AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players ›  Official OPPO BDP-103 Owner's Thread
Official OPPO BDP-103 Owner's Thread - Page 490
post #14671 of 16400
Originally Posted by jlpowell84 View Post
Ok thanks. If audio will be improved I consider it a worthy upgrade.
There is no audio difference between the 103 and the 103D.
Just curious, is the better audio something that can be noticed by nearly 100% of people?
I doubt that 100% of any group can agree. Either OPPO would be better using their analog output than a PS3 digital output. At least that's what I've read here.
All the OPPO owners might be folks who have chosen the OPPO players over the PS3, or they have no interest in gaming in the first place. Many of them are very interested in audio, and there are detailed discussions about getting the most out of direct connections to amplifiers using the analog outputs.
Do an advanced search on user name in this thread for "Bob Pariseau" and you will get detailed information about audio and other issues. If you've read all the posts since your first question in this thread, then you've read at least one of Bob's posts. Click on his name and you will get a menu where one option is a list of all his posts listed by the most recent. I think he posted about audio in the 103D thread sometime today.
post #14672 of 16400
Windstream is coming tomorrow to upgrade me to a 12Mbps connection (yes, yes, this is KY) as well as a new phone line in the basement (right where the equipment is). Once the new router they install is in place, I'll have a wired connection to all my HT components smile.gif
I'll play with the Roku Stick and if it sucks, I'll just return it. Honestly, the YOUTUBE and VUDU on the PS3 don't look that bad to me, and the kids never complain.
The 103 had VUDU, Netflix, Pandora, and CinemaNow out of the box, and we have DishNetwork for other stuff so the Roku is not that big a deal for me. I guess I'll just use the 103 for the speed, 3D, multi format decoding, and video processing on non-BD source, and use source direct on BDs. I'm not sure how 2D->3D works, but I'll try it. I dont have a 4K device, so that part's irrelevant.
Freddy ..
post #14673 of 16400
Originally Posted by plissken99 View Post
I just got a few 3D files. They are top/bottom and the Oppo won't output them in 3D, it just comes out as top and bottom. Also it's set to force 3D output. I set the projectors 3D type to top/bottom which did nothing. Any ideas?
Oppo does not guarantee support for any such "user generated" media files. But typically you would leave the video alone in the player and force the display to switch to T-B 3D playback. The player does not convert SBS or T-B 3D to frame packed output. Anyhow if your TV cannot display 3D images from the files, it either an issue with the files or with the TV.
post #14674 of 16400
My new OPPO 103 will arrive next week. I have a few questions. I'm upgrading to the Sony VPL- HW55ES, while my sound system will remain the same. I will run HDMI directly from the OPPO to the PJ, and route the audio to my Rotel 1066 PrePro. It doesn't have HDMI in. It has Analog 7.1 in, they call it Multi Input, which will accept the Analog Out from the OPPO. It also has several other inputs for audio, for my turntable, etc. It has 7.1 Pre Out, also, so I think it will just pass through the audio signal from the OPPO without further processing. That means the OPPO will do all the audio and all the video processing, which sounds okay to me. Is that right, or do I need to change out the Rotel? Also, I have a wireless set top box for Direct TV, which I'll run into the OPPO. I assume it's easy to select which signal the OPPO outputs, the Direct TV vs the disc? Thanks for the help, this is fairly new to me.
post #14675 of 16400
Ok I will for sure and get familiarized with these units. So what is the conventional ways to hook these up? I see one can do away with an AVR but I don't want to give up Audyssey.
post #14676 of 16400
Got it working! I had the player set to auto on the resolution, I switched it to "source direct" and it worked like a charm!
post #14677 of 16400
I think people who want to keep Audyssey almost always us a single HDMI connection to their AVR, but there are examples where people do unique arrangements that I don't bother to follow. Bob's post are a treasure chest of information.
An OPPO is worth the effort even if it's just to decide to go are not. smile.gif
I just ran across this 103D review in the 103D thread.
Edited by htwaits - 1/30/14 at 12:41am
post #14678 of 16400
HDMI1 to your AVR, HDMI from your AVR to your TV. Your other sources can be connected either to the AVR or to the Oppo; either way, Audyssey will be availablec to all digital sources getting sent to your AVR.
post #14679 of 16400
The remote has an INPUT button which displays a popup list of the options.
The Setup menu also has Power On Input which can be set to Blu-ray or Last Input, the latter handy if you are commonly watching from some other input.
-Bill
post #14680 of 16400
Is it normal that mkv files (PAL DVDs, ripped by MakeMKV) are being displayed as 576p titles when the Oppo is set to "direct"?
post #14681 of 16400
Instead of 576i? Is MakeMKV set to "de-interlace" when ripping? My PAL discs are still boxed in storage, so I have yet to test them, but in theory they would output 576i in Source Direct, and I'm assuming a straight rip of a PAL disc would as well.
post #14682 of 16400
I think maybe the best way is to use a preamp/processor to receive audio input from the OPPO as well as other sources. Mine is an old Rotel. If you can find a PrePro with Audessey, you can feed the Analog in from the OPPO, then use the other inputs for other sources. I have a turntable as my only other audio source into the Rotel. The Rotel feeds an Adcom 100WPC amp in the equipment rack, which in turn powers the rear surrounds. The Rotel also feeds a Bryston 4B, via in-wall Canare interconnects to the screen wall. The Bryston powers the LF and RF Watt/Puppy V's. An in-wall IC feeds an M&K V125 powered sub, making my system 4.1. Weird, I know, but I want movie sound coming out of the WP's.
post #14683 of 16400
-Bill
Thanks, Bill, that's what I assumed. I've never owned a BDP that accepted inputs from other sources.
post #14684 of 16400
Well, I can't see 'de-interlace' option in MakeMKV. Is there supposed to be such option? Playing straight from a disc results in 576i as expected, when the player is set to 'source direct'.
post #14685 of 16400
Afraid I'm not familiar with MakeMKV. Maybe they call it "pull-down" or "interpolation"?
Glad to hear disc outputs 576i in Source Direct though.
post #14686 of 16400
I have investigated MakeMKV menus and there is nothing video-related. MakeMKV should not touch the video, it puts movie content into a different container only.
I am afraid this way the video is not deinterlaced by the Oppo, it just gets upscaled. Or am I wrong?
post #14687 of 16400
Whether the Oppo outputs an 'i' or 'p' signal should depend on how the PAL MPEG-2 video stream has been flagged. If you want to find out how the MPEG-2 stream has been flagged you can use an application called MediaInfo.
However, the MPEG-2 video stream on many PAL DVD movies have actually been encoded using 'progressive' frames but are flagged as 'interlaced' to conform with the DVD standard. Thankfully, such video streams can be 're-flagged' using an application called ReStream prior to muxing into the MKV container....
post #14688 of 16400
Thank you for the explanation. I will look into this further as I am actually re-ripping everything from the scratch - so now it is a good time to utilise this information. Thank you again.
post #14689 of 16400
Ok. So I can just buy an hdmi switch and connect all my sources to the Oppo direct and then output everything from the Oppo to the JVC with the existing HDMI cable and then use the second HDMI out on the Oppo to send the audio from EVERYTHING connected back to the AVR, or does it only output the bluray audio from the Oppo? Basically 5 devices go into the Oppo and the Oppo outputs to the JVC through 1 output and then all the audio from all 5 sources connected to the Oppo will go the the AVR through the second HMDI out put on the Oppo? Hope that made sense. LOL.
If I already have a darbee, could I put it directly after the hdmi switch and before it enters the Oppo? Would that give me the same effect as the built in darbee in the 103d? Any benefit with the built in darbee vs. the original one?
Finally, is it really worth it to do all this? Will I get a better picture from having the Oppo upscale to 4K vs. just sending a 1080p signal from my AVR and just using eshift 3 on the 1080p image? When you go into your info menu on the JVC, does it show the 3840 x 2160 res?
post #14690 of 16400
Which hardware region free mod do yo guys recommend? Seen them as cheap as 50.00. Does anyone know if the jailbreak firmware works without issue? and is there anyway to remove cinevia infection?
thanks
post #14691 of 16400
much appreciated all the input gents!
post #14692 of 16400
I would put it between the OPPO and the display.
Functionally they are the same. Folks in the Darblet thread sometimes report power-on and handshaking problems which don't happen with the -103D.
Which is that?
From discs? No.
From the player? No, but currently it is enforced only on files on optical media. Future rules may be different.
-Bill
post #14693 of 16400
The firmware is something I saw on ebay. Haven't really researched it myself. If you set the Oppo to 4K upscale, does the darbee still function? I was told the darbee does not process 4K signals, so wouldn't that be a waste of money if you have a 4K tv and upscale everything to 4K from the Oppo?
post #14694 of 16400
I just connected my brand new Oppo BDP-103 and tried to wirelessly connect with Netflix. The display indicated the connection failed and that I needed a "Network Adapter"
I know my wireless network signal is strong as I just returned a Samsung BDF-5900 that was connected wirelessly to my network just this morning.
I traded in the Samsung for the Oppo as I know it is a much higher quality product (and a heckuva lot more expensive). But I will say when i started up the Samsung for the very first time it prompted me immediately for my wireless network key etc and I was able to sign uo for and receive Netflix with two or three minutes.
So do I really need a separate "Network Adapter"?
Any ides to help me troubleshoot and get on line would be greatly appreciate. I use an Apple Airport Extreme router with an Airport Express upstairs as a signal booster.
post #14695 of 16400
That was answered in the other thread. Darbee is before 4k scaling.
-Bill
post #14696 of 16400
Try the BDP-103 thread: http://www.avsforum.com/t/1432162/official-oppo-bdp-103-owners-thread
The player comes with a USB wireless adapter and extension cable so you can position it as needed. Were those things not in the box? You have selected wireless in the Setup menu?
-Bill
post #14697 of 16400
The problem with connecting the OPPO directly to your display is that you won't be able to see on-screen menus for your AVR unless you also run HDMI from your AVR to the JVC. I will have that problem because my PrePro predates HDMI. I'll need to run Component to my Sony from the Rotel because that's the lowest res input in accepts. I won't need to access the Rotel OSD often, so won't run a component cable in wall.
post #14698 of 16400
-Bill
Thanks Bill, I guess it pays to look at all the contents of the box. Thanks for the heads-up, I'm good to go and already enjoying the Oppo. Thanks again!
post #14699 of 16400
Thoroughly enjoying the 103. Thanks again for the help here. Next upgrade: eye exam next week...
post #14700 of 16400
I'm trying to update the pro modchip in my 103AU using the fw update on Gattiweb's site but it won't read from the usb (sandisk). Can anyone who's done this let me know what stick worked for them? I don't want to have to go out and buy a bunch of usb sticks to find one that works!
