AVS › AVS Forum › Audio › Soundbars › Outlaw Audio OSB-1 soundbar
post #1 of 13
There is been some discussion about Outlaw's new soundbar (the OSB-1) in their company-hosted forum for several weeks, but it actually went on sale today (shipping in a week or so). This is a powered unit designed using Atlantic Technology's H-PAS algorithms, so it achieves a -3dB point of around 47Hz. I had a chance to listen to Atlantic's AT-1 (the tower speaker that was designed using H-PAS) a couple years ago, and I was quite impressed.
The soundbar is selling for $799. What may be useful for folks is the "intro" write-up that Outlaw sent out today. It helps explain a bit about the soundbar's design, particularly the practical repercussions of that low -3dB point. They posted the explanation here.
post #2 of 13
Is the Outlaw exactly the same as the new Atlantic Technology soundbar (other than branding)?
post #3 of 13
Yes. Exactly
post #4 of 13
Also it appears that the Outlaw warranty is 3 years vs 90 days on the the AT(?)
Is that correct as well?
post #5 of 13
AT has a 5 year warranty on their speakers if you register them and bought them from an authorized dealer.
post #6 of 13
Bob
Isdo you know if there is a reason they say 90 days on the website?
Getting the soundbar next week (from an authorized dealer) and will provide an aseessment
post #7 of 13
Use this link under register your warranty and click "View Limited Warranty". A Pop up will appear with the extended service agreement.
http://atlantictechnology.com/default.asp?IsDev=False&NodeId=40
I know AT wouldn't give you a problem as long as you bought from one of their authorized dealers and still had the receipt. The 90 days is from unauthorized dealers, I believe by law they only have to give 30 days.
post #8 of 13
Thanks for the link
Upon opening the link I believe the extended warranty will be one year as this is a powered speaker (5 years for active speakers)
post #9 of 13
The manual says 5 years but it might be worth giving AT a call to check.
post #10 of 13
I could be wrong but I thought powered speakers and active speakers were the same thing.
post #11 of 13
They are. I think the post above meant to say "5 years for passive speakers" as that is how the warranty reads in the AT manual.
post #12 of 13
Thta is correct
My mistake as I meant one year for powered speakers and 5 years for passive speakers as per the manual
AV guy is installing the AT tomorrow
post #13 of 13
Let us know how you like it. I have one coming but probably won't get much of a chance to play with it for a few weeks.
  Back to Forum: Soundbars
