AVS › AVS Forum › Video Components › Home Theater Computers › why is thermal grease so freakin' hard to clean up ???
post #1 of 7
Just sayin'
You get some artic silver 5 on your clothes... just throw them away,
post #2 of 7
Originally Posted by Mfusick View Post
Just sayin'
The only thing I found that works cleaning Artic Silver is 190 grain alcohol (Everclear) which
is better used in Lemonaid.
Xylene is a better cleaner, but that is NASTY stuff.
post #3 of 7
True. I actually have some Artic Clean.. the thermalpaste remover. It works great on a CPU top... or a fan. But not on clothes... frown.gif
post #4 of 7
nail polish remover
post #5 of 7
I've been using Dow Corning DC111 vacuum grease as thermal compound for years. It is pretty much the same base but clear instead of white. Almost all thermal grease company buy a base then add their own secret sauce. It doesn't leave a white stain.
post #6 of 7
Arctic Silver is just like the name implies - silver. You should be using it sparingly anyway. If you're ham fisted enough to get it on your clothes then perhaps you should be wearing old clothes when using it.
post #7 of 7
lol.
No I did not even use any. I just had a tube in my pc toolbox (Yes I have a tool box of all PC related stuff)
I grabbed it and I guess the cap came off or something
I was not paying attention. I felt something on my finger so I wiped on my pant leg because I was installing a hard drive.
Then I realized after it was artic silver... and how hard to clean.
I must say the thermal past remover is very good though. It's awesome stuff
