USB receptacle
post #1 of 2
Does anyone know if I can use this USB/Receptacle on a 20 amp line? The instructions say it will accept #14 and #12 wire so i assume it's ok??
http://www.cooperindustries.com/content/public/en/wiring_devices/products/receptacles/residential/tamper_weather_resistant/combination_usb_charger_with_tamper_resistant_receptacle-tr7740.html
post #2 of 2
Check out this link... seems you should be ok in a 20A circuit.
http://diy.stackexchange.com/questions/12115/is-using-15-amp-components-on-a-20-amp-breaker-against-code
BTW - I really like those outlets and have been thinking of getting something similar for awhile.
-Shawn
Standard Disclaimer - I am not an electrician nor do I pretend to be one on the internet.
