I have read in some spots that the louvre filter basically is like vinetian blinds for the tv, blocking light from above. If the TV is going to be mounted above a fireplace, fairly high up, with only a light about 12 feet away in the next room over, will the filter even have any effect? Will just having a dimly lit room affect the blacks noticeably on the UT50 or does the light have to be fairly significant?
AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Panasonic Louvre Filter Question (UT50 vs ST50)
AVS Top Picks
post #2 of 7
10/3/12 at 2:12pm
post #3 of 7
10/3/12 at 2:25pm
post #4 of 7
10/3/12 at 2:56pm
post #5 of 7
10/3/12 at 11:42pm
post #6 of 7
10/4/12 at 5:23am
post #7 of 7
10/4/12 at 7:12am
AVS Top Picks
