Originally Posted by oddmania
The Audyssey in AVR is switched on,and no I'll only use it for movie viewing only ( blu-ray's) nothing else.
But if the 105 enhances the AQ on my AVR when connected via analogue the why not go with it?but if it'll provide the same AQ if connected via analogue or HDMI as the 103,then save the cash and go with 103.
I know I'm repeating my self,since I'm from Kuwait and there's no oppo dealer in my country forums is my only reference.
So bare with and all help is appreciated.
The audio signal has to be converted from digital to analog somewhere in your system. When you use analog audio outs from the Oppo player, you are using the audio DACs in the Oppo. When you use HDMI output, you are using the audio DACs in the AVR. Which sounds better depends on which has the better DACs, the player or the receiver. The 105 has better audio DACs than the 103, and should sound better than both the 103 and your receiver. But it also depends on your other equipment (if you have cheap speakers and cheap AVR, then you won't hear the difference). If money is no object, I would go with the 105 since it absolutely has better audio DACs and should sound better. If you use HDMI for audio, then get the 103 since both players will sound the same since the AVR is converting the digital signal to analog, not the player. Hope this helps.
