AVS › AVS Forum › Display Devices › Display Calibration › Calibrators - Gear Storage and Transport
post #1 of 4
Though most of my work is done at home for reviews, I wanted to ask the pros out there what they used for storing and transporting their gear around. Right now I'm just using a combination of the i1Pro case and some other bags, but would like to keep everything in a single, sealed case that is well organized if possible. I'm hoping those that travel around a lot have a suggestion for that they use. Thanks.
post #2 of 4
Take a look at the Pelican 1510 w/ Pick-N-Pluck
Calibration Kit example
Edited by turbe - 10/3/12 at 11:50am
post #3 of 4
A Pelican was my initial thought, but I had seen some people complaining that the foam starts to fall apart from continually inserting and removing gear over and over. Any issues like that?
post #4 of 4
I use a storm case...pretty much like a Pelican.
Later
RayJr
