AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players ›  Official OPPO BDP-103 Owner's Thread
Official OPPO BDP-103 Owner's Thread - Page 183
post #5461 of 9021
Originally Posted by Bob Pariseau View Post
There are two possibilities here. Either the AVR is not properly initializing the new digital audio stream processing or the HDMI handshake has left the processor confused as to what form of digital audio is coming in.
I recommend you try HDMI Audio LPCM instead of either Bitstream or Auto. AVRs that have problems initializing a newly started Bitstream will often not have problems when the digital audio input is LPCM.
I also recommend you try some experiments with lowering the bandwidth on the HDMI cable. This would include turning off Deep Color in the OPPO and temporarily trying a lower resolution (1080i or 720p -- don't go lower, as the high bit rate audio tracks can not be carried on HDMI when the video resolution is lower than 720p).
If the audio works without problems at 720p or 1080i, but still fails at 1080p (or 1080p plus Deep Color), than that is strong evidence of marginal cabling. Try upgrading your HDMI cables. Keep in mind that HDMI is an end to end protocol so the problem could be the HDMI cable on the OUTPUT side of the AVR. If you have any adapters, wall plates, daisy-chained cables, HDMI switches, or other gizmos in the HDMI path, they alone could be the cause of the problem. Also note that for HDMI, too *SHORT* of a cable can give just as much problem as too *LONG* of a cable. The sweet spot length for HDMI between any two devices is 6 feet (2 meters). So an 18 inch HDMI cable could very well cause problems, as non-intuitive as that must seem. This has to do with how the HDMI chips "equalize" the signal on the cable to try to make longer cables work more reliably.
--Bob
Thank you (as always!) Bob. I will give this a try and report back. FWIW, my PS3 Slim has always sent Bitstream and been set to Deep Color ON (or Auto? I forget but it is definitely not OFF) and sending full 1080P to the AVR all along, so I'll cross my fingers that a swell new HDMI cable will do the trick (mine are all 6 ft). Other than that, I may also try a different input on my AVR incase the current one is "finicky"?
One more question/This comment has me confused a bit:
In my situation, the AVR is not outputting anything over HDMI as I'm only SENDING audio signal TO it; the video is Oppo direct to my TV via HDMI 1?
B
post #5462 of 9021
^ That was just a boilerplate comment. If you have no HDMI output from the AVR then there's no cable to replace.
--Bob
post #5463 of 9021
Originally Posted by rickydenim View Post
I did some tests on the S&M disc and tried going from -15 sharpness on the Kuro back to -10 and leaving it at -15 and using the Oppo sharpness +1. What I found was that even when changing Kuro to -10 it wasn't as sharp as the Oppo and created halo's around the lines etc. Using the Oppo -1 created sharpness and more detailed lines and had no halos or errors. I could get the Kuro to -12 and Oppo sharpness +1 without any issues.
So adding more sharpness on the Kuro isn't the fix I'm afraid, they aren't doing the same thing.
Rats. Thanks for testing it out, though. I do remember now that halos can start to appear on test patterns fairly quickly if you push the sharpness on the Kuro.
(Haven't changed mine in a long time). That said, there were times when I checked the sharpness when I first got the set, and while there were technically
slight halos on the test pattern, I couldn't seem to see them in 'real world' viewing.
But I bet I would see the same results you did.. To get the slight softness out of the picture might take a real push on the Kuro, and then you'd be
ending up with a processed image once again, but with an older, less sophisticated processor. At lest the Oppo at +1 keeps the artifacts to a minimum.
I assume when you said "Using the Oppo -1 created sharpness and more detailed lines and had no halos or errors.", you meant +1, not -1?
I did a bit of testing last night, although brief. Been watching 'Deadwood' on blu-ray. I compared the 103 at 0, +1 and my old 83 at 0. Each slightly
different, but I'd sat the 83 had the best feel of crispness without looking pushed, and of the two settings on the 103, the slight processing but sharper
image of +1 looked better to my eyes than the slight but annoying softness of 0. Both felt like a slight compromise. But I guess I'm really over-sensitive
to softness, since the 103 at zero distracted me more. I almost felt like I was watching DVD not blu-ray. (To be clear, that was a personal, visceral
reaction. I'm not claiming the problem is nearly that severe in any objective sense. I was just surprised to see how sensitive my particular eye/
brain combination was to what is reality a minor shift...)
post #5464 of 9021
. The ability to reduce the intensity between
Off and Low is something that we are looking into, but based on the register data for this chipset, it is an all or nothing type of solution."[/quote]
By this does Oppo mean- based on the chipset- there really isn't an acceptable fix?
post #5465 of 9021
You are saying that the sliders in Picture Adjustment did not match the numeric values shown? That's not normal.
First check that you have current firmware. Check Setup > Device Setup > Firmware Information. Your "Main" firmware version should end "1220".
Next, do a complete reset of the player. NOTE: You will need to re-enter your Wifi information and account credentials for things like Netflix. Do it like this:
1) Remove any disc
2) Go into Setup and Erase Persistent Storage. Then Reset Factory Defaults > Erase Accounts and Settings
3) Power down the player. Then pull the power plug for about 10 seconds. Do not skip this step.
4) Power up and re-enter your personal settings.
5) Power down once more. Settings are saved during the power down cycle.
Check to see that your Picture Adjustment settings are now showing correctly. Keep an eye on them from time to time to see that the problem does not recur. If it DOES recur, call OPPO Tech Support as the settings memory may be failing in your unit.
--Bob
Thanks for the steps, Bob. Did what you outlined and no change. Showing the exact same thing. Just to be sure here a pics and I will be checking with OPPO support to see what they have to say. I did switch over to HDMI 2 and same thing, except that sharpness was at +2 and noise reduction was at +3 and there was no sliders for color and contrast enhancement. Is that normal?
oppo a.jpg 94k .jpg file oppo b.jpg 41k .jpg file oppo c.jpg 46k .jpg file
Edited by subavision212 - 2/11/13 at 7:34am
post #5466 of 9021
Changing my Kuro sharpness to -12 and keeping the Oppo at Default "0" works for me. Does this pass the S&M disc testing, I'm not sure since I didn't tested it but I was going base on what looks good to my eyes and Oppo +1 is too drastic of a jump from default 0 to +1. Some users noticed no softness issue and others like +1 so at the end it's what looks good to you until we hear from Oppo.
By this does Oppo mean- based on the chipset- there really isn't an acceptable fix?[/quote]I'm afraid this might be t:eek:he case
post #5467 of 9021
post #5468 of 9021
Originally Posted by subavision212 View Post
Thanks for the steps, Bob. Did what you outlined and no change. Showing the exact same thing. Just to be sure here a pics and I will be checking with OPPO support to see what they have to say. oppo a.jpg 94k .jpg file oppo b.jpg 41k .jpg file oppo c.jpg 46k .jpg file
Those 3 pictures look "normal" presuming you shifted Color Enhacement to +4 yourself for the 2nd picture.
--Bob
post #5469 of 9021
That's backwards. RGB Video Level encodes Black as 16 and Reference White as 235. The values below 16 are the "blacker than black" values, and the values from 236 to 255 are the "peak white" values. The OPPO preserves the entire range from 0-255 with that encoding -- no clipping.
RGB PC Level encodes Black as 0 and Reference White as 255. There's no place to put "blacker than black" or "peak white" values so they are clipped to Black and Reference White.
Video for home theater uses RGB Video Level, which has the same data range as YCbCr (i.e., including "blacker than black" and "peak white" ranges). The data on the discs is YCbCr.
The reason for the two ranges outside of the Black to Reference White range is to provide headroom and footroom for video processing. This avoids artifacts that might occur by putting a hard cutoff at either end. This includes video processing both before the data is put on the disc and during playback.
RGB PC Level is used for computer graphics sent directly to a computer monitor. It doesn't need the extra ranges because the pixel values are being created on the fly by the graphics card instead of being produced through a video chain from film production through to disc transfer through to decoding, processing, and display. RGB PC Level is also used for video games for the same reason. The value of course is that it includes more "steps" between Black and Reference White. But again, video for home theater is encoded using the RGB Video Level = YCbCr format ranges so that's the one you want to use for reproduction, since otherwise the "fewer" steps of the home theater format must get converted to the "more" steps of RGB PC Level -- which produces rounding errors and banding (false contours) -- and any pixels with values in the "blacker than black" or "peak white" ranges get clipped.
--Bob
Ah, glad I asked. Thanks for the correction and clearing that up.
post #5470 of 9021
Haven't seen this mentioned, but wrote service about an issue when running my Direct TV through the 103 for the noticeable picture improvement. The issue, which service wrote they were aware, is that an error screen comes up stating the TV is not authorized to receive that signal on that recorded show, usually something like HBO, and to use component connection.
What they didn't tell me which I found out, is turning off the 103 and back on selecting the HDMI input again results in that particular program already playing normally. If you change to another recorded program, usually a premium movie channel, you have to do it again. As I mentioned, they are aware of it but would have preferred them mentioning the temporary solution. Love the improvement of quality , and this allows me to run directly to my amp leaving my tubed preamp off saving it's lifespan. The sound is dynamic in that direct connection to the amp, and the volume control is excellent. Even running through the preamp, the 103 has noticeable improvement over my (recently sold) 83 SE. OPPO has another amazing product for the money.....
post #5471 of 9021
--Bob
I haven't changed any settings in picture adjustment since the day I hooked my 103 up. Followed your steps and just re-entered my Netflix and VUDU accounts. I have been using all the settings recommended in the BDP-103 Settings Checklist here since I bought the 103. At least until I changed the sharpness setting yesterday. The photo with +4 on the left is when I ran the slider all the way to the right. The 0 is untouched but it still has the +4 on the right. If you say that's normal that's good enough for me. Like I said, everything looks and is running fine when using it. thanks again.
post #5472 of 9021
--Bob
OK, I think you've just gotten confused by how to read those sliders. Each slider has a minimum number on the left (0 in this case), and a maximum number on the right (+4 in this case). The vertical line inside the slider and the number TO THE LEFT of the "minimum" number represent the currently selected value.
When you slide the slider all the way to the left, the +4 "maximum" possible value will still show to the right of the slider, just as when you slide the slider all the way to the right, the 0 "minimum" possible value will still show to the left of the slider. But the vertical bar inside the slider and the current value number to the left of the "minimum" number reflect the current setting.
--Bob
post #5473 of 9021
I have a couple of questions about the 103, which I wondered if I could get some help with?
First, I have not purchased the unit yet, but would it be fair to say that I will see a marked picture improvement over the Panasonic DMP-BD30 (my existing player)?
Second, my plan is to run Split A/V mode from the Oppo direct to my display device (Epson 6010) and send audio direct to a DTC-9.8 via HDMI 2 Out (which I know many of you on this thread have done). Some people use Split A/V to enable 3D, but my chief desire would be to by-pass the SO video processor in the Integra in order to take full advantage of the Qdeo video processor in the Oppo. I called Integra and asked if there was a way of disabling the video processor in the 9.8, but apparently not, hence this proposition. Are there others on this thread who are doing the same, i.e. running direct to display device to take advantage of the Qdeo?
post #5474 of 9021
For Blu-ray: no. For DVD: maybe, but there are a lot of factors. Panasonic has a pretty good reputation with DVD.
-Bill
post #5475 of 9021
I have recently had my 8g THX calibrated if I push YCbCr 4:2:2 to 4:4:4 and Deep Color on am I going to mess things up as he said to switch off deep color and keep 4:2:2?
post #5476 of 9021
Possibly. Although in theory it should not make a difference, the point is he calibrated a specific input format and switching formats may tickle some bug.
This is a question best asked your calibrator, as he may have had good reason to warn you off the alternate formats. Or, you could make the changes and see if you can spot any differences (positive or negative).
--Bob
post #5477 of 9021
--Bob
Okay, now I get it. Thanks for clearing that up. Just assumed things were supposed to be at zero.
post #5478 of 9021
"Also keep in mind that to get the real benefit of the OPPO in such a setup you need to set your Cable box to send 480i video to the OPPO. If the cable box is sending 1080i or 1080p when you watch an SD channel then it is the Cable box which is doing the de-interlacing and upscaling of that SD channel content. And the video processing in many of these Cable and Satellite boxes is frighteningly bad."
To achieve the above would I be correct in stating that I should have the cable box set to "Native"? Are there any other selections on the cable box or the Oppo that I should make?
I have another issue if you would be so kind to address. My Yamaha RX-V1300 receiver is old enough to not have HDMI inputs or outputs. Therefore, I have it connected to the Oppo via the analog 6 CH INPUT. This setup works great for DVDs and Blu-rays through the Oppo set on 5.1 downmix. However, when I play a CD, all I get is sound from the 2 front speakers. I suppose I could run a digital optic cable from the Oppo to the dedicated CD digital optical slot on the Yamaha but I was hoping to be able to test the sound difference of the analog playback. I called Oppo and was told to select "Music" in the NEO:6 audio setup section but that does not work because when I have the Yamaha on 6 CH INPUT that selection automatically turns off the DSP programs which I believe includes NEO:6. Any ideas?
post #5479 of 9021
OPPO meant for you to try the DTS Neo:6 Music mode IN THE OPPO, not in your Receiver. IMPORTANT NOTE: You should leave that TURNED OFF except when you actually want to use it.
You do understand, I hope, that CDs are stereo. Only. You can set the OPPO to do bass steering (Crossover processing) so that you get 2.1 speaker output on the Analog jacks -- Left Front / Right Front/ Subwoofer. Set LF/RF to Small in the OPPO and pick a Crossover frequency in the OPPO. 2.0 or 2.1 speakers will give you the "purest" sound for CD playback. Using Neo:6 in the OPPO (or something like it in your receiver) "processes" the audio to generate audio to send to the Center and Surround speakers. That can be fun to listen, to, but that's certainly *NOT* what you want if you are checking audio quality.
Running Optical digital audio cable for CD playback will also work if really want to use the surround sound processing available in your Receiver.
Yes, "Native" output resolution in the Cable box will give you the correct output resolutions. Note that each time the Cable box changes to a different output resolution there will, necessarily, be a new HDI handshake.
--Bob
post #5480 of 9021
regarding analog 6 CH INPUT. This setup works great for DVDs and Blu-rays through the Oppo set on 5.1 downmix.
Would you not set downmix on 7.1 for a 5.1 setup?
post #5481 of 9021
You may see improvemt on DVD playback depending upon what type of DVD's you watch. Panny had trouble with mixed cadence material like Anime or bad cadence materials resulting in jaggies until the 110,210 models. For non-problematic DVD's it should improve but maybe not a marked improvement.
post #5482 of 9021
I did some more experimentation with Netflix High/HD streams and HDMI 1 video output from the 105 (which is the same as with the 103). I can still spot no reason to prefer Source Direct over explicit 1080p with Sharpness 0. But explicit 1080p with Sharpness +1 looks better than either.
This is with YCbCr 4:4:4 and no Deep Color. I wonder whether the folks reporting excessive noise reduction for Netflix (cured by going to Source Direct) might be using a different video format (e.g., with Deep Color enabled)?
--Bob
I have Deep Color enabled, YCbCr 4:2:2. I'll try turning off Deep Color and see if there's any difference, not that it should have any effect. I also tried Sharpness +1 at 1080p and it didn't help.
post #5483 of 9021
My hope is that, as Bob Pariseau postulated when this all first started, and he did some testing, that this may not simply an issue of the
sharpness setting levels, but something more complex and subtle that Oppo might address. (Bob, I hope I'm not putting words in your mouth).
If that's the case, there may be a fix, which isn't just about Oppo adjusting what 0 and +1 mean.
But Oppo my also declare there's no problem (which would be disappointing given the number of us seeing something), or
they may indeed say there is no fix, which would also be disappointing. In those cases I might be going back to my 83 as my
primary blu-ray player.
post #5484 of 9021
I loved my 83 but it was a bit slow with load times compared to the 103. My dream oppo would have been the 83 with the 103s processing power and hdmi input. DVD looked ridiculously good but natural.
post #5485 of 9021
Another gripe about Netflix on the Oppo. Changing the parental controls level does not take effect immediately, like it does on every other player I have. During the day I restrict the Netflix level to PG for the kids. But at night I'd like to watch an R-rated movie so I change the parental control setting on the website before I launch the app. Just tried this with the oppo and its stuck in the PG level after going in and out of the Netflix app. That's Pretty annoying since all the other players I've ever used do it instantly.
post #5486 of 9021
Turned Deep Color off, no change. Same noise reduction and motion artifacts as with Deep Color on.
Bob, the effect of the noise reduction varies based on content, and depending on what you're watching, it could be negligible. I have a few key scenes I use that reliably show the difference between the two.
post #5487 of 9021
This is good news since I have yet to calibrate the tv (I'll be using a Disney WOW blu ray). By the way, when I mentioned that I saw no dramatic difference in SD picture quality I was speaking in terms of Comcast cable broadcasts which, I suppose, are going to be lacking regardless (?). Again, I was probably expecting the impossible: that the Oppo would make the SD channels magically look nearly as good as HD channels. I will say that when I did SD-DVD comparisons with the Oppo versus my old Samsung BD2500, I did discern at least a certain amount of improvement via the Oppo. And if the PQ on that particular source gets even better after a calibration, then I'll be a happ(ier) camper. Now if I could just figure out how to get the Oppo to do my dishes for me. . .
I couldn't get my oppo 103 to broadcast anything when passing the Comcast box through it, got the error message and a green low def image on any channel
post #5488 of 9021
Try the hdmi2 output
post #5489 of 9021
post #5490 of 9021
I just went back to the first page and clicked on some the recent review links.
How is it that none of the professional reviews mention the sharpness issue?
