AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players ›  Official OPPO BDP-103 Owner's Thread
Official OPPO BDP-103 Owner's Thread - Page 23
post #661 of 9120
Originally Posted by davehale View Post
My next glitch,
I have played over 100 Blu ray disks on my 93 including Star Trek -played twice (the one with Spock, McCoy and Jim Kirk when they were younger) and no problems. It stops repeatedly at 3 minutes and 34 seconds even after carefully cleaning it on my -103.
Dave
That would be the newest Star Trek from 2009 with new actors etc. All the details here http://www.imdb.com/title/tt0796366/
Of course I have this title as I love a lot of scifi including Star Trek. I will test it out soon maybe tomorrow and let you know if I have the same results.
post #662 of 9120
Can the Oppo player support local physical storage formatted in Mac OS Extended or does it need to be FAT32/NTFS?
post #663 of 9120
ok, I meant to play the discs in the OPPO not stream
post #664 of 9120
Thanks Bakerwi,
It only states Star Trek-no other title or designation or #. I have emailed OPPO to see whats up.
Dave
post #665 of 9120
FAT or NTFS only.
-Bill
post #666 of 9120
I'm not understanding the question. What does the Xtreamer SideWinder3 have to do with playing discs on the OPPO?
-Bill
post #667 of 9120
My next glitch,
Dave
There's an abundance of information not provided, but what you're describing is a pretty typical description of a flawed disc. In any case that movie plays fine here.
post #668 of 9120
Thanks for checking it out rdgrimes. Liked that movie and now seems- worthless ,not a scratch or mark on it and only I handled it. Hope I don't find any more like it
Dave
post #669 of 9120
Watched Californication tonight season 4 (DVD) disc 1 and several times went to pause, rewind, fw and when resuming play the framerate was very jerky. Had to pause, play a few times to get it smooth again. Anyone else experiencing this? I do have it set to 1080P/24 so not sure if that might be the trouble.
post #670 of 9120
^ There have been reports this can happen with DVD 24p Conversion ON. As you discovered, doing Pause/Play again is the cure. It is evidently frame drop stutter due to 24p Conversion getting confused by your navigation commands. It does not seem to be easy to reproduce.
If you have found a repeatable case, please email OPPO Tech Support with the disc and time code information, and the exact set of steps which you've found generates the problem.
--Bob
Edited by Bob Pariseau - 10/14/12 at 12:31am
post #671 of 9120
Hi
Wondering if the new oppo will support 3 or even 4 tb harddrives
Mikael
post #672 of 9120
Another early first impression of the BDP-103
Blu - Ray - OPPO BDP-103 (translated from hometheater.co.il)
Speed
There is a new feature to play a quick fire. One of the things that really bothered the previous player was the long time it took him to come on to work. I checked the time machine's power various situations, and comparing it to other devices:
- OPP BDP-103 Quick Start mode (partial shutdown) - about 6 seconds
- OPP BDP-103 from Energy Efficient (complete shutdown) - about 19 seconds
- OPPO BDP-93 - about 38 seconds
Summary
This is indeed a significant upgrade with the previous player. Oppo company opened a large gap over the competition. Very good construction quality. Buttons and remote device better quality and feel good. Backlit sign quality and show a sharp instrument and displays important information.
post #673 of 9120
Hi,
Seriously tempted by a 103 but have a couple of questions.
I have my media on shared (SMB) drives on both a NAS and also my Win 7 PC, I currently use a Dune media player which plays the media fine. Would the Oppo also play said media? It's all BluRay backed up to BDMV folder structure.
Also I may upgrade to a 3D projector sometime in the near future, is the 103 able to play 3D via SMB in either ISO or BDMV folder?
Thanks in advance.
post #674 of 9120
Originally Posted by swarm87 View Post
stupid question but would a 103 be overkill for a 37" tv(set is 4 years old and am considering upgrading to a 42 or 47 3d set in the next 2 or 3 years)
Assuming it is a 1080p display and not 720p, high quality source components are every bit as important as they are for larger TVs as long as you are sitting close enough to see all the detail in HD images. The real determining factor is viewing angle... how much of your field of vision is occupied by the TV screen.
Let's take a viewing angle of 40 degrees... you can achieve this with ANY video display and they will all give you the same detail regardless of how large the screen is. For example here are examples of disgonal screen sizes and the viewing distance that provides a 40 degree viewing angle:
37" = 3.7 feet
47" = 4.7 feet
60" = 6 feet
72" = 7.2 feet
96" = 9.6 feet
All of those screen sizes and viewing distances will result in THE SAME viewing experience because the screen will fill the same 40-degree angle of view in every case. And that viewing angle will allow you to see all the detail present in HD images. If you sit much farther than that from the screen, you won't be able to see all the detail present in the images. It's amazing how far most people sit from their TV or projector screens... much too far to see all the detail present in 1080 resolution images. When we switch to 4K resolution images, it will be even WORSE as you'll have to sit even closer to see all the detail present in the images!. I've seen 4K images and they do support getting very close to the screen to see all the detail present in the images.
post #675 of 9120
I just bought the 93 a few months ago. My new favorite player is the Sony S790, which seems to upscale better. Curious to know how the 103 stacks up against the Sony for DVD upconversion.
post #676 of 9120
Originally Posted by honky1000 View Post
Hi
Mikael
Yes, see the FAQ: What partition tables are supported on attached hard drives?
-Bill
post #677 of 9120
Originally Posted by s_inman View Post
Hi,
Yes.
BDMV: yes.
Blu-ray ISO: no, not directly. There is a trick with SMB that might work for you: How do you play Blu-ray ISO files over SMB?
-Bill
post #678 of 9120
Even the lowest end Sony blu-ray player upscales better than a 93, hence my hope the 103 is an advance over the 93.
post #679 of 9120
The Oppo 93 is one of the poorest upscalers of dvd and lower res media. Even cheap Pioneer and Panasonic players have it beaten in this department. Im not sure if it's their implementation of the Marvell QDEO, or the fact the QDEO is just overhyped to begin with. The mediatek output on HDMI 2 can look cleaner and less artifact prone than the QDEO in certain cases.
What irks me is how many AVS members just fell over themselves to kiss OPPO's behind and declare it a great upscaler, which it wasn't.
I sincerely hope those now reviewing the Oppo 103 will do an even handed assessment of its capabilities.
post #680 of 9120
Originally Posted by Agisthos View Post
kiss OPPO's behind
You have a right to your opinion but you are being offensive and, I suspect, in violation of forum rules.
-Bill
post #681 of 9120
Some members are still saying that the 83 is still the best, also better than the 103.
post #682 of 9120
^ As stated in prior posts, personally I've switched to the 103. In addition to scaling and de-interlacing improvement over the 93, it also has significant improvements in DVD 24p Conversion over the 83.
--Bob
post #683 of 9120
My next glitch,
Dave
Dave,
I've tried the time stamp you reference and it plays without a problem on my 103 and 93. I can't imagine what could be causing it not to play on your 103. Hopefully, someone else can venture a guess as to the possible problem.
post #684 of 9120
^ With Blu-ray it is possible to have manufacturing defects that are not visible to the naked eye.
The usual next steps in a case like this would be to try the disc in a different player. If it fails there as well then exchange the disc.
If it works in the other player, then give OPPO Tech Support a call. If they don't spot an easy answer, and you are willing to loan out the disc for a while, they've even been known to take in discs so that the lab guys can try them and see precisely what's happening on your specific disc (which may differ from a new copy they could buy themselves). They send the disc back of course.
--Bob
post #685 of 9120
I did prefer the Sony BDP-S790 over the BDP-93 for DVD playback, but it wasn't night and day and if I had to make a choice it would be the BDP-93 for everything else that it supports that the Sony does not..smile.gif My only reason for purchasing the Sony at the time was for my wife who likes streaming content. Actually if not for streaming the Sony would not have been a consideration, but the DVD playback was a pleasant surprise.smile.gif I would suggest anyone just looking for blu-ray, DVD playback and streaming to consider the Sony.
The DVD playback of the Sony BDP-S790 is pretty much a wash compared to the BDP-103 according to my eyes. However, before someone chimes in with the price delta between the Sony and the BDP-93 or BDP-103 remember you are getting significantly (in my opinion; especially the 103) more machine and don't get forget Oppo's outstanding customer service, which you can't put a price on.smile.gif
Edited by bakerwi - 10/14/12 at 7:58am
post #686 of 9120
Does anyone else have an issue with their 103 showing a white band along the left side of the display when the screen saver activates? I've attached a pic. Ignore the flash booms that look like I captured the moon in the picture.
post #687 of 9120
Yes, that's a known problem. A few pixels of the underlying image are showing through along the left edge. OPPO engineering is on the case.
--Bob
post #688 of 9120
While you are entitled to your opinion; in my opinion the BDP-93 is not as bad a DVD player as you make it out to be. I did think the BDP-83 which I no longer own was a better DVD player, but Oppo had significant experience with the ABT chip. I can't speak to the cheap Pioneer and Panasonic players since they don't hold any interest for me, but the 93 is definately not a dog when it comes to DVD playback. There may be some transports subjectively better, but I haven't seen night and day amongst the transports I own and I own some solid transports. Some of the beta testers and owners (myself included) of the both the BDP-83 and BDP-93 definately saw room for improvement in this area of the BDP-93.
I also don't recall the many AVS memebrs falling over themselves to kiss Oppo's behind and declare it a great upscaler, but maybe I missed those postings.biggrin.gif I could be mistaken, but I since a little anger:D; remember this is only a hobby.smile.gif
It still amazes me the visceral response that an Oppo product can elicit.eek.gif
Edited by bakerwi - 10/14/12 at 8:16am
post #689 of 9120
83 still rules over 103 for DVD playback in my opinion.
post #690 of 9120
Google translation from Dutch of a new review of the BDP-103EU:
http://translate.google.com/translate?sl=nl&tl=en&js=n&prev=_t&hl=en&ie=UTF-8&layout=2&eotf=1&u=http%3A%2F%2Fwww.htforum.nl%2Fyabbse%2Findex.php%3Ftopic%3D126939.0
The translation is what it is. Native speakers may prefer the original:
http://www.htforum.nl/yabbse/index.php?topic=126939.0
--Bob
Edited by Bob Pariseau - 10/14/12 at 8:34am
