AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players ›  Official OPPO BDP-103 Owner's Thread
Official OPPO BDP-103 Owner's Thread - Page 484
post #14491 of 16418
Hi,
I was wondering if anyone else is having a problem with the beta update. I tried formatting my Cruze USB drive to Fat and then Fat 32. I downloaded the file off the Oppo sight. Made sure I had the right file name and it was in the root directory. I tired the USB drive in the front port and back port. The player shows that the USB drive was in the player but I can't get the player to find the firmware. I even went into Setup and device but the upgrade selection was grayed out. Not sure what the issue might be. Any help is appreciated.
post #14492 of 16418
^ Make sure you don't have a disc loaded in the tray, and that you are not playing other content (e.g., a media file).
--Bob
post #14493 of 16418
I installed OShare on my PC and the oppo recognized it. I was able to view movie and picture files without any issues from the oppo.
post #14494 of 16418
Bob,
Doesn't the USB stick need to be formatted in NTFS?
post #14495 of 16418
Originally Posted by HomeGuy View Post
Hi,
Also verify the player is mounting the USB stick properly. Put some media files on the stick and verify the player can see them when you select the appropriate Photo/Music/Movie icon from the Home Screen.
Originally Posted by Mongo171 View Post
Bob,
No, that would be weird.
-Bill
post #14496 of 16418
My bad. Just checked my stick and it is FAT. Sorry for the bad info.frown.gif
post #14497 of 16418
I just meant that such a requirement would be strange, as FAT is universally used for this type of work.
NTFS does work on a USB stick for media file storage, but I haven't tried firmware update. It might work. Oops, OPPO's update instructions: The USB drive must be in FAT or FAT32 format, not NTFS.
You can Backup & Restore Settings from an NTFS stick.
-Bill
Edited by wmcclain - 1/23/14 at 5:05am
post #14498 of 16418
Hi,
Very stange but I was finally able to get the player to recognize the update. I guess there is a bit of an issue with this player reading my drive. After the update I set the player to split A/V and then ran an audio cable from the player to my processor. I ran HDMI 2 for audio and HDMI for video. I then tried SACD in DSD and it worked but I'm still not sure I'm splitting the signal after reading the manual. It works so I don't care and 99% of the time I will be using Analog. I'm curious with DSD is the processor doing the encoding?
I also have my directv, ps3 and Smart T.V. running into the processor and then out to the 103 and then out to the T.V. This allows me to process the video via Darbee. It does make a nice difference. I don't think it is anything you'd miss but it is nice to have. The biggest problem is that the signal is still pretty compresed from Directv.
The player is certainly well built and I like the functionality - it makes sense. I can also tell you it's a huge sound upgrade over my PS3 (fat) player. The only option I would like to see is a link to Amazon video. Are apps added at the discretion of Oppo?
Edited by HomeGuy - 1/23/14 at 9:51am
post #14499 of 16418
OPPO has said they are always pursuing new network partners. The problem is the big guys like Amazon don't have much time for a little company like OPPO. Understandably they go for the most viewers with as little effort as they can.
Amazon is available on the Roku Streaming Stick, which you can buy at a discount from OPPO.
-Bill
post #14500 of 16418
About once a month when I try going online with my computer, I cant access the internet. My 103 is hardwired to my router and as soon as i disconnect it, I can get on line. Then I reconnect the 103 and all is well for a while. Any ideas?
post #14501 of 16418
If your 103 is set for "Quick Start" mode it might be hanging your router somehow, since the network connection is live. Sounds like a router problem, if so then rebooting the router should also resolve it.
post #14502 of 16418
It is in "Quick Start". Any settings suggestions for the router maybe or take it out of Quick Start?
post #14503 of 16418
I think I might be missing a trick... Is there a quick way to navigate to the beginning of the 'Network' GUI (where the magnifying glass icon is)? I'm a bit fed up having to press the 'return' button multiple times!
Cheers all
post #14504 of 16418
Bob,
I thought it needed to be formatted as FAT-32. The manual covers this.
post #14505 of 16418
Its impossible to say, short of turning off QuickStart mode. I'd say there's some polling activity in the router that's hanging because the player doesn't respond, although it should. Looking for an excuse to buy a nice new router? If turning off QuickStart fixes it, or if rebooting the router fixes the hang, then its the router AFAIK. My best guess would be that the period of time passing between powering up the Oppo might be the key.
post #14506 of 16418
As a data point, I've found that placing any of the devices in my (rather complex) home network in 'Quick Start' mode eventually results in the devices misbehaving somehow wrt to network access. Consequently, I've stopped doing this. I have a large number of devices and computers on my network and this may have something to do with it. Just seems to work better if when not in use they aren't trying to connect (also reduces unnecessary network traffic). wink.gif
post #14507 of 16418
It's a new router (6 month old ) . When I reboot the 103 all is well. I'm going to take it out of quick start and see what happens. Thanks for the suggestions.
post #14508 of 16418
You might also try checking your DHCP and static address settings in the router, to make sure two devices aren't conflicting.
You could also try assigning the Oppo a static IP address outside the DHCP range. I have seen this type of issue occur before: A device gets a DHCP address, and then it goes into a 'soft' sleep. Then, its DHCP address expires, and another device on the network takes the same address. When the device wakes up, it simply uses its old address even though it is expired and doesn't try to get a new one. Then, with 2 devices trying to use the same address, neither can use the network until one of them is shut off. Giving the Oppo a static address outside the DCHP range would fix it if this is the issue.
post #14509 of 16418
Cheers all
HOME goes to the screen just above that.
-Bill
post #14510 of 16418
-Bill
I thought about that too - but "Home-Right-Right-Right-Right-Enter" is really no better than "Return-Return-Return-Return-..."
(Have I ever mentioned that I hate navigation using LURDS remotes?) wink.gif
post #14511 of 16418
Thanks for that, I'll give that a try too.
post #14512 of 16418
-Bill
Yes, in a way it does.
But it does not take you to the beginning of the 'Network' GUI (where the magnifying glass icon is). It only takes you to the last place you navigated too. Which could be many folders down...
post #14513 of 16418
You might want to give a DHCP reservation a try instead of a static IP address. It acts in the same way, but in this case it tells your DHCP server in the router which address to reserve only for your Oppo. This way the DHCP server knows that it should give the Oppo and only the Oppo that address.
post #14514 of 16418
I dont see DHCP reservation in my router. It's an ASUS RT-AC66R. How would I go about trying that?
post #14515 of 16418
I think I found it...assigned it just for the Oppo .Well see what happens. Thank.
post #14516 of 16418
But "Home-Left-Left-Enter" (I think that's the correct number of lefts, I'm not sitting in front of the player UI at the moment) might be biggrin.gif.
post #14517 of 16418
If you guys can hear a dull thudding sound. That's me banging my head against a brick wall wink.gif
By-the-way I'm just watching Blues Brothers on Blu-ray. I can't believe I first saw this at the movies in 1980 eek.gif
post #14518 of 16418
Let me save you all a bunch of trouble - the BLUE button.
post #14519 of 16418
Correct me if I'm wrong but this information does not seem to appear within the User Manual (v1.6) or Bills unofficial FAQ
Cheers and many thanks again
post #14520 of 16418
Never heard of it! I'll add it to the FAQ under "hidden features".
-Bill
