Originally Posted by umdad06
I had the same problem with my Harmony One. I would guess the setup software is the same for your Harmony 900(?). What I did was create a new button for the LCD screen and have the remote "Learn" the "Input" button. When I set up the remote I then could have it send the "Input" command followed by a "1" or a "3" to select the blu-ray player or the back HDMI. Works perfectly. Although i did have to put in a couple of seconds delay between commands.
HTH
HTH
Sorry, I forgot to say that I used the Oppo BDP-83 as my device. Then you have to have your remote learn the commands that are missing, such as Input.
