AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players ›  Official OPPO BDP-103 Owner's Thread
Official OPPO BDP-103 Owner's Thread - Page 247
post #7381 of 16402
Originally Posted by wmcclain View Post
Out of order on SMB? That is a known issue. The server is delivering the names out of order and the player should sort them but doesn't.
I'm not sure what is standard in the SMB world: who is supposed to do the sorting, but if the servers aren't then the player must.
There is a trick to make recent Samba servers sort correctly, but I don't know about WHS.
In DLNA the servers sort and are generally correct, or at least under user control.
-Bill
- I guess its the SMB. I'm not particularly savvy at the networking protocols, and running an OS that is a native server has certainly created its fair share of redundancies that I've yet to fully crack.
When I go into the Network on the Oppo, I have (if I recall, i'm not at home) about 12 devices/servers that can be accessed. My main storage is on a WHS2011 machine, where I'm running Plex (primarily for adding additional metadata for movies and streaming to portable devices), AssetUPnP (for my music sharing), and the native WHS server. All of the computers in my network show up.
I see the PCs each twice. Once with the little server icon next to them and once with the Windows Media logo next to them. Plex and AssetUPnP are listed separately with their own icons.
If its a known issue, i guess I'll deal with it until Oppo chooses to deal with it (or not).
thanks!
post #7382 of 16402
The two little servers icon is SMB.
DLNA servers provide their own icons, and so will be different for each type. Is there a generic icon? I forget.
-Bill
post #7383 of 16402
-Bill
Its the SMB and the Windows Logo ones. But yes, definitely the SMB.
thanks for the help, Bill!
post #7384 of 16402
Originally Posted by SeeMoreDigital View Post
I've got quite a few hardware media players... I'll fire them up and compare the differences via SMB wink.gif
Okay, I've just compared the 'Music' album folder layouts from a Realtek and a Sigma chip-set based hardware media player against the Oppo (Mediatek) and both of the other players list the album names in the correct alphabetical order.
By contrast. For some reason the Oppo places Don Henley above Boston, Cyndi Lauper, Aerosmith and the Black Crowes eek.gif
post #7385 of 16402
There is a trick to make recent Samba servers sort correctly...
-Bill
Would you mind sharing this trick? Thanks.
post #7386 of 16402
If I understand the "Split A/V" feature correctly, HDMI1 is used to send video to my TV and HDMI2 to send audio to my AVR. But I notice that audio is also being sent to my TV on HDMI1. Was I wrong in assuming that this connection would be video only? If so, is there a setting to disable audio on HDMI1 in Split A/V mode? TIA.
post #7387 of 16402
-Bill
In /etc/samba/smb.conf, place this line under "[global]":
Code:
    vfs objects = dirsort
Restart the server.
I believe this requires Samba v3.3.3 or later.
Someone tried it on a NAS and couldn't get it to work. We suspected that some administrative tool on the NAS didn't like configuration files being changed behind the scenes.
-Bill
post #7388 of 16402
-Bill
The generic DNLA icon on the Oppo is 2 little PC monitors. The Microsoft icon is always going to be the retarded WMP server, which can be shut off without affecting SMB.
post #7389 of 16402
My set up is split like yours. HDMI will carry both audio and video from the source if both are available which they would be with the Oppo's 2 HDMI outputs. So the short answer is to just keep the volume turned off on your display if you want to use your AVR to control the audio.
post #7390 of 16402
This is incorrect. If your HDMI-2 connection is "powered off", then both audio and video will be output from HDMI-1. But if HDMI-2 is "powered on" and you have "Split A/V" set, then HDMI-1 will be video-only. HDMI-2 will be both audio and video.
If you have "Split A/V" set, according to page 53 of the PDF user manual:
2. Dual HDMI Output: Allows you to select the output mode when both HDMI Output ports are in
use. If only one HDMI Output is active, this selection will not apply.
Split A/V (recommended) – Use HDMI 1 OUT as the dedicated video output port and
HDMI 2 OUT as the dedicated audio output port. This setting will ensure the best possible
picture quality and the highest possible audio resolution.
Dual Display – Send digital audio and video signals to both HDMI Outputs simultaneously.
This setting is only recommended when two HDMI displays are required, since the surround
sound audio signal may be down-mixed to stereo and the original audio quality may be lost.
In Split A/V mode, HDMI 1 OUT has video only with no audio, but HDMI 2 OUT will have audio
and possibly video. This is because HDMI embeds audio into video data so there must always
be a video signal, even if it’s only a blank screen, to carry audio through.
post #7391 of 16402
Sorry for the wrong info. So it sounds like the OP has his player set to split mode, but is still getting audio from HDMI 1 to the display. Shouldn't that be automatically off if he's chosen split and is running audio via HDMI 2?
post #7392 of 16402
O.K., I get no audio while playing some video files thru oshare (I am new at this, so bear with my ignorance), I think WMV files play ok, also 24/192 HD tracks don't play thru oshare, any guidance would be appreciated.
post #7393 of 16402
Exactly -- both my HDMI ports are connected to an active powered-on device but I'm still getting audio on HDMI1.
post #7394 of 16402
Could you test the files on local storage to eliminate the DLNA server as a factor?
If still no good, post the mediainfo (http://mediainfo.sourceforge.net/en) results for the problem files.
What type of files are the HD tracks?
-Bill
post #7395 of 16402
-Bill
Any idea how to check my Samba version?
And I think you're right about not being able to change the file -- it seems to take the edit but when I reboot the edit's gone from the config file. Any way around this?
post #7396 of 16402
This is on an NAS? I can only suggest finding a support forum for your model, or asking the vendor.
My experience is on Linux, which (of course!) always works for everything.
-Bill
post #7397 of 16402
Thanks Bill, the 24/192 are FLAC files and the video files are mp4. I did notice that 24/96 FLAC files will play though, at least the one set of 24/96 files I have play.
post #7398 of 16402
-Bill
Yes this is on a DNS-323 running ffp. Will investigate further as you suggest. Thanks Bill.
post #7399 of 16402
Hmmm...
Unfortunately, this SMB Samba trick does not explain how/why all my Mediatek and Sigma A/V chip-set based media players are able to list SMB shared directories (stored on my Synology NAS) in the correct way!
post #7400 of 16402
Hmmm...
Well, no. One thing has nothing to do with the other.
The OPPO is not sorting SMB listings and the other devices are. If you can get the server to sort the listings before sending them then the OPPO does not need to.
But the ultimate solution is for the player to sort. We went through the same thing on USB devices ages ago on earlier players.
-Bill
post #7401 of 16402
Arrrgh... It all so infuriating!
post #7402 of 16402
Certainly shouldn't be happening.
I'd call Oppo for support, and to decide if your unit is defective or if there's something else configured incorrectly in your setup.
But in my mind, that's exactly what "Split A/V" is for, as long as the HDMI-2 device is sensed and powered on, HDMI-1 should be video-only. That's the design.
post #7403 of 16402
Code:
Restart the server.
-Bill
Bill, I just wanted to tell you that I managed to upgrade my NAS's Samba to 3.4.6. I then added that line in the smb.conf file and voila -- it worked! I now have beautifully sorted files when accessing my NAS from the Oppo using SMB. Thanks again.
And if you're at all interested why you can't change the conf file on some NAS's it's because on these machines the conf file is actually loaded from NVRAM (and placed in /etc/samba) when the NAS boots. So you can make all the changes you want but when you reboot the file gets clobbered. This is probably done so you can't inadvertently hose SMB -- make a mistake in that conf file and you've lost your SMB access.
Edited by Flave - 4/4/13 at 4:27pm
post #7404 of 16402
I haven't ventured into the beta firmware, but is there any update on whether YouTube will now remember your account information and device pairings across reboots?
post #7405 of 16402
It's working for me.
--Bob
post #7406 of 16402
^ Thanks!
post #7407 of 16402
Forgive me if this question was answered before. Is there a difference in quality between the 103 and 105 for a SACD playing in bitstream?
I just bought the new processor from Marantz Av8801, and I’m wondering if it worth buying the 105.
post #7408 of 16402
Over HDMI? No difference.
-Bill
post #7409 of 16402
-Bill
Yes, over HDMI!
Thanks Bill!
post #7410 of 16402
Originally Posted by Bob Pariseau View Post
The first reaction whenever you have connectivity problems like this is that something needs to be fixed in the HDMI cabling. For example, don't use short HDMI cables between any two devices (which includes the Darbee). The sweet spot in length for HDMI cables is about 6 feet (2 meters) between any two devices. Second, make sure ALL your HDMI cables are marked as "High Speed" or "For 1080p". Keep in mind that HDMI is an end to end protocol so ANY cable in the signal path could be the problem, including cables beyond the Darbee. Third, consider the entirety of your HDMI cabling and see if there is more than one possible HDMI path from the Source to the AVR or Source to the Display. If so, temporarily DISCONNECT the path you don't think you are using and see if the problem goes away. Some devices keep HDMI connections "live" even when you don't think they are selected for use. Some devices EVEN do this when the device is supposedly OFF!
Still having problems after the above? Try 1080i from end to end instead of 1080p. If 1080i works but 1080p does not, that's a pretty strong indication that some cable is marginal, perhaps a faulty cable.
--Bob
Thanks Bob. Replaced one of the short cords with a longer one and that seems to have done it. It was working with the short cord with my previous blu-ray players so I assumed the problem was something else.
