Originally Posted by JazzGuyy
I still think the problem is at least partially related to the additional DRM info that HBO and some other channels put in their signal. This may complicate the handshaking. The extra DRM was meant to prevent copying of
HBO and other channels' programs but who knows what it appears like to the Oppo.
Im not disputing that, its called HDCP and its common. The issue is, plenty of other devices handle that handshake OK. Something about the Directv DVR and Oppo arent getting along, its got nothing to do with premium channels and their policy, and its not something that should be an issue. Also, this DVR has handshake problems with AVR's too, and its documented. I think its a more Directv Hardware issue, than an HBO/Oppo issue, but I could be wrong.
Just has to be worked out, and hopefully Oppo can.
. As I read through this thread the discussion of streaming with all the computer "lingo" goes way over my head. I have fed my 103 a steady diet of SACDs and DVD-As for two days. I'm loving the 103 and have yet to setup the wireless connection. I hope I can figure it out
. I only ran a relatively quick test with a single Blu-ray ISO, but I was able to fast forward at max speed, skip chapters, and play a few minutes here and there with absolutely no issues. Performance of all of this seemed to be just as good as if I had put the original disc in the tray. I've only ripped 1 Blu-ray to ISO at this point as I've been debating about exactly what approach to take, so I can't do a lot of testing to see how the mounting solution works with a bunch of ISO's, but the initial result appears to be promising.
