Originally Posted by terrspin11
So, what is the conclusion regarding bi-wiring these receivers- yay or nay?
Also, does anyone set their input source level above or below 0 db? I have a ps3 and directv and am considering raising the level. My silly reason being, is for 100w, this doesnt seem to have a lot of low end oomph.
I am sure my thinking is flawed, so I am hoping someone can explain to my why i need to crank this up to get to the volume that is audible.
Nay for both bi-amping and bi-wiring.
Note also that increasing the Source Level setting will reduce the master volume level in the process so using this setting is generally only necessary if you want to level out all sources such that they each provide the same "actual" SPL volume at the same master volume setting.
