Featured Stories
Topics Discussed
Related Forum Threads
- OPPO BDP-105 vs Sony XA7ES for 2 channel audio question Last post on 4/11/13 at 4:51am in Blu-ray Players
- Official OPPO BDP-103/BDP-105 Anticipation Thread Last post on 5/16/13 at 11:42am in Blu-ray Players
- Oppo BDP-105 Last post on 5/2/13 at 3:07pm in Audio Gear
- Oppo BDP-105 SABRE32 DAC vs Denon 4520 built-in via Airplay Last post on 4/30/13 at 2:34pm in Receivers, Amps, and Processors
- OPPO BDP-103 OR OPPO BDP-105 Last post on 4/28/13 at 9:07am in Display Devices
Related Reviews
Official OPPO BDP-103 Owner's Thread - Page 194
Gear mentioned in this thread:
- giedrys
- Trader Feedback: 0
- Quiet Senior Member
- offline
- 383 Posts. Joined 12/2006
- Select All Posts By This User
That sounds like a hard drive issue. Maybe fragmentation?
Some buffer could be exhausted and need to be refilled, but 15-20m of BR is a large amount of data.
As an experiment, you might try unpacking the ISO into a BDMV folder contained in an AVCHD folder and see if that makes a difference. It might reveal or eliminate the loopback mechanism as part of the problem.
-Bill
Thanks Bill, I'll try. But it would be nice to make it work somehow without additional steps someday. It's a really cool feature, this playback over SMB.
- larryep
- HT 2nd class
- offline
- 1,175 Posts. Joined 8/2002
Thank you. I use xlobby for the front end. It runs on the computer and has a web server.
- apw2607
- offline
- 1,473 Posts. Joined 10/2011
Just wanted to add that my isp is now part of netflix's open connect network. So I should be able to receive super hd streams now (opp netflix app shows the super hd stream option). But of course, I'm only receiving x-high streams even though my connection is perfectly capable of the super hd streams (I get consistent 20mb down via hard wired connection). Is there any way to reset the netflix app or the player or change the network settings to ensure that I will get the better super hd streams? It's as if the oppo netlifx app doesn't recognize the super hd streams and just tops out at x-high instead of super quality. This is extremely annoying. I know I have the bandwidth do support the super hd streams via numerous network tests that I have conducted.
Super HD = 5.8MB/S which is now the new "x-high" on netflix apps that support the display/info overlay like the Oppo, PS3 and Sony 2012 BDPs.
- pwiss
- offline
- 766 Posts. Joined 10/2004
Just had an interesting email exchange with Oppo (this is why I love them, they responded in less than 24
hours, and on a holiday.) I tried to address some of the issues with sharpness, Source Direct, etc. and get
clear answers. This exchange doesn't clear up everything, but at least makes clear what's known, what's
intentional, what's a question, and just what Source Direct in HDMI 1 means.
Me: As I'm sure you're aware, debate about sharpness and other issues on the 103 continue to bounce around on
the AVS Forum. Even the on line experts seem to sometimes contradict each other. Perhaps you can clear up
some confusion.
1) If one uses HDMI 1, 1080P out, with all controls on the Oppo set to zero, is the QEDO still doing some noise
reduction and/or other processing? In other words, does it make sense that HDMI1 with all controls at 0 still
produces a slightly different (to my eye softer) image than HDMI 2?
Oppo: There is some amount of Noise Reduction applied to HDMI 1 to correct visual errors when streaming from Netflix.
From our engineering the amount of NR added to the signal is negligible for disc media playback, which is why it remains
in our firmware. We are looking into the observations that our customers have reported, but at this time we believe that the
HDMI 1 sharpness output is correct, and any alteration of the sharpness is personal preference.
2) Does that change on Source Direct? Is Source Direct from HDMI 1 unprocessed by the QEDO? Should that look identical
with HDMI 2?
Oppo: Source Direct does not bypass the NR being applied since this is a default value that we have enabled in the player.
3) Is there a reason that, at least to some of us, the processing on HDMI 1, outputting 1080P, set at 0 seems more aggressive
than that on the 93 and 83 (which, I know, had a different chip)? In other words, has Oppo intentionally chosen a more aggressive
processing level at all 0, or is that still something you are investigating as a possible bug?
Oppo: This is still being investigated, so we do not have an answer for your question at this time.
4) Would it be possible to implement the processing less aggressively or even not at all with controls at zero if it seemed like that
would improve customer experience?
Oppo: This is something that we can change in the firmware, but only if we find that the HDMI 1 output is not working to our original
engineering specifications.
It sounds like Netflix NR is only on HDMI 1. Does this imply that HDMI 2 did not need added NR for Netflix?
- wmcclain
- Trader Feedback: +3
- Bill McClain
- offline
- 13,985 Posts. Joined 5/2006
Well,,,
I think I have an issue with my 103. Purchased prior/for Christmas and its been basically flawless. This is my third OPPO, I still own and utilize a 93 since pre-order days etc thus I'm pretty seasoned with settings and am confident I have tried all that I could.
Long story short, HDMI 2 has no signal.. Basically I have/had it running split A/V.
What happens if you select Dual Display instead of Split A/V?
-Bill
- Neuromancer
- offline
- 10,427 Posts. Joined 7/2005
- Neuromancer
- offline
My understanding is that it's not about a need for NR, it's a personal choice. If you use HDMI 1 you are getting some NR no matter
what. It seems to be Oppo's opinion that Netflix looked better with it, so they left some NR on at all times in HDMI 1 with the theory it is
slight enough not to matter when playing shiny discs. (Although it does bug some of us, sigh...)
If you like the look of Netflix (or anything) better with no NR, you have to use HDMI 2, which doesn't go through the QEDO processor
at all, and so has no NR. But especially with a signal as wonky as Netflix, I think it's about taste, not need.
True, but then you have to define 'normal'. 'Normal' to Oppo, need not be the same as 'optimal' for you.
Oppo is acknowledging there is some NR on at all times with HDMI 1, and that in turn means the signal is at least
slightly processed. Whether you like it, or it bothers you is more an 'art' decision than a 'science' one. Their feeling is
that it should be so minor you won't notice it on shiny discs, but I'm not sure my eyes agree.
The way I read it, they're saying 'this level of NR looks the way we want it to'. But whether you agree with their taste
or prefer the slightly different unprocessed look of HDMI 2, or even the somewhat artificially sharpened look of
+1 is personal, not right and wrong.
To my eye, certainly, for example on SD-DVD discs, there is a notable difference between HDMI 1 and 2 with
both at 0. It affects both sharpness and contrast. On discs I've helped master, HDMI 2 actually
looks closer to the master, while HDMI 1 has slightly more 'pop', but slightly less fine detail. HDMI 1 is
a more eye catching picture, but a less 'accurate' one. (And ironically, on SD-DVD, to me both options
trail the old ABT chip results on the 83 and 983.)
But it does sound clear that the way oppo has implemented the QEDO chip is intentional and not a bug. Now
it's up to each of us to decide what we like. At least we have options.
As I understand it if you're seeing "X-High HD" on the stream, then you have to be getting the Super HD. Everyone else is limited to the "High-HD" streams under the newest Netflix configuration. But its also good to note that there's no reason to assume that a "Super HD" stream will actually look any better than anything else. But "X-High" no longer exists for the unwashed masses.
Well that settles it. Wish it was more clear on devices that support super hd. Netflix, vague as always, changes things but doesn't indicate what you should be looking for. Their landing page for super hd info says you should see "super hd" for eligible streams in your netflix app. But I guess they didn't anticipate that people might want to view stream info as well and that the stream info would indicate something different.
Thanks. I've been enjoying hdmi1 sharpness +1 but I've got both outputs hooked up so I am going to play a little with hdmi2 some more as well as hdmi1 sharpness 0.
This is getting kinda silly now, so is there any mode or HDMI that presents a Bluray as intended by the director. I'm not interested in Oppo's artistic freedom at this point "adding NR" when its not necessary and not as intended. At least give us a mode where we don't have to have the processing, is that HDMI 2 now?
As I understood their response, that's clearly what they are saying. If you want (as I generally do) a signal that is not processed
at all, you have to use HDMI 2
My personal preference would have been that 0 on all controls on HDMI 1 would have meant that all processing was off, but they have chosen
not to implement the chip that way, although their reply implied they could have done that if they had chosen to.
I'm planning to do the same when I get the time. If you can, report back your thoughts here. I'll be very curious as to what you
see.
- thirdkind
- Measured in feet.
- offline
- 2,472 Posts. Joined 3/2002
Then there's something else going on with Netflix because I see the same artifacts and softness on both HDMI 1 and HDMI 2 when set to 1080p. Using Source Direct clears it up in both cases. The effect is so subtle as to be irrelevant on some material and noticeably detrimental on other material; I can provide suggestions for test material if anyone cares to investigate further.
I haven't seen anything objectionable during Blu-ray disc playback at any resolution, so I'll leave that debate to others.
Sidetracked- Thanks for sharing your Oppo email communications with us
Even before all this sharp 1 stuff it was very clear to my eyes that hdmi1 looks the best on bluray. I can't say if it is the most accurate but its definitely bold and highly detailed with great pop and richness and there is simply more there to gawk at than hdmi2. The NR on hdmi1 appears to be adaptive and on something like avatar or up that is such a clean source I doubt any NR is going on because there isn't any. Someone else commented that some of the chroma patterns on spears and munsil were better on hdmi1 than hdmi2 which I haven't messed with a lot.
My issues have been with my cable feed in the oppo input. On 720p sources hdmi1 sharp 0 looks soft, on some 720p especially sports sharp 1 looks ringy. Hdmi2 in addition to maybe looking a little more natural has way better handshaking.
- rdgrimes
- Oppo Beta Group
- offline
- 14,804 Posts. Joined 3/2004
Just found some rather big glitch:
When playing mounted BD 3D ISO file and via SMB, picture and sound stutters after 15-20min of playing, sometimes sooner. It coincides with HDD noise(same as windows searching or indexing). After pausing and waiting a minute everything is back to normal... for another 20 min.
Is this my hardware(bandwidth) limitation? The particular HDD where media files are located is rather fast (WD Black)
You've got something thrashing the HDD. Windows search or indexing is a possibility. Open "resource monitor" while the ISO is playing and it'll tell you what processes are accessing the HDD while this is happening. I forget where that particular monitor is located, but its lurking somewhere. (resmon.exe)
- jdlynch
- Trader Feedback: +2
- offline
- 453 Posts. Joined 8/2002
Could someone please explain this to me?
I am not using any of the digital/HDMI output connections.
- pwiss
- offline
- Hubertoliver
- offline
- 164 Posts. Joined 2/2012
I"m using HDMI 2 mainly for my SACD's and because my PIONEER VSX-1121 has the QDEO chipset I can utilize. It's working great using this setup so far.
- giedrys
- offline
It's not windows search-disabled at the moment. So is indexing. Will try "resource monitor" option.
First, what makes the Oppo 103 better then say, Sony /ES, Pioneer/Elite, Panasonic, ect. Trust me I can unserstand the difference's if I am told what they are, and if they can be seen. I do not quite follow how the wireless work for this player either- ie, netflix ect.
Secondly, reviews state even the customer support is the highest in the industry- is this actually true?
Third- Are these players made here in the USA?
Finally, in a few months I will be upgrading to a projector and screen at 100 or so inches, I am not into 3d, so would the 103 be a good choice for my use? Does it do 3d? How good is the 2 channel audio compared to high end SACD players. Would this player be a good all in one unit?
Thank you in advance.
- globalnomad
- offline
- 50 Posts. Joined 12/2012
Hi there, there are others on this forum much more knowledgeable than I, but I think I can help you with the above.
Based on my own interaction with OPPO, I would give their customer support 5*. I had a defective player (locked up on startup) and I was exchanging emails in near real-time. Reading about others' interactions with them, I would say that their prompt responses are anything but an exception.
103 does support 3D, though I do not use 3D myself so I can't speak to its quality. OPPO's audio is considered one of the best and does line up against some SACD players, though from what I've heard not necessarily high end SACD - perhaps mid-tier. Here in Hong Kong, some people buy the 105, which has superior analog audio and a DAC, exclusively for its audio playback abilities. I've seen many an OPPO set up in audio Hi-Fi shops. I know some people on this forum have noticed a hiss/hum when connecting analog directly to an amp, though it seems the controversial "consensus" is that this is hardware dependent. I'm running mine in stereo mode to a micromegaHD IA-60 to a pair of Monitor RX2s and I couldn't be happier. The reason I bought the OPPO was to get the best of both the audio and video worlds - I love that it's networked as well.
- globalnomad
- offline
I have 3 players in use right now DVD, HD, and Blu Ray. So as you can imagine I would really like to consolidate some space. That said, I am not willing to give up my 2 channel audio, heck I still listen to vinyl- and love it too.- Official OPPO BDP-103 Owner's Thread
Recent Discussions
- › Digital Concert Hall dot com, Berlin Philharmoniker 16 seconds ago
- › Movie with the HOTTEST girl you've ever seen. 19 seconds ago
- › ePVision PHD-VRX Owners Thread 31 seconds ago
- › Microsoft fires the first shot in the "NEXT" generation.... 32 seconds ago
- › 'Motive' on ABC 40 seconds ago
- › Panasonic ST60 Deals 1 minute ago
- › 2013 Panasonic Settings/Issues Thread 1 minute ago
- › Sherwood R-972 User Thread 1 minute ago
- › The Official ChromaPure thread 1 minute ago
- › Calling all Polkies:Official Polk thread 1 minute ago
Recent Reviews
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › BenQ W1070 1080P 3D Projector by jakob_s
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
- › Sharp DT 510 DLP Projector by rdcollns
- › Onkyo TXNR801 / TX-NR801 / TX-NR801 7.1 Channel Digital Home... by mswope63
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
