This is with one of my Pioneer FS51s
I think one of my tweeters is maybe blown I guess. I don't think I ever pushed it too far, and the other one sounds and measures perfectly fine.
I don't know exactly when this would have happened.
I tested all the speakers in the same spot and same location off the same speaker outputs of my AVR and the one rolls off significantly sooner.
I noticed this when running test tones for setting volume.
Also my Audyssey EQ trys to boost the higher frequencies of this speaker.
It does still produce sound throughout the entire frequency response. Just not as loud as the others.
That is measured from the exact same speaker connections and location.
I took it apart. From the start of reading a problem would be if the two connections don't measure any resistance.
Mine seems to.
Any thoughts on other potential problems?
I sent a email to pioneer but I can't imagine getting a useful response.
Is there anyway I can get an idea of what tweeter to replace this with?
Edited by Shinyav - 10/3/12 at 11:31pm
Mine seems to.
