Each episode is a .mkv file. All the files are in a single folder on a 2TB Western Digital HDD connected to my 103 via USB to the front panel input.
The problem with this series is the subtitles. I play an episode, and once it begins I click the Subtitles button on the Oppo remote. The box pops up, I click down and select "English." Unfortunately, nothing happens.
Now, when playing the exact same .mkv file on my laptop using VLC Player, the subtitles display properly.
The Oppo has been amazing so far, playing all kinds of file formats via that external HDD. It's just strange that VLC will display the subtitles (thus proving they're definitely built into the .mkv file), but not my 103.
Any advice? Is this something I should check with the Oppo support people?
post #13684 of 16400
What is the format of the subtitles? Could you post the text output of the mediainfo utility when run on one of the mkv files? Or mkvinfo, if you have that?
(If these are pirated downloads: we are not supposed to help with that on AVSForum).
-Bill
post #13685 of 16400
Originally Posted by lrav View Post
We run into trouble though when we pause a Roku Netflix stream that is playing DD+ 5.1 audio. Sometimes when resuming playback after pausing, we have no audio any more. .
Simply pause or RW and start again.
post #13686 of 16400
Roger that, apologies to the board.
post #13687 of 16400
Speaking "abstractly" about general technical issues seems to be within bounds, though. Why certain subtitle types are not working, for example.
-Bill
post #13688 of 16400
Originally Posted by robcentola View Post
But if I have some sort of NAS I can push to the Oppo like I do with the files in my PC, right? I keep the lid closed and can control it with Gizmo with no sweat. I guess a DLNA NAS located remotely is the best solution. I was looking for a cheaper way......
I am going to assume here that you are not looking to continue using your PC for this purpose, in which case adding storage to the existing PC that runs JRiver would be the least-expensive and most functional option. In that case, yes, the next best thing, if you want to keep the TV turned off when listening to music, or you just want the benefit of a nice tablet/smartphone-based browsing interface, is to get a DLNA NAS.
Be forewarned, however - a DLNA NAS is not JRiver running on a PC. There are just all kinds of things that JRiver+Gizmo or JRiver+JRemote do better (faster, easier, more reliably) than any other combination of DLNA server and controller. The next best is probably Plex+its controller/player apps. But neither JRiver nor Plex is available in embedded form on a NAS - so those combinations are out.
As a result, you are going to get an embedded DLNA server and you are going to have to mate it with a general-purpose DLNA controller app - and this is where things get ugly. Some controllers and some players just don't get along. Some controllers and the Oppo don't like each other very much either. I would ask around in the Oppo DLNA thread (link below) for folks who use a NAS-based DLNA server and external controller so you can find a combination that works well in aggregate.
But, having been down this path myself - in literally multiple dozens (yes, I DO know what "literally" means) of DLNA server and controller combinations - nothing holds a candle to JRiver and its "sister" controller apps right now, for either functionality or reliability when used with the BDP-103.
http://www.avsforum.com/forum/newestpost/1215071
post #13689 of 16400
Originally Posted by boe View Post
Question on lip sync adjusting.
Hello,
I have an oppo 103 connected HDMI 1 to my DVD in on my AVP. From AVP to TV. I have the AVP HDMI 1.4 update module.
I'm noticing a lip sync issue on Avatar 3D but not Avatar 2D or streamed video.
Any suggestions? I apologize if this has been covered already. I tried adjusting audio dely from -80 all the way to plus 200 - I just couldn't seem to get it right. It takes FOREVER to get to a particular in Avatar the way I'm doing it. When I go to the oppo home screen - settings audio - lip sync - every time I want to get back to the scene where he's putting in the command center (ch 3 or 4) I have to play the preview/3d/setup/20th century fox, chapter chapter.... There has to be a better way.
I should mention that I have a 4K TV if that has any impact on audio delay.
post #13690 of 16400
It doesn't usually help. Pause/Resume was what got us into the trouble in the first place, after all. The most reliable "fix" is to unplug/replug the HDMI from the Roku to the BDP which is really disruptive to the viewing experience.
In continuing experiments (navigating out of the current movie, back to the Home menu, etc.) I am finding that the Roku player sometimes is locking up, so I am getting suspicious that the problem may all be at that end. I just don't have a way to test it in isolation. I have not found similar complaints (recently) on the Roku forums, and with Oppo supporting the Roku stick, I figured someone else around here might have run into this.
post #13691 of 16400
Update on my Youtube issue.
The key to this issue was OPPO/device was not activated as I suspected. The activation sequence never showed up for some odd reason. Played around with my Youtube account on the PC. Spent an hour analyzing everything on my account. Everything looked good and up to date. Did find a part about activate a device but wouldn't let me or save or anything but it seemed as though my legacy device/account was probably updated somehow while fooling around. Went back to the OPPO and the OPPO/device activation key finally showed up. All is well. Both OPPO's work the way I need them.
post #13692 of 16400
I do not see on the Oppo web site that the 103 supports Amazon Prime streaming. Will they support in the future?
post #13693 of 16400
OPPO has not had any luck getting Amazon to provide a native app. No way to know whether Amazon will become more cooperative down the road.
However, you can access Amazon Prime streaming *NOW* via a Channel on the ROKU Streaming Stick. See the OPPO Digital web site for discounted pricing on the Stick. Or if you already have a ROKU device you can connect it to one of the HDMI Inputs of the 103 if you'd like to have it passed through the 103.
--Bob
post #13694 of 16400
--Bob
Didn't want pay the extra $$'s for the app. Do the streaming services demand a licensing fee for their app?
post #13695 of 16400
Oddly not compatible with all android devices. No problem installing on my droid razr mqxx hd but wont install on my samsung note 8.0.
Annoying, since I use my tablet more than my phone for things like that.
Originally Posted by vinnie97 View Post
The Android media control app is out for BDP-10x players. I'm sure this has been announced somewhere but I couldn't find any announcements in the last 5 pages. Thanks, Oppo, for delivering it in 2013 after all. I can't wait to try it out (EDIT: I see it's been mentioned on page 1 as expected...didn't realize it had been available since Dec. 6th at the latest
post #13696 of 16400
Some streaming service (especially ones with the initials "A.P.") are really only interested in working with the largest of the large equipment providers. How they keep to that population I do not know - they could charge for licensing and then price it way out of anyone else's league, or they could just be uncooperative and not be willing to provide licenses and support to anyone who is not big enough.
You can see this for yourself. Go to this page and then look at the supported product list for "A.P.".
http://www.amazon.com/gp/video/ontv/devices
Looks like a lot of products, huh? Ok - then collapse it to manufacturers rather than products. How long is the list? Here is the complete list for Game Consoles, TVs, BD players, Set-top boxes, and Dedicated streamers:
Microsoft
Nintendo
Tivo
LG
Panasonic
Samsung
Sony
Vizio
Asus
Hisense
Netgear
Roku
...done...
See anyone missing besides Oppo? I do - LOTS - including some much bigger names than "Oppo".
That places the problem pretty squarely in Amazon's court, not Oppo's.
post #13697 of 16400
Contact OPPO. They can link you to a Beta APK that you can install on your Samsung which should resolve the incompatibility.
post #13698 of 16400
Microsoft
Nintendo
Tivo
LG
Panasonic
Samsung
Sony
Vizio
Asus
Hisense
Netgear
Roku
...done...
Too bad.
post #13699 of 16400
Does anyone know if there are any issues with the Oppo BDP-103 introducing shimmer to the video playback of MKV files? I don't usually watch a lot of mkv files so I've never noticed it before, but lately I've been backing up some Blu-rays and even though they are 1080p/24fps MKV files, there is literally a tonne of shimmer in the image when played back on my Oppo. If I try the files on my PC then there is no shimmer at all!
Is this just the player being a bit crap at mkv playback or could there be some sort of scaling issue? Usually I have my resolution output set to 1080p to upscale DVDs, but I tried switching to Source Direct and the shimmer issues were unchanged.
post #13700 of 16400
I do a bunch and have no quality issues. Are you compressing these?
Are the PC and OPPO both playing the files over a network, or both local, or...?
-Bill
post #13701 of 16400
Continuing Youtube saga,
I apologize for butting in as I have found my Youtube issue with multiple OPPOs/TV's.
1. Be sure you are on the correct Network (home) on your PC. I believe this was my main problem.
2. Once you can see the Youtube password on your OPPO, then Enter that into the Youtube box on your PC. Of course you need to be on the youtube.com/activate website to enter this code.
3. If you have an older Youtube account then be sure of your Account Settings and be sure to reset Youtube as your legacy settings (over 2 years old) will then be sure to include additional older OPPO's. Disregard all the other Youtube settings at this time as not yet needed.
5. Try again; it should work even with PC off
post #13702 of 16400
I have my cable DVR box connected into the Oppo 105 via HDMI-IN and now I see what people were talking about the video quality of TV broadcasts.
But I seem to have a problem where there is a muting in the audio output after a rewind/fast forward of the program material on my DVR. I'm not saying the audio/video are out of sync, its just that there's a 3-5 sec mute before audio is output. In the meantime, the video plays during this mute interval. Is this normal?
I have tried audio Bitstream or LPCM. Same behavior and I am on the latest official firmware (Dec 5th).
post #13703 of 16400
Prior to running your DVR (from TWC/LA? and what make/model of DVR do you have? Motorola infrastructure or SA/Cisco?) through your Oppo, when you rewind/FF did this audio muting NOT occur? Surely you never had audio when you were actually FF or REW, because all DVR's will mute during these control functions and only return audio back when the control function is finished. This typically occurs fairly quickly after the normal image once again appears on the screen, but it's not instantaneous.
So is the 3-5 second mute you're describing when now running through your 105 just somewhat longer than you're used to it being when running the DVR directly to your HDTV/AVR?? You're sure it's that long? No exaggeration?? Does it actually vary in duration?
post #13704 of 16400
I own my very own Moxi HD 3-Tuner DVR (TWC is my cable provider) and no, after the fast forward/reverse or skip video, the audio and video came on within a second or so when using my pre-pro(Anthem D2v). But with the Oppo processing in the loop, after a fast forward/reverse or skip the audio is muted closer to 3- 4 seconds while the video is playing. No exaggeration here... After wards, the audio comes back on and everything is fine.
Edited by dmusoke - 12/15/13 at 8:06pm
post #13705 of 16400
Should I be getting surround processing while watching a Netflix movie? Watching 007 Skyfall, it seems to only play through the front L&R speakers.... no sub output or any other surround speakers. Im hooked up with 7.1 analog for audio... Is there a setting Im missing?
post #13706 of 16400
This movie isn't in 5.1 sound on Netflix. You can listen to the matrixed surround sound by switching your AVR to Dolby ProLogic. Not as good as Dolby Digital, though...
post #13707 of 16400
Ya same here with the subtitle problem, I'll have to check and see what kind of subtitle file is being used when they don't work on the 103. They work on VLC but on the Oppo 103 I get the subtitle box and check English but none appear.
post #13708 of 16400
Yea, I saw that when it said Super HD it wouldnt play through the surrounds. When a movie says 5.1 its better though still not playing through the surround rear speakers.... same with when playing a DVD (non blu ray).... the rear surrounds dont produce sound. I did the test tone and set up and theyre all working. Will I only get the rear surrounds during blu ray play back?
post #13709 of 16400
Anyone else having problems with Plex Media Server?
Whenever I try to access my Plex Media Server through the oppo 103, the oppo freezes and requires a reboot. I get passed the first few levels, but when it gets to my folder with 500+ movies, it just freezes. I let it sit for about 5 mins before I decided it was frozen.
When accessing the same content through my windows shares on the oppo, it has no problem and finds all the movies in seconds.
post #13710 of 16400
Netflix "Super HD" is for the video. 5.1 is the audio.
