Originally Posted by
Bob Pariseau
I don't think you follow. Sure it has the "Input" button for the device. You can use that for manually selecting which Input to use on the 103.
But if you set up a new Activity on the Logitech which includes the 103, does it ask you which Input the 103 should be set to as part of entering that Activity?
I.e., can you set up an Activity which automatically changes the 103 to start using what's coming in on, say, the Front HDMI Input?
--Bob
If the Harmony software doesn't ask you to set the input on the 103 when setting up an activity (I doubt they have programmed that) you still have the ability to add startup commands manually to an activity.
From the Activities tab select Settings for the appropriate activity.
Select -Review the settings for this activity. Click Next
Select -Yes, but I want to add more control of options and devices for this Activity. Click Next
Click Save and Click Next until you get to the Custom Actions screen
On this screen you can add an "action" for any of the devices used in this activity - ie. send the Input command to the 103.
Click Save Click Next Click Done
It could get tricky if you don't have a discrete command for the each of the HDMI inputs & you need to know what input it was on last to figure out how many Input commands are needed to toggle through to the desired HDMI input.
