AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players ›  Official OPPO BDP-103 Owner's Thread
Official OPPO BDP-103 Owner's Thread - Page 9
post #241 of 8986
What's the main problem with ISO mounted on Windows? Is it that folders are browseable, but nothing can load? And is it only with BDMV, or have other things been tried as well like an ISO with files?
If its BDMV only, I don't have a Blu-ray drive or ripping software - is there anywhere I can get a free .iso to play with?
post #242 of 8986
I recall that the AVS HD 709 calibration disc has both BDMV and AVCHD versions; it's DVD sized and free: http://www.avsforum.com/t/948496/avs-hd-709-blu-ray-mp4-calibration
Other file types (like mp3, jpg, etc) in ISO files should work if mounted, although there is less reason to store them that way than with DVD and BR.
-Bill
post #243 of 8986
Originally Posted by Saturn94 View Post
Thanks for the clarification.
So it wouldn't be any/much different than what I already have; playing music from my laptop computer wirelessly through my Logitech Squeezebox Touch. On hi rez music files quality suffers when streaming wirelessly hence my interest in using a USB drive wired directly to the playback device. The Touch does have a USB connection, but its so poorly implemented as to be pretty much useless.
Is there a chance Oppo will come out with an app that will do what I want?
Originally Posted by Bob Pariseau View Post
Keep a sharp eye on this thread as I expect people to be trying different playback control schemes soon. This Media Controller stuff really does open up a ton of new possibilities.
As for a new app from OPPO: Ask Again Later; The Future is Hazy
--Bob
Thanks. I will keep on eye on this thread to see what develops.
Meanwhile, I was looking through the manual to see how the 103 handles playing audio files (no pun intended wink.gif ) from a connected USB drive. It looks like I can see a list of songs by file structure, genre, artitst, or album. I don't see where I can add a song(s) to play after the current song(s) finish playing. Am I interpreting this correctly that I cannot add songs to play on the fly?
Edited by Saturn94 - 10/5/12 at 1:52pm
post #244 of 8986
I believe DVDFab HD Decrypter is free, but iso creation (Clone) is a paid feature. However, you can use something like ImgBurn to create an iso file from the resulting BDMV and CERTIFICATE directories.
post #245 of 8986
Originally Posted by wmcclain View Post
Another new topic for the FAQ: Is the player a Digital Media Renderer?
On this I only know what I read. I'll add any tips or gotchas posted here or mailed to me.
-Bill
Anyone try vmcMote yet?
I am going to try this shortly, but I thought I would ask for others opinions as well.
post #246 of 8986
Originally Posted by Welles1941 View Post
You may want to add to the FAQ that on Windows creating a directory junction also works.
I remember that BDMV folders enforce Cinavia, but do AVCHD folders? If not, this might be the preferred method, of junctioning a folder called "AVCHD" to the "BDMV" folder in the iso.
Someone with a Cinavia ISO may want to test this. If you junction the whole iso, is Cinavia enforced? And then if you just junction the BDMV folder to a folder named AVCHD in your share, is Cinavia triggered then?
post #247 of 8986
It's worth a try but you should get the same results on local storage. SMB doesn't provide any magic.
-Bill
post #248 of 8986
How do you access the content inside an ISO from local storage?
What I'm suggesting is:
Mount the ISO on Windows.
Junction the BDMV folder inside the ISO to a folder named AVCHD in your share.
Enjoy!
No change to your ISO when you're done.
The purpose is to keep your ISOs intact with no re-encoding, etc - just a method to play them.
post #249 of 8986
Enjoy!
You're trying to defeat Cinvavia, right? If AVCHD is a way to do that you can test it on local storage.
Handling it out of ISO on SMB is not relevant as far as I can see.
-Bill
post #250 of 8986
Originally Posted by kendo70433 View Post
A second bug. I started to play a Netflix Splice DVD. Went through all of the previews. At the disk menu I hit play. The -103 froze at 17 seconds of play. Play and stop didn't work. Eject didn't work. Power off took 3-4 tries at the front panel button. Power on resulted in an eject cycle. When I closed the tray, the -103 did not resume; it acted as though seeing the disk for the first time. The second time, the movie played fine.
~Ken
Originally Posted by Neuromancer View Post
The player will forget any changes that were made in a power cycle where the player freezes. This includes breakpoints for disc resume. This is normal.
Yes, I assumed the last bit was normal, though it was interesting the Eject command stayed queued up through a power cycle. I was mainly reporting the hard freeze in case some pattern emerges, since it wasn't immediately reproducible.
post #251 of 8986
FWIW, I just confirmed that by setting the player to Quick Start in the Device Setup menu it will be recognize by the Android application in a powered off state and allow you to turn it on. In the Energy Efficient mode (default) the Android app cannot find or power on the player.
Bottom line, in quick start mode the ethernet port remains active.
RS232 port is active in either power mode to accept a power on command.
-Ben
post #252 of 8986
^ Good catch! The Wifi dongle is also kept powered during Quick Start power off.
--Bob
post #253 of 8986
RS-232 and IR interface directly with the MCU, which is always one regardless of the energy mode.
Ethernet and Wireless are only engage when the processor is on and feeding power and logic to these interfaces. This only works with the Quick Start Mode.
MHL power is also available in the Quick Start Mode.
post #254 of 8986
I don't know specifically about HBO GO, but the Roku Streaming Stick is supposedly coming out this month and will add access to lots of different Internet services. It plugs into the Front HDMI Input and is controlled using the player's own remote. It has its own Wifi, independent of the networking of the OPPO. So you will need a Wifi setup to use it.
If you have another way to access the HBO content, try feeding the result of that into the Front or Rear HDMI Input.
--Bob
Roku streaming stick is now available from Roku site. 99 bucks.
post #255 of 8986
Thanks for clarifying!
BTW 9,999 posts, cool... I've been lurking for way to long.
post #256 of 8986
So after reading bobs amazing explanation of audio over in the 103/105 anticipation thread (I highly advise people to go read it. Page 49 and 50) it got me thinking to what I should do bit stream or LPCM.
I have a denon 2313ci and an Oppo 103. How would i go about choosing which one would be the better DAC? Should I have the Oppo do the LPCM and then send it to the denon? Or since I bought the denon for this reason, should I bit stream to the Denon and have the 2313ci do the decoding? How would be the best way to choose (besides trying both smile.gif )
Also I don't care for seconday audio so that's not a big deal. Also I am going to run dual HDMI. HDMI 1 to TV, HDMI 2 to the Avr.
Edited by Usarocker - 10/5/12 at 4:13pm
post #257 of 8986
Another good catch!
http://www.roku.com/streamingstick
--Bob
post #258 of 8986
Another good catch!
--Bob
Looking forward to the feedback Oppo 103 owners !
post #259 of 8986
So the Rimu stick will only work in the front HDMI port?
Which means I would have a 3 inch purple thing sticking out in the front of my nice blu-ray player?
Bummer
What is the big advantage of the stick over the regular Roku. I currently have the RokuXS HD hooked into my AVR
post #260 of 8986
Do you connect the Roku stick using the HDMI in the front of the player?
post #261 of 8986
Yes, the Roku stick has to go in the front. One of the two reasons I just bought an XS instead (the other being that it can only use wireless). An advantage of the stick is that is doesn't consume an HDMI port on your AVR, and (assuming you don't have a universal remote) it's one less remote to deal with.
post #262 of 8986
Nah, you could always throw the purple stick underneath:
http://www.amazon.com/Hdmi-Port-Saver-Cable-Inch/dp/B000Q6WEFW
post #263 of 8986
post #264 of 8986
I think this is for a regular hdmi input, not sure if the Roku stick can work with this.
post #265 of 8986
What's the word on Logitech 900 and the 103? I'm guessing the 93 codes work, but are there commands that I need to add to be harmony?
I think I might pick up a harmony touch this weekend to play with. Don't think I will like it over my 900 but something else to try.
post #266 of 8986
Originally Posted by x43x View Post
My unboxing and some hands on
http://www.youtube.com/watch?v=tzmDVRIbMac&feature=youtu.be
Nice video, pity you don't show the setup menu.
post #267 of 8986
Hmmm...I didn't think to add it merely because it can be gleamed from the manual. Maybe a separate video just for the set-up menu?
post #268 of 8986
I was just about to call Fed Ex and let them have it when my 103 showed up at 9:30 pm. I have never seen FedEx deliver so late. I have to get up at 2:30 am to give my friends a ride to the airport. Now i will get no sleep! The sacrifices we make for the hobby we love smile.gif
post #269 of 8986
Thanks for the news. One of the posts seemed to indicate that the Roku streaming stick might not work with HBO GO, so I will check with Roku tech support. It would be better if I could place it in one of the rear inputs, if the remote would still function, but this is a good start.
post #270 of 8986
Sincerely appreciate all those posting how to best stream content through the BDP-103. My 103 arrives tomorrow and I am confused (as the 'noob' I am). Have read this entire thread and much of the 'Anticipation' thread for the 103/105. Also watched the unboxing youtube link recently posted in this thread. And read data from the media streaming section of AVS Forum.
Understand that the BDP-103 inherently includes Cinvavia.
1. If I use a media server (like the Synology units) can I stream all media thru the BDP-103 or will Cinvavia interrupt the audio for Cinvavia protected audio/video content?
2. If using a BDP-93/95 (or earlier Oppo players - or other non-Cinvavia Blu-Ray players) would Cinvavia interrupt the audio for Cinvavia protected content?
3. Would it be wise to have a pre-Cinvavia Blu-Ray player (like the earlier OPPO units) in the house to substitute when Cinvavia Blu-Rays are to be viewed over the NAS? If so, what Blu-Ray players do youl recommend?
4. Other than a media server, is other equipment (Dune HD media players, Popcorn Hour media players, etc) needed to watch iso or mkv 'Blu-Ray' streamed content?
5. Does the (about to be released) Poporn A-400 or C-300 resolve anything substantial when streaming via the BDP-103?
6. Appears the Dune HD media players may be redundant to that provided by the BDP-103 or is this not a correct understanding?
This thread's networking discussion with the BDP-103 has been very helpful, although the biggest interest is how the BDP-103 performs under all possible uses, not just networking. Apologize for the uninformed questions. Am trying to learn how to best use this great new device! Thanks again.
