AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players ›  Official OPPO BDP-103 Owner's Thread
Official OPPO BDP-103 Owner's Thread - Page 322
post #9631 of 16357
Originally Posted by PRBR View Post
is that people said hat is not good to pass video thru the avr that is why i taking the other route.i works fine with my sony and my samsung both of them with dual hdmi so your theory of two hdmi terminating at the same tv is not very accurate
1) The Oppo is also a very different unit compared to the Sony and Samsung with a secondary video processor (Qdeo) in the mix on HDMI 1.
2) It's only bad to pass video through the AVR if the AVR does something bad to it. This was a potential issue back when video was analog or if the AVR had a poor digital video processor that degraded the digital signal. The RX-A810 (via HDMI) is neither and simply passes the digital signal to the TV. Try it at least. I don't think you'll see a difference in video quality in your specific situation.
post #9632 of 16357
Hey guys, I am SURE I am hallucinating, but it appears to my eyes that HDMI 1 "Softening/NR" issue is improved on the new Beta. Anyone else see this or is it just placebo/Wishful thinking? I can see a scenario where this could have been improved without making a big to do in the Release notes since the implication previously was that the chip was working as expected. Thoughts? Anyone else on the new Beta version notice this?
post #9633 of 16357
i can try it that way or just turn off the oppo,turn on the video output on the avr,set up what ever i want to set and the turn it off again.that is the way im doing it right now but is not the way is suppose to be!! thanks for the input
post #9634 of 16357
Originally Posted by Bob Pariseau View Post
Think of it this way: Do DTS-HD MA and Dolby TrueHD work to your speakers? The signal going to your speakers is also Analog. The answer, of course, is yes.
Playing a high bit-rate Bitstream digital audio format like DTS-HD MA or Dolby TrueHD involves two steps. First the Bitstream gets "decoded" into high bit-rate, multi-channel LPCM. LPCM is also digital audio -- think of it as the "simplest" form of digital audio. Next the LPCM has to be "converted" to ANALOG audio -- by DACs (Digital to Analog Converters) -- at which point it is no longer digital audio. It is Analog voltage levels that can be amplified and rendered by your speakers.
The OPPO can send the original Bitstream out over HDMI -- after which all that processing has to be done in your AVR.
Or the OPPO can decode the original Bitstream into the equivalent set of LPCM streams and send THAT out over HDMI -- after which you AVR only has to do the conversion to Analog.
Or the OPPO can decode the original Bitstream into the equivalent set of LPCM streams and then convert those to Analog for output on its Analog audio jacks -- after which your AVR only needs act like a pre-amp, as all the heavy lifting (processing of the audio while still in digital format) has already been done in the OPPO.
(The Optical/Coax digital audio outputs are handled differently since they can not carry either the high bit-rate "lossless" Bitstreams, nor carry multi-channel LPCM. If you try to play DTS-HD MA or Dolby TrueHD over those, you will get a "compatibility" audio track instead.)
So for DTS-HD MA and Dolby TrueHD to "work" via the Analog outputs, two things need to be true: First the OPPO needs to be able to decode those Bitstreams into the equivalent LPCM digital audio streams. And Second the OPPO needs to be able to convert high bit-rate, multi-channel LPCM digital audio to multi-channel Analog audio for output in a high quality fashion. The 103 and 105 do both of those -- with the 105 doing an even better job of the second part -- the conversion to Analog.
--Bob
if i set my oppo to do the decoding with his digital to analog converter,there is a difference using the analog audio vs the HDMI? some guy at a store tell me you can hear a difference is you let the oppo do the decoding and send it thru the analogs outputs to the avr...is that true?
post #9635 of 16357
Potentially - it depends on the quality of the digital to analog conversion at the Oppo vs. the AVR.
If the Oppo has better DA converters, there may be a difference if you sent it through HDMI to the AVR if the AVR has inferior DACs.
If the AVR has better DA converters, then the HDMI path may be better, since you are using the AVR's DACs.
That is, of course all other things being equal. The wild card in this is the room correction that the AVR is probably putting on the incoming signal, compensating for the room's inadequacies. If this performs better than you setting the proper values on the Oppo, then the HDMI path is better. If you do a good job of setting the values in the Oppo, that may sound better.
In the end, it depends on your taste. I found both approaches to give good results, the Oppo -> analog took a bit more work. I now have an HDMI path only for convenience, and because I like my Pioneer's room correction being applied.
post #9636 of 16357
thanks good to know!! my avr does not have a 7.1 analog input but i can get one with it if it will sound better that way but based on your advise i leave it like that using the hdmi! thanks
post #9637 of 16357
Don't forget you would also need to get 4 pairs of interconnect cables. Who wants that mess? It is the reason everyone went HDMI years ago.
post #9638 of 16357
Well,,, that's not the real reason. Prior to HDMI everyone typically used a single digital cable or fiber optic toslink for sound and either composite, component or S-Video for video.. HDMI handled the increasing bandwidth issues associated with better resolutions on both audio and video. Not to mention the ever increasing copy protection capabilities... My OPPOs were the first to have me try multi channel analog.
Overall however, with exception to the physical connection and inherent handshake issues I'll take the single HDMI run over two digital cables any day. biggrin.gif
post #9639 of 16357
I used to have sharpness set to +1, but now I leave it at 0, so there could be something in what you say - or it´s just a figment of the imagination.
post #9640 of 16357
I tried sharpness +1 after the beta, was my first time, and I did not care for it after a couple of days. I have a darbee 5000 waiting at home now, kinda curious to try it for a longer period.
post #9641 of 16357
I have a Darbee as well typically at around HD45-47. Since installing the Beta I felt the need to dial down the Darbee a bit closer to 40 and with the Darbee "off" I felt like the pure picture from HDMI 1 was indeed a bit less soft than before. Again, I could be imagining it, but I don't think I am.
post #9642 of 16357
For the first time, I have spent some time comparing the output of HDMI1 and 2 with the same content and all picture adjustment settings at 0. I definitely prefer HDMI1 in terms of definition.
post #9643 of 16357
Sorry if this has been mentioned/asked in this thread already, but does the OPPO 103 stream Netflix 3D?
I think my ISP supports it, but haven't noticed any indication on the OPPO Netflix app.
If it does, what movie would demonstrate this on my 3D Optoma from Netflix? And does it require a certain OPPO firmware version?
post #9644 of 16357
Looks like there is a specific list of devices from Netflix that support 3D.
post #9645 of 16357
And a specific list of providers (HSI). I have devices that will do SuperHD and 3D, but my ATT DSL is not supported.
post #9646 of 16357
Is there anyone here using the Roku stick who wouldn't mind testing 24fps content on Netflix? I reported an issue to Oppo a while back, but they said no one else has reported the problem. It's still on their list for the engineers to review.
If I watch Netflix content encoded at 24fps using the Roku stick, I see dropped frames and stuttering about once per minute. The audio is unaffected. I've tried 1080p24 AUTO, ON, and OFF on the Oppo, and they all demonstrate the problem. It looks like the video processor has some trouble maintaining a framerate lock on incoming 24fps material.
When using the native Netflix app, I don't see any dropped frames, but I think that's because the native app outputs everything at 1080p60 regardless of the original encoding.
If someone could give it a try and report their findings, I'd really appreciate it. Confirmed 24fps material includes Arrested Development (Season 4, anyway), Hemlock Grove, and The Tudors.
post #9647 of 16357
I can do SuperHD with the OPPO and my provider sits on the OpenConnect or whatever it is for Netflix.
But I don't see any 3D from Netflix or Vudu on the OPPO.
Is anyone doing this on the OPPO or is the OPPO just not supported?
I was pretty sure someone mentioned that it was, but maybe I was deluded.
I doubt the OPPO is going to show up on the 'list' of compatible devices on Netflix, that probably gets updated once a year, lol!
post #9648 of 16357
I thought as long as you could do SuperHD and were on OpenConnect, it meant you had 3D too. Maybe Im wrong there.
post #9649 of 16357
only certain players can do 3d. mostly the ps3. not even the roku can do 3d.
they can do the superhd. I kinda doubt it that oppo will be able to do the 3d.
Jacob
post #9650 of 16357
Have any of the reviews examined the scaling and deinterlacing of the HDMI input? Ive not seen one, unless I missed it. All the reviews seem to focus on audio and blu-ray, but of course one would be curious how well the HDMI In Back does with 720p and 1080i from a DVR.
I agree .. no one (to my knowledge) has reviewed the quality of the HDMI inputs. Since its the first BR player to have these type of inputs, reviewers probably didn't know what to do with them and with time constraints, they simply skipped them. Hardly any tested the quality of the headphone amplifier, with the exception of Secrets of Home Theatre and at that just a listening review, which I guess is fine. A few tested the USB dac and coaxial/optical inputs. Again Secrets did this as well plus maybe a few others.
post #9651 of 16357
Jacob
According to Netflix´s website, currently only PS3 and only with certain LG TV models.
post #9652 of 16357
Top notch calibrators and even Stacey Spears, maker of the Spears & Munsil calibration disk says the same. HDMI-2 is inferior for video using cheesy interpolation algorithms like Nearest Neighbor(simple pixel replication which produces jaggies easily) which produces Chroma misalignment.
HDMI-1 uses Bi-linear interpolation which is much superior with no chroma errors and minimal artifacts. If you want to know more, you can get the new S&M ver 2 disk and run the test patterns. You'll either cry or get elated at how your TV performssmile.gif!
post #9653 of 16357
HDMI-1 uses Bi-linear interpolation which is much superior with no chroma errors and minimal artifacts. If you want to know more, you can get the new S&M ver 2 disk and run the test patterns. You'll either cry or get elated at how your TV performs:) !
I have just ordered the S&M-2 disc from Amazon.com and eagerly look forward to putting my equipment through its paces.
post #9654 of 16357
I just picked up a bdp-103 and will be setting it up this weekend. My processor is a Marantz AV8801 and I will be using HDMI. Short of scouring through 9000 posts are there any setup tips/settings you would definitely recommend different from the factory default ?
post #9655 of 16357
The FAQ has some tips: What are the recommended settings for the OPPO BDP-103?
The manual has a good section on audio configuration.
-Bill
post #9656 of 16357
Yes, but HDMI 1 has forced DNR, while HDMI 2 does not. It's a trade-off, and you'll have to decide for yourself which problem is more bothersome to you.
I've reverted back to using the BDP-93 for the time being.
post #9657 of 16357
I thought HDMI 1 on the 93 had the same forced DNR.
post #9658 of 16357
The User Manual states as follows (p. 58):
"7. Noise Reduction: Allows you to select whether the player will apply video noise reduction processing. For HDMI 1, the noise reduction level can be set between 0 and 8. The default is level 0, which turns off noise reduction."
Reading this literally, there should be no noise reduction of any kind if the level is set to 0. Am I missing something??
post #9659 of 16357
Several users have noticed that HDMI-1 looks a lot sharper after the latest beta firmware. You might have to try to for yourself and decide.
Yes it does...but to what degree as compared to the 103/105, we do not know since they use the same video processor.rolleyes.gif
post #9660 of 16357
Confusing eh? Oppo has repeatedly said that even with NR set to zero, there is still inherent noise reduction going on within the QDEO processor.
