^ The usual suggestion is to uninstall any components of Windows Live Essentials that you might have on Windows 7 as it appears to interfere with SMB access to Windows 7.
Some folks have reported that components of Windows Live Essentials may be a bit tricky to find (embedded with other installs) and so they report success by installing Windows Live Essentials and THEN uninstalling it to get rid of all of them.
ETA: I should add it is also possible to screw up access to Windows 7 if you don't have the various sharing permissions set up correctly in it. There have been a number of posts from folks in this thread describing what's known to work. Try a search. I'm not sure if this info has made it into the FAQ (link available at the top of the first post of this thread). I don't do SMB from Windows 7, so I can't rattle off the answer for you.
--Bob
Edited by Bob Pariseau - 2/21/13 at 6:46am
--Bob
